Question about Sanyo DS31520 31" TV
No picture only blue line
Sanyo DS31520has a solid blue line through middle of screen--thats all--- no picture
  • pslquietwate Dec 27, 2008
    only solid blue line on SAnyo ds31520, a tech said More often than not, it would be the vertical output IC. Is thjis worth replacing or new tv time ?
  • pslquietwate Dec 28, 2008
    yes, thank you
  • Sanyo Master
  • 19,396 Answers
Nice Fixya!
Posted on Dec 28, 2008
    Genius:
  • 1,239 Answers
Hi I was not sure if the line was going from top to bottom or left to right. the X driver board is for left to right and the Y board is for top to bottom . The Y driver board is a common issue with these sets there is a Y main board and a upper and lower buffer board for the Y axis
Posted on Dec 27, 2008
  • ABHISHEK.C
    ABHISHEK.C Dec 27, 2008
    or just had one given to me with the same proplem. i think a bad soilder joint on one of IC chips. you just had to put a drop of soilder on it.
    Sergeant:
    Novelist:
  • 327 Answers
It is very much worth replacing the vertical output ic.as this is a common problem and gets easily repaired .
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, your description could possibly indicate a single line. This is almost always caused by the failure of the vertical deflection circuitry. More often than not, it would be the vertical output IC.
Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Dec 27, 2008
    This is a relatively easy repair and should take no more than 30 minutes to complete the job. Parts cost would be in the neighborhood of 10~15USD. Service fee would be another matter. However, if you have experience/comfortable with a soldering iron or know of a buddy who is, then it would be to your advantage to have it repaired.
    Cheers.
My 55in Sanyo has white lines top to bottom of the screen the color of the screen changes while cable is on and then turns black with big white and blue lines in the middle when jst the tv is on
T'Con board fault.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 18, 2015 | Sanyo Televison & Video
Sanyo dp50747 plasma tv is only showing in the middle of screen no video blue square showing horizontal 20 inches wide.The outside of square is blue solid both sides inside the square fuzzy lines red,...
It is line fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 17, 2014 | Sanyo Televison & Video
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
Sanyo DP46848 im stumped lol... with nothing connected ( aka ) cable and or any other components .. just plug and turn on .. the screen has a solid blue bar from top to bottom with small white lines in...
Although you have not posted a picture, I believe you may have a screen or LCD panel problem, the panels have film connections that go from the t-con module, through the panel control pc boards then through thinn film connectors from the lcd screen. Likely this is the problem.
Oct 29, 2013 | Sanyo DP46848 LCD TV
TV HAS A COLOR LINE WHEN IS ON IN THE MIDDLE OF SCREEN
if it runs across the screen its a buffer board usually. Can you paste a picture of the line?
Mar 10, 2013 | Sanyo DP50747 50 in. Plasma TV
I have a sanyo DS35580 and there is a blue line across the middle of the screen
You haven't stated whether there is screen or picture. If you see only a blue line across the screen with high brightness, vertical output Ic of your TV has burned out. Don't switch on the set further or increase its brightness, till the fault is retified. Otherwise there will a phosphur burn occur where the blue line is now, and it is internal, whcih cannot be retified anymore.
Oct 16, 2010 | Sanyo DS31520 31" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Picture goes to one thin horizontal line in middle of screen
There is a bad solder connection in the vertical sweep circuit. if you know how toi solder, go and find the vertical output IC and resolder that first.. but if you have no solid state electronic repair experience, please find a trained tech to assist you in this repair, as if you wait it may end up costing you double of what it would now, so haveit done ASAP. Good Luck Please do not forget to rate this one.
Oct 16, 2006 | Sanyo DS24205 24" TV
Sanyo DS31520 31" TV Logo
26 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
