Question about Danze D302521 Antioch Roman Tub Faucet with Soft Touch Personal Shower - Ch...
Trying to remove cowell from Roman tub faucet
I have a Price Pfister RT6. I replaced the valve but the spout is wiggling and the set screw is tight. I would like to remove the cowell / spout and see if I can tighten it. Any ideas?
Thanks
    Problem Solver:
  • 14 Answers
The Price Phister Roman tub spout needs to be tightened from beneath.
If you do not have a removable skirt on the tub it will be a bit difficult to tighten.
Should you have crawl space under the tub and are careful to locate the dead space between the tub and the skirt you can cut a hole beneath the valve and spout location and reach up from below to tighten the spout.
If you have tile as a surround and no access from below you will have to remove some of the tile in order to gain access.
You may want to call in a proffessional plumber to handle this.
Hope this helps,
sanray
Posted on Dec 27, 2008
Pfister tub faucet is blocked
If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed.
He has a very extensive list of repair parts for faucets and knowledge of how these work.
Rod
US Parts Center
Jan 29, 2013 | Price Pfister Pfister 806-dy11 Treviso...
New Faucet drips for several seconds after it is
some of these new faucets are "soft off" which means the will drip or run for a second or 2 before the water stops. I know this can be annoying, but it is how some of them are made
Aug 01, 2010 | Price Pfister RT6-B0XX Georgetown Two...
The shower tap is broken. The top came off of the plunger that changes the water flow from shower to tap and all the other pieces fell into the tub. Is there an easy way to fix it. I am definitely not a...
it may be very simple--you have to get your head underneath the tub spout and look to see if there is a "set screw" on it---if there is ,you unscrew it, which releases the screw holding the spout in place on the pipe coming out of the wall---jimmy it a bit and the spout will come off---don't yank too hard---if there is no set screw, then all you do is turn the whole tub-spout counterclockwise carefully, and unthread it from the pipe in the wall..replace w/ a new tub-spout--anywhere from $5 to $500
Feb 24, 2010 | Price Pfister 01-111 Shower Head, Tub...
I have a Price Pfister Traditional Chrome Roman Tub Faucet Model #WR2700C. It is a brand new faucet, just installed it. I'm getting a very slow drip from the faucet. What can I do to stope the leak...
There could be debris wedge in the cartridge of the faucet. If you have tried pulling the cartridge out to see, and you are still having these issues, more than likely it is a defective cartridge; in which case it should still be under warranty. If you haven't tried this, then I would recommend doing so. Just be sure to turn water off to your faucet first.
Nov 15, 2009 | Price Pfister RT6-E0XC/HHL-ELBC/0X6-040...
Moen Tub Filler Can't Remove Spout
It should lift off gently twist as you lift maybe tap spout lightly back and forth with a rubber mallet
Oct 14, 2009 | Moen Kingsley Two Handle Roman Tub Faucet...
Tub shower diverter stem on tub spout broke and need to have instructions for how to replace the ROD Diverter seal o ring in the spout.
you must replace the whole stem.you can get it at homedepot. first take the cover off over the stem. this should screw off or is held on with a allen key.then unscrew stem from valve body.make sure water is off to tub,just in case.
Jun 27, 2009 | Price Pfister Ashfield Single Control...
My 3 handle bathtub fauset [price pfisher] cycles hot and cold
You will need to either replace center "shower diverter"assembly or a quicker fix would be to remove old tub water fill spout and replace with a "pull up diverter knob" type water spout. Cost about 10 dollars Hdepot Pull Knob to divert water to shower when showering.
jthomefix
Mar 15, 2009 | Price Pfister Ashfield Widespread Bathroom...
Trying to take apart to find the leak
Turn off water supply, if its a single handle there should be only 1 set screw then diverter is screwed down. After you remove the diverter there is a small rubber washer or o-ring ..let me know which it has.Thankyou.
All Price Pfister Parisa Collections products are backed by the Pforever Warranty, which guarantees both finish and function for the life of the product.
Dec 14, 2008 | Plumbing
Danze D302521 Antioch Roman Tub Faucet with Soft Touch Personal Shower - Ch... Logo
212 people viewed this question
Top Danze Plumbing Experts
john h
Andrew Bugbee
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
