Codes for a magnavox t.v. for the remote
Im needing the codes to get my remote to change the channals on a magnavox t.v.
  • 5,138 Answers
Magnavox Codes 004-006-008-019-062-068-075-076-077--088-130-131-132-133-134-183-196-219-235
Posted on Dec 27, 2008
I have a ge universal remote model 02150-v2 and looking for a code for a magnavox DVD player
TRY THESE CODES :
MAGNAVOX 0398 0408 0979 0981 0980 0456 0915 0914 0969 0979 0980
3 DIGIT CODES :MAGNAVOX 360, 370, 398, 408, 456, 900, 903, 904 900, 904,162
Apr 09, 2012 | GE Televison & Video
I have a philips SRU3003WM universal remote im trying tn program to work on a magnavox tv model TR2510 C101 but cant find the codes to do so
The codes for Magnavox are 0807, 0002, 0502, 0919, 1914, 0224, 0430, 0247, 0402, 0408, 0109, 0715. Enter the code in the Setup and then check if the remote does any feature other than on/off.
You can search through all the codes as well. Turn on the TV. Press and hold the Setup button until the light remains lit. Press the TV button. Press Channel Up repeatedly (up to 300 times) until the channel changes on the TV. (If you miss this, press Channel Down to backtrack). Press the Mute button to set the code. Check if the TV responds to other functions of the remote. Continue the search as above if it doesn't work for all desired functions.
However if your TV was released less than 6 months before the remote was programmed or is newer than the remote, the code you need may not be in the programming.
I hope this helps.
Oct 03, 2010 | Philips Magnavox 27MS343S 27" TV
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
I have the MAGNAVOX MRU1400 universal remote. I
Im trying to set up this remote control to turn on an Admira tvl
Jan 17, 2010 | Philips Magnavox MRU1400 Universal remote...
I do not have a manual and need to know how to set it up and the code for a vizio tv.
On your remote you will find a setup botton and what i want you to do is hit set up then hit the tv botton and hit channal up and do that untell it turns off your tv are the channal if that works it tv botton again and your remote will work other wise in the back of your remote it well tell you a code number and go on line to philips and they will give your your codes for you.
Dec 09, 2009 | Philips Magnavox Learning Universal Remote
Need instructions to program tv
okay this is what you do hit the code search botton hit the tv botton the hit channal up untell you find that your tv is changing channals then hit tv again and that should work just do it slow becouse if you pass the channal it changes then you will have to use the channal back button tell it pops up again it will work.
Dec 09, 2009 | RCA Universal Remote Control
Need code to program Direct TV Remote to control Hyundai TV (Model: Imagequest Q321)
I do not think your remote will support that. Use DTV remote to change channals, IMGQ remote to change volume, input, and power.
Jul 03, 2009 | Televison & Video
I need to codes to program my remote for my tv
try hifi remotes.com Philips/Magnavox same company try magnavox codes also.
Jan 26, 2009 | Philips Universal PH301S Remote Control
I have a rca remote (rcu404) my tv is a magnavox. I can not find my book so I need help finding the correct code to program the remote to the tv. Thanks I do not have the code book for my remote control....
Code 000 for Magnavox TV Code 004 for Magnavox TV Code 006 for Magnavox TV Code 008 for Magnavox TV Code 019 for Magnavox TV Code 062 for Magnavox TV Code 068 for Magnavox TV Code 069 for Magnavox TV Code 075 for Magnavox TV Code 076 for Magnavox TV Code 077 for Magnavox TV Code 088 for Magnavox TV Code 130 for Magnavox TV Code 132 for Magnavox TV Code 133 for Magnavox TV Code 134 for Magnavox TV Code 183 for Magnavox TV Code 219 for Magnavox TV Code 235 for Magnavox TV
Jan 14, 2009 | RCA RCU404 Remote Control
Channal Search
Im sorry but you can't without the original remote. If you want to consider getting the remote go to http://www.remote.com or maybe you can borrow one from a freind or a local store that sells Emerson will let you borrow one. Good Luck
Aug 13, 2006 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
