Question about Timex T309TT Clock Radio
Setting the time
Hi guys, I just can't figure out how to set the time on this clock. I actually don't know how to do anything else with it but I really need to set the time correctly. My son left it here when he returned to California. Help Clueless2
  • 1 more comment
  • Banne Nov 10, 2007
    I have a Timex Model #T308S, preset tuning clock radio with auto-set and nature souunds. It was a gift, and try as I might, I can't set the "bird-song" alarm, or any of the nature sounds. I press down on the various buttons, i.e. reset, date set, right or left arrows, and nothing happens. What do I need to do to get it to work? I did reset the time change from DST to ST, after many unsuccessful attempts, by removing the batteries.
  • Anonymous Jan 06, 2008
    Need a manual. Can't get the alarm set.
  • spano Mar 09, 2008
    how do I set the time on timex T 309TT?
Manual is found at www.timexaudio.com
Posted on Jan 06, 2008
Remove the screw from the back near the top. Remove the top cover. Press and hold the time button located underneath the cover. Press << or >> to change the time and press the time button again.
Posted on Jun 19, 2007
On the T308S, depress and hold one of the Alarm buttons on top ("1" on the left-front, and "2" mon the right-front) until the alarm time starts flashing. Momentarily depress the "Mode" switch on the top-left-front (also labeled "1") to CYCLE through the Sound options. The lower-right portion of the Display will change, ,indicating the Nature Sound or BUZ selected.
Posted on Jan 04, 2008
SOURCE:
RCA Model RP3765 manual
Hi Arlene, Your clock should actually set its own time if the two Double batteries are installed. If not click link and follow instructions RCA RP3765 User Manual Setting The Clock Setting Clock
Good luck
Nov 04, 2014 | Audio Players & Recorders
Don't know how to set alarm or time
Please download the user's manual from here:
http://www.nodevice.com/user_manual/download_346371.html
Then read pages 14-15 for setting the time and pages 16-18 for setting the alarms. This guide is detailed and good enough.
Thanks.
gylacz
Jul 18, 2011 | Memorex MC2864 Clock Radio
I wish to change the time on the clock on my LUMINA MICROWAVE. I lost the manual so I don't know how to do it. Can you please give me some guidance on how to change the time? I look forward to hear...
I feel your pain, I am in the same position. After endless mucking around I finally figured it out. By the way, this is for my model P10034AP. Press these buttons: - Cancel [to abort anything currently underway] Clock [to set the time] Cancel [to clear the time allowing input] nnnn [the 4 numbers HH:MM in 24 hour time] Clock [to set the new time]
Hope that helps :) Cheers Jonathan Barton
Jun 29, 2011 | Microwave Ovens
I don't know to set the time and alarm. Cd player isn't working but somtimes it does then not again!!! It's weird!!
You do not have to set the clock time
as a built-in automatic time set system
is equipped in this clock powered by 3V
(2 x “AA” batteries (included)). All you
have to do is to plug this clock for
power and current time will be shown
automatically.
Before plugging in for power, follow
the steps below to select time zone.
Setting Time Zone
You may slide the time zone selector at
the bottom of the clock to Pacific,
Mountain, Central or Eastern.
Refer to Figure 1 for U.S. Time Zone
details.
Refer to Figure 2 for Canadian Time
Zone details.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Jun 15, 2010 | RCA RP3740 Clock Radio
Wont work
Don't know this particular model, but it sounds like you are just pressing the time buttons for cooking and not actually setting the time clock which is what it's asking for. Are you following the instructions for setting time as detailed in your instruction book?
Oct 20, 2009 | Whirlpool Microwave Ovens
Setting the delay on the oven
To correctly proceed you have to know the format the timer program is working in. SO you need to know
1Time format IE 12 hour AM - PM or 24 hr military time 2If a day, date is required M-Sun...or IE Sat 12th of March...(some times this is not a peramiter needed)
With the clock and calendar set the delay time should require a "timed mode setting" prior to being able to set the timer. Once in this mode you will have 1 of 3 ways to set the time delay depending on how the timer is set up to read your instructions. .
1 the actual time of day it is to start (set in actual clock time like the equalivant of 3:05 PM or if in military time, 24hr clock 15:05) or 2 the actual delay time until the program is set to start (again set in hours and minutes 2:10 = 2 hours and 10 minutes from now) 3 also is the stop time, when you want to program to end (also set in the format the timer is programed to recieve instructions)
Also the calendar could be waiting for input as to which day to start the program
Jun 12, 2009 | Kitchen Ranges
I have a chefmate digital kitchen scale and I do not know how to reset the clock.
I have the same problem. The only way I can figure out how to reset the clock is to take out the batteries and put them back in at 11:59 pm or midnight. Replacing batteries reset the clock to 12:00 am. So if you do it at midnight, you'll end up with the right time. But for the life of me, I cannot figure out how to actually set the clock using the availble buttons.
Apr 13, 2009 | Health & Beauty
ALARM CLOCK SETTING
I've manage to set it... press time/awake and the 1 flashes... use arrows to set the time... then press time/awake again for alarm 2.
But how do you know when it is actually set?? it did not go off this morning and i was late for work!
Mar 14, 2009 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
I HAVE A KENWOOD KDC 122 CD CAR STEREO. THERES A CLOCK ADJUSTMENT BUTTON,WHEN I PRESS THE CLOCK ADJUSTMENT BUTTON THE CLOCK "FLASHES" BUT I DON"T KNOW HOW TO SET IT,I DON"T KNOW HOW TO MOVE THE NUMBERS,IF...
For the manual for this unit head to this page
http://www.cartoys.com/cartoy/pdfs/kdc-122s_manual.pdf]
However im pretty sure you actually use the volume or tune/seek to change the numbers then when changed to what you woudl liek again simply hit the main button you used to get into the clock setting originally,
Hope this helps
Cheers
Steve
Mar 09, 2009 | Kenwood KDC-122 CD Player
Sopho BaseLine Pro, Philips telephone set
sir,
i have philips sopho baseline pro device. we are having since 7 years. now we need to change the settings,i.e programming. send the user manual or programming guide.we are the technical guys. we can get easily.thanks
Sep 08, 2008 | Philips Lands Phones
Timex T309TT Clock Radio Logo
450 people viewed this question
Top Timex Audio Players & Recorders Experts
Gyula Lacz
Steve Allison
Steve Allison
Are you a Timex Audio Player and Recorder Expert? Answer questions, earn points and help others
