Question about Scosche Industries EFX Amplifier Wiring Kit 8-gauge w/Patch Cord Car Audio Amplifier
Trying to hook my amp up in my car, I already have everything but the main power supply which is the wire to the battery.I was wondering how would i do that the right way?
    Problem Solver:
  • 9 Answers
The car amp needs to be wired using a +12 power, ground, and +12v signal (rmt) cables.  the +12 volt cable needs to be connected from the posative terminal of the car battery to a fuse (the right size should be written on the amp somewhere) then to the +12v on the amp. the ground cable needs to be connected to the negative terminal of your car battery. the RMT is the more complicated one, this needs to be connected to the header unit or the ignition switch. if you look in the instructions for your header unit (the unict where you insert CD's or tapes etc) this should explain whewre exactly to connect this cable. or you can connect it to the terminal on the ignition switch which becomes live only when you turn the key, should be the third one in. this line basicly tells your amp to turn itself on when it recieves a 12v current. you can also wire it up to a manual switch directly from the battery by connecting another cable to the posative terminal of the battery then to a switch then to the RMT terminal of the amp.
Posted on Dec 28, 2008
I have an Pioneer ts-wx65a that was given to me. I
power from the battery to the amp, blue wire called the remote wire or pwr ant wire to the amp and a good ground to the amp also from the back of the radio is two rca jacks that need to run to the amp
Oct 15, 2014 | Car Audio & Video
Tried hooking subs and amp to my factory deck in my 2006 chrysler town &country limited.. Everything was working but wife's friend started while I was wiring smelled like burning electrical.. Now no s
Only fuse you need is the power wire leading to your aftermarket amplifier for te subwoofer. Which most likely you have too small of a gauge of wire and burned straight through it, and if you haven't, add a 40 amp fuse near the battery where your power cable is hooked up to. Also use a multimeter to test your power wire on amp, check the
Jul 19, 2013 | Car Audio & Video
I have a amp from my car hooked up to a laptop power supply. It won't turn on. Everything is connected properly. What should I do
Why would you do that? If you were were going to do it properly, did you hook up the remote wire as well? Second, the voltage coming out the charger is >18 volts while the current draw on the amp is way too high for that charger.
Nonetheless, try a car battery if you want to test the amp.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
May 17, 2012 | Kenwood Car Audio & Video
I have one wired connected to the ignition on to main power and it says i need to connect one to car power supply, where do i hook that one up to ???
Are you installing a speaker box and amplifier? Your ignition wire on your speaker box or amplifier should go to the ignition wire on your radio. That turns the system on when the radio is turned on. The main power wire should be ran using 8 gauge or lower wire with a 30 amp fuseable link and connect directly to your battery
Aug 14, 2011 | Clarion Car Audio & Video
So, everything is hooked up, the amp is getting power, but the problem is getting power from the amp to the sub, any idea what the problem could be?
Well the two main things that i think of is that your fuse in your battery wire is blown. Or that your ground wire isn't all the way connected
Jan 18, 2010 | Alpine MRP-M500 Car Audio Amplifier
No power to amp
Hi do you have power back to the amp on the main feed if so check the fuse in the amp
May 17, 2009 | 2002 Chevrolet Impala
Stereo amp power supply
No I wouldn't share the amp feed. It should be stand alone, with its own fuse.
Yes it is wise to connect directly to the battery, hence through the firewall.
You should purchase an amp wiring kit, matched to the
watts of the amp. It has everything you need to correctly make all of the connections.
Good luck
Aduz
Mar 11, 2009 | Car Audio & Video
Amp problems
did you run your 12+ to the battery? did you supply a sufficient ground of least 2x the size of the power lead?..did you hook up to the amp turn on lead and NOT the power antenna? model numbers of radio and amp would really be helpful...my email is troublerst@hotmail.com send me specifics and we will work it out
Nov 07, 2007 | Car Audio & Video
Scosche Industries EFX Amplifier Wiring Kit 8-gauge w/Patch Cord Car Audio Amplifier Logo
276 people viewed this question
Top Scosche Industries Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Scosche Industries Car Audio and Video Expert? Answer questions, earn points and help others
