Question about Panasonic CT-27SC14 27" TV
Panasonic CT-27SC14 This is a strange problem, or maybe not, the set when turned on appears to start up, I get High Voltage, static on screen and in checking there is indeed high voltage on the CRT around 20-30,000 volts, however there is no raster or picture or sound, no fuses blown and power indicator stays lit, the set does not shut down until turned back off, I suspect a problem on the secondary board, power supply board, any ideas as to what might be defective on this board to cause this? again I have no schematic for this model, any help would be appreciated.
  • Mark Moore Apr 24, 2007
    HI
    No, I didn't mean the voltage was fluctuating, I meant the voltage had a reading of somewhere between 20 and 30KV probably around the voltage you state. No as far as I can tell no filaments are lit in the CRT, in fact I have checked for heater voltage and have non as far as I can tell, this is why I'm suspecting a problem on the Low voltage supply board, as to what I'm not sure, thats the issue, I have no schematic for this model, any other ideas?
  • Mark Moore Apr 26, 2007
    HI
    Well after doing the checks, I found the CRT at fault, Ohmed out the pins, they were open, now I just have to find a good CRT, thanks for your help:)
    President:
  • 1,284 Answers
The high voltage should be around 29.5 KV and not fuctuate between 20-30 KV that would indicate a high voltage regulation issue then. Are the filaments lighted up in the neck of the CRT? If so then yes you are probably looking at a low voltage issue such as a 12 volt source or a a/v switching IC issue.
Posted on Apr 23, 2007
  • Don
    Don Apr 24, 2007
    If you have high voltage at 30kv then you should have filaments. The filament voltage comes freom the high voltage transformer and not low voltage. I would check on the CRT board for the two pins marked "F" for filament or "H" for heater and see if there is any kind of A.C. volatge there at all. If there is, disconnect the board and check for continuity between those two pins. Low resistance is normal, open is a bad CRT.
My panasonic crt tv stuck on standby mode only
Hi. Replace the batteries in you remote control already ?
Normally, every TV can be switched on using the local "channel up/dwn " buttons. If this does not work, then there is a more serious problem at hand.
Apr 09, 2014 | Panasonic CT-27SC14 27" TV
Distorted screen & picture does not fill screen
check smps power supply, capacitors first and the voltages.
May 03, 2010 | Panasonic CT-27SC14 27" TV
TV off...cant get out of standby mode
Sounds like the connections on the CRT Socket or CRT circuit board. Remove back and check connections.
You could also have buildup on the cathodes of the electron gun (internally) to redimie you must have set in operation and viewing video. Tap the neck of the tube gently while watching for the colors to change until they Stabileize, this is best seen whith the color turned off.
Good Luck
Feb 12, 2010 | Panasonic CT-27SC14 27" TV
My Panasonic CT-27SC14 tv won't turn on. worked fine last night. The cable box does but nothing happens with the tv..whether I use the remote or the power button. Unplugged it from the power source and...
hi,disconated from AC main. if you know bit of repairing tv and soldering? this what to look for main power board. 1 x dry joints 2 x leaky capacitors just remember when changing cap's make sure to use the 105' and same value.
Feb 04, 2010 | Panasonic CT-27SC14 27" TV
Panasonic CT-32g19j
check The B+ of your tv. If no b+ Check the input AC voltage. If Ac i/p are ok but no B+ Volt maybe your IC in power supply has problem.
Jun 01, 2009 | Panasonic CT-32SL14 32" TV
Can't tell if we need converter box for a Panasonic TV CT 27SC14J
this tv does not have a digital tuner. so, if you used an antenna to get off air channels, you would need a converter box. however, if you have cable or a satellite dish you will not need anything.
Oct 15, 2008 | Panasonic CT-27SC14 27" TV
Fixing Tilt
YOU PROBABLY TOUCH THE SCREEN VOLTAGE ADJUSTMENT LOCATED ON THE FLYBACK TRANSFORMER. BECAREFUL ADJUSTING IT LPUS IT IS HIGH VOLTAGE USE A PLASTIC ADJUSTMENT DRIVE.
THANKS DOCTOR VIDEO
Apr 24, 2008 | Panasonic CT-27SX11 27" TV
Panasonic 36HX41E Tau 36" HDTV Won't turn on
i think line out put transformer is leaking high voltage.if u r nat an technetion then dont try to on tv agin because high voltages can damage several costly ic in the set.
May 25, 2007 | Panasonic CT-32HX40 32" TV
Won't turn off
it can happen due to overvoltage shutdown circuit. when voltage is too high, tv will shut down. it is possible that this specific model doesnt fit your local electricity network.
Dec 14, 2005 | Panasonic CT-36HL43 36" TV
Panasonic CT-27SC14 27" TV Logo
158 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
