Schematic needed I have a Philips Subwoofer SW 990/17, that is dead. It has blown both 4 amp fuses inside the woofer. It is probably the rectifier diodes that shorted, but I would still like to see a scematic
  • davidnc1972 May 21, 2009
    Schematic needet too. I have same problem, it is dead, but both fuses are OK. David
night71
  • 328 Answers
SOURCE: dis-assembling subwoofer
Unless you are good with wiring and can accept having the front cover broken, then you can do it yourself. The speaker protector can be gently pried off but will probably break if not done perfectly. If you get the front cover off, there should be 4 screws holding the speaker. Remove them and then you can see inside. Take note of how the resisters are attached. You may need to solder if they are separated. If you are confident handling this job, go for it, if not, take it to your local repair shop.
Posted on Oct 29, 2007
Ecollier2012
  • 3459 Answers
SOURCE: dptv335 Philips 55PW9363
Did you ever get this set fixed? If so what was the solution?
Posted on Oct 24, 2008
SOURCE: Sub woofer amp blown
looking for a replacement amp for mackie srm 450 woofer
Posted on Nov 14, 2008
easyq
  • 144 Answers
SOURCE: Fuse keeps blowing in the subwoofer on my Philips hts-3450
Replace the capacitors with ones of the correct v. Download latest manual from Philips website to verify if the capacity value is not a typing error.
Posted on Jan 29, 2009
srinivasb81
  • 51 Answers
SOURCE: Need to replace home theater subwoofer-Tivoli TDHT1 is the system
You please check the ohms with the woofer watts so that the same frequency of the woofer you can fix of different company, otherwise there will be damage of the circuit board so please use the appropriate frequency of woofer speakers.
Posted on Apr 12, 2009
Hi friends i am using kenwood subwoofer sw-300 its not working from two days, i observer relay triping sound from inside the amp relay omron g5r 2232p-kw 48vdc has continue tripping while power on,
Short circuit protection energizes. Check for any external short circuit with connecting sires to sub woofer. If it found OK, the sub-woofer output amplifier section circuit inside the set is fault. Short circuited component/s. Check and replace them. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Sep 03, 2015 | Kenwood Car Audio & Video
Miller bobcat 225ntblows fuse when you put fuse in
Stop using the fuse as a tester. Find the short circuit with an ohmmeter.
Nov 09, 2014 | Miller Bobcat 225NT 8000 Watt Generator...
JVC RX 505v stereo receiver keeps blowing fuses. Replaced fuse with specified rating (125v 5 Amp) but still keeps blowing fuse. Fuse appears black inside and I see a flash when I apply power. Can...
The likely cause of this is a dead short in the power supply. I don't receal the specifics of this unit, but there should be a set of four(4) diodes or a single bridge rectifier in the main power supply area. Check this/these for a direct short using a diode checker. Other than that, the output transistors being shorted can cause hte same symptom. Without seeing the actual unit, I can not tell for sure. If you know how, check the output transistors as well. Report your results here.
Dan
Nov 30, 2010 | Audio Players & Recorders
Hi i have problems with my subwoofer it wont play it's an alpine 12'' type e with alpine mrp m350 amp. there is light on the amp. how do I find out my subwoofer is blown or what else can be...
ok, your amp is in protect mode. either the speaker wires are crossed and shorting out, your woofer's vioce coils are melted and the speaker is blown or the amp is dead.
to determine if the speakers voice coils are melted, and thus the speaker being blown is the reason for the "protect" light, simply push in the cone of the woofer in gently with your hand. the woofer should move a little more than an inch, without any resistance, before bottoming out. if there feels to be any resistance, like a rubbing or scratching, before the woofer bottoms out, then your voice coils are fried, and you need a new woofer.
Nov 25, 2010 | Car Audio & Video
Samick sga 120 amp keeps blowing fuses. replaced all rectifier diodes and tranformer seems to be working fine. any suggestions?
Fuse blowing is due to excessive current drain and the the first clue is the blown fuse itself. If the fuse blows with a flash a bang and splatters copper across the inside of the glass you have a hard blow caused by a dead short on the power supply, check for power switch flashing over internaly. Short circuit main filter capacitors. Shorted turns in power transformer primary winding. If fuse just separates check for short on output transistors C to E. Try isolating fault by disconnecting LT pos/neg supplies to output stage. Also check for partial shorts on speakers and speaker wires using an analog ohm meter on low ohms setting.
Mar 27, 2010 | Audio Players & Recorders
Broken amp
Why did you replace the fuse? If it was blown then you need to take the amp in for servicing. Iffthe fuse is glass and it was silvery on the inside, that is a hard short and is likely a power supply problem. Probably a rectifier diode or filter cap. Pray that it isn't the power transformer. Diodes are cheap... few pennies... caps a few bucks at most. Power transformer... you DO NOT want to know.
Mar 13, 2010 | Fender Hot Rod Deluxe Guitar Combo...
The required fuse is 1.6 A / 125V an is blown, I wen to radio shack and bought a 1.6A/250V and it has blown 2 already, what can I do or check to fix it? This is a Sony Sub-woofer model sa-wmsp1.
If power transformer T1 got shorted or its output voltage got shorted for some reason, fuse will blow in Sony SA-WMSP1 active subwoofer.
Check power transformer, D401 bridge rectifiers and IC301 power amplifier out chip. Any of them is bad.
Let me know if you have additional question.
Thanks.
Jan 08, 2010 | JBL PSW-D110 Speaker
Power Light off & speaker not working
I had the same problem. The screws around the perimeter of the back plate must be unscrewed and the plate must be pried off as it is glued to the box. When replacing my fuse, 2A 5x20 GMA, it blew the fuse again. Disconnecting the second circuit board prevented the next fuse from blowing, but now the question is what is wrong with the circuit board? I cannot see any damage or shorts.
Oct 10, 2007 | Kenwood SW-38HT Subwoofer
357 people viewed this question
 Grubhead
Grubhead
