Question about Cameras
Lens stays open
When power on it beeps and says lens error restart camera. Battery is charged and remains unchanged. Lens does not retract back into camera
  • blte Dec 31, 2008
    My canon digital camera turns on, the lense will not retratct and I can not restart it so the lense goes back in.
  • 33 Answers
The lens would have to be repaired or replaced. You'd be looking at a $95-$125 repair
Posted on Dec 31, 2008
When I power up the camera the lens opens and immediately retracts and the camera shuts off. I've attempted to push every button while turning on the camera to no avail. I also held onto the lens when it...
Have you made sure that the batteries are LiIon and fully charged? I had a similar problem with a Kodak Easyshare camera that required the higher voltage LiIon battery pack rather than alkaline AAs which will fit in there but is not exactly right.
Feb 09, 2011 | Kodak EASYSHARE M763 Digital Camera
I put in my battery after charging and the camera opened but it will not take pictures. The lens will note retract. when I press the on button the green light comes on but the camera buzzes and nothing...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 24, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Camera beeps and turns off and lens won't retract
Lens error / Battery expire.
1. Use a new battery will fully charged and then use it. Hope you get good result.
2. Some time lens zooming gear getting damaged by dust. if that gear is scrached by dust then your lens can't work and it will stucked. Your camera automatically turn off.
Of those 2 85% chance of poor/ long time used Battery & 15% chance of lens zooming gear damaged.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Cameras
The screen reads "lens error, restart camera. I can not get the lens to retract. I can not get the power to stay on. The cannon screen shows up momentairly - but fades to black and the message appears.
remove the battery, let it sit for at least 2 hours, then put it back. put the batteries back, then gentle push the lens sideways to free its stuck part. if the error still occurs and the lens is not retracting, consult the warranty for the device as the lens assembly gears may be at fault.
regards,
voodoo
Aug 12, 2009 | Canon PowerShot SD1000 Digital Camera
Lens Error - Restart Camera : Lens remains in extended position.
I had the same problem with the same camera. Ended up twisting the lens by hand back and forth while powering the camera on and off till the lens pins finally realined and let it close properly. Took alot of patience and care but has worked since. Usual cause of this problem is powering camera while the lens is blocked from extending, ie in a case, laying on its face etc.
May 28, 2009 | Canon PowerShot SD870 IS Digital Camera
Lens will not retract. orange and green lights come on, but preview screen remains dark and lens will not retract when I trun it off.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 02, 2009 | Cameras
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Lens error. Restart camera.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 07, 2009 | Canon PowerShot A720 IS Digital Camera
Camera beeps loud 3 times and shuts right off!!
sounds like a lens error, does the lens extend or retract? You probably have to get the lens back on track, use gentle pressure wiht the camera face down on a towel covered table and turn on to see if the camera tries to retract the lens. I really dislike these types of cameras that extend the lens everytime, if it turns on in your pocket, your doomed!
May 27, 2008 | Samsung Digimax S500 Digital Camera
Cameras Logo
162 people viewed this question
Top Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
