Question about Canonical Ltd. Ubuntu
My computeer will not connect to the web
It said i have to manually run dpkg config a how do i do this can you explain thanks steve
    Scholar:
  • 77 Answers
I do not have a linux desktop and have not used ubuntu much but I can explain and I hope you can understand.
You need to either open a linux console terminal OR just press Ctrl - Alt - F2 . Then press enter and run the following command:
sudo dpkg-reconfigure  followed by the package name you want to configure, or whatever it was that gave this error.
HTH,
Deboo
Posted on Jan 04, 2009
How can I fix the problem of not being able to use Synaptic Package Manager or Update Manager in Linux Mint 1i KDE?
Did you run sudo dpkg --configure -a in terminal? Can you reinstall the update manager? Sounds like everything needs to be removed and reinstalled from terminal, and maybe a sudo apt-get autoremove followed by an update? It seems like the only reason synaptic and software manager wouldn't work is you've over tinkered with your os, and maybe accidentally removed something you needed for those things to run. I'm new to Linux myself, so beyond that idk. If all else fails, backup and do a fresh install to get your system back to it's original state.
Sep 17, 2014 | Computers & Internet
How do i configure the switch to allow web access through the serial port
If you can't find the manual on the Dell web site, there is a copy at: http://www.manualowl.com/m/Dell/PowerConnect-3548/Manual/188907
Did you use the command: ip http server ? See page 501 in the manual.
I would not recommend setting up a network switch with password-free access to the internet. You should at the very least limit access to a small subset of IP addresses (e.g. your network group's machines). The best practice is to use ssh communications or https with the web browser, otherwise anyone with a well-placed sniffer can read your clear-text traffic.
Sep 19, 2012 | Dell PowerConnect 3548
I have a Toshiba Satellite laptop and I'm needing to know how to get the drivers back on it for wireless. I installed Windows Xp on it and since then I can't connect wireless. Thanks for your help...
hello my brother this web site can help to get back your driver the website will make a scan for your pc and will give you the drivers that you need to set up (the needed drivers) from here www.ma-config.com
NOTE:this website is free , and too you can get an explain on youtube if you don't know how don it work. just writ this in youtube (www.ma-config.com
and please rate me
Jun 14, 2011 | Computers & Internet
How to install package manager in ubuntu?
A package manager is a program that installs and uninstalls software, and keeps track of all the components each piece of software needs.
Dpkg is the Ubuntu package manager dpkg is a medium-level tool to install, build, remove and manage Ubuntu packages. The primary and more user-friendly front-end for dpkg is dselect.dpkg itself is controlled entirely via command line parameters,which consist of exactly one action and zero or more options. The action-parameter tells dpkg what to do and options control the behavior of the action in some way.
Now we will see all the available commands for dpkg with examples
1) Install a package
Syntax
dpkg -i <.deb file name>
Example
dpkg -i avg71flm_r28-1_i386.deb
2) Install all packages recursively from a directory
Syntax
dpkg -R
Example
dpkg -R /usr/local/src
3) Unpack the package, but don’t configure it.
Syntax
dpkg --unpack package_file
If you use -R option is specified, package_file must refer to a directory instead.
Example
dpkg --unpack avg71flm_r28-1_i386.deb
4) Reconfigure an unpacked package
Syntax
dpkg --configure package
If -a is given instead of package, all unpacked but uncon-figured packages are configured.
Example
dpkg --configure avg71flm_r28-1_i386.deb
5) Remove an installed package except configuration files
Syntax
dpkg -r
Example
dpkg -r avg71flm_r28-1_i386.deb
6) Remove an installed package including configuration files
Syntax
dpkg -P
If you use -a is given instead of a package name, then all packages unpacked, but marked to be removed or purged in file /var/lib/dpkg/status, are removed or purged, respectively.
Example
dpkg -P avg71flm
7) Replace available packages info
Syntax
dpkg --update-avail <Packages-file>
With this option old information is replaced with the information in the Packages-file.
icon_cool.gif Merge with info from file
Syntax
dpkg --merge-avail <Packages-file>
With this option old informa-tion is combined with information from Packages-file.
The Packages-file distributed with Debian is simply named Packages.dpkg keeps its record of available packages in /var/lib/dpkg/available.
9) Update dpkg and dselect’s idea of which packages are available with information from the package pack-age_file.
Syntax
dpkg -A package_file
10) Forget about uninstalled unavailable packages.
Syntax
dpkg --forget-old-unavail
11) Erase the existing information about what packages are available.
Syntax
dpkg --clear-avail
12) Searches for packages that have been installed only partially on your system.
Syntax
dpkg -C
13) Compare Package versions version numbers
Syntax
dpkg --compare-versions ver1 op ver2
14) Display a brief help message.
Syntax
dpkg --help
15) Display dpkg licence.
Syntax
dpkg --licence (or) dpkg --license
16) Display dpkg version information.
Syntax
dpkg --version
17) Build a deb package.
Syntax
dpkg -b directory [filename]
18) List contents of a deb package.
Syntax
dpkg -c filename
19) Show information about a package.
Syntax
dpkg -I filename [control-file]
20) List packages matching given pattern.
Syntax
dpkg -l package-name-pattern
Example
dpkg -l vim
21) List all installed packages, along with package version and short description
Syntax
dpkg -l
22) Report status of specified package.
Syntax
dpkg -s package-name
Example
dpkg -s ssh
23) List files installed to your system from package.
Syntax
dpkg -L package-Name
Example
dpkg -L nagios2
24) Search for a filename from installed packages.
Syntax
dpkg -S filename-search-pattern
Example
dpkg -S /sbin/ifconfig
25) Display details about package
Syntax
dpkg -p package-name
Example
dpkg -p nagios2
Please check if this is any help for you.
Regards.
May 26, 2010 | Computers & Internet
I can't get my web picture to connect to business
test with MSN . then try config on MSN on tools and choose Webcam config or Audio/Video config.
Jan 05, 2010 | Dynex DX-WC100 Webcam
Modify Web.config file at Run time
http://www.west-wind.com/Weblog/posts/5688.aspx ~This sets the basic idea in motion. Regards Gewiz
May 28, 2009 | InstallShield 11 Professional Edition
TV will not work when connected to laptop with av cable
moz-screenshot.jpgmoz-screenshot-1.jpgmoz-screenshot-2.jpg This information is from the owners manual for your model Sony (PCG-GRZ610) PC Notebook computer found on page (57) has a diagram and procedure for making the correct connections. You must make sure you have the correct connection cables and have set both the television and computer for external signal output source (notebook).External signal input source (television). The cable connection is listed below and follow the web page link to see the correct procedure for getting the laptop computer and the television working together. This procedure is explained in the notebooks owners manual on pages (112) (113) (114) you will also need to look in the televisions owners manual to see the procedure for switching the input source to external, so it can see the computer's signal. The owner manual copy is listed as the user's guide. You will also find customer service available on this web page. They will be able to help you with any problems you might be having with the set-up between the computer and television not explained clearly to you in the owners manuals of the laptop and television. I hope this information helps you solve the problem of making the connection between your laptop and television. Thank you for using FixYa and have a nice day! http://esupport.sony.com/US/perl/model-documents.pl?mdl=PCGGRZ610
May 07, 2009 | Sony VAIO GRZ610 Notebook
Wireless Connection
Follow trhis posting as I'm working a pretty much the same prolem
Trendware TRENDnet TEW-421PC 54Mbps PCMCIA...
trying to get a laptop on aol
Hi We are trying to connect to Aol by laptop.... More...
Jeff
Feb 08, 2008 | Computers & Internet
DPR-1260 ... prints but cannot access web config page
To get into the web configuration you need to know your firmware on the DPR-1260. If it is 1.12, us http://dlinkps-xxxxxx where the X's are the last 6 number of the mac address. If it is 1.20 and up, use http://dlink-xxxxxx, where the x's are the last 6 number of the mac address. If you do set it up as DHCP or static and know the ip address of the print server just type in the ip address of the print server on the address bar.
Oct 21, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Canonical Ltd. Ubuntu Logo
44 people viewed this question
Top Canonical Ltd. Computers & Internet Experts
none
k24674
Jaipal Reddy
Jaipal Reddy
Are you a Canonical Ltd. Computer and Internet Expert? Answer questions, earn points and help others
