Question about Video Game Consoles & Games
No video through hdmi output on ps3... have sound just not the video?? Anyone know??
  • 73 Answers
Well this one is easy,if there is a sound and no video.make sure that your tv is switched to hdmi input.maybe you are switched in the a/v input.but if you are already on the hdmi input then try to use another hdmi cable.maybe its faulty already.let me know what happens and maybe i can give more help
Posted on Dec 27, 2008
5 Suggested Answers
Orbixx
  • 133 Answers
SOURCE: How do I get my PS3 repaired?
Well PS3's come with a 1 year warranty, I'd check your date of purchase to see if it was under 1 year, if so - you can get it repaired under warranty if it's faulty.
Posted on Sep 07, 2007
  • 5 Answers
SOURCE: Do you want to output video and audio using HDMI on the PS3?
How do you have the PS3 hooked to your tv?
Posted on Jun 20, 2009
benwabnick
  • 2404 Answers
SOURCE: No video on PS3
Use regular A/V cables on the ps3. Turn off the PS3 from the back. Go ahead and hold down the power button on the front and as your doing that turn on the ps3 from the back and keep holding the power button on the front for 5 seconds.
At this point it should reset the machine back to factory defaults and you should get video. Go ahead and change the video output to HDMI and reboot the system. On the reboot you should get video from the HDMI output, if you don't then that means you have a bad main board inside of fthe PS3.
Posted on Aug 19, 2009
addmeps3
  • 61 Answers
SOURCE: PS3 HDMI No picture nor audio
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Posted on Jun 28, 2010
Only sound comes when i connect HDMI cable to my TV for the ps3
you need to select High definition output on the PS3. Connect it via hdmi and via standard lead switch the tv to standard so you can see the picture then select high definition output. Switch over to hdmi and you should see a picture
Mar 01, 2011 | Video Game Consoles & Games
Jun 26, 2010 | Sony Playstation 3 (PS3) Console
How do i connect my PS3 to get output sound from DAV Z280
you need to go into the sound settings on the ps3 and choose to play sound through hdmi
Mar 29, 2010 | Sony Playstation 3 (PS3) Console
No video on PS3
Aug 19, 2009 | Sony Playstation 3 (PS3) Console
Ps3 and onkyo receiver
Hello.
I have a similar setup and am having problems of my own, but i've got it somewhat working at the moment.
I have the TV connected via HDMI to the receivers HDMI output port.
I have the PS3 connected via HDMI to the receivers HDMI input port 1.
I went on the receiver and followed the instructions in the manual to setup the DVD function on the receiver (i chose to call my ps3 a dvd) to use HDMI-1. I can't remember the button combination as i'm not at my hosue right now, but it was in the HDMI section of the manual (page 44 on my manual). Essentially I had to tell the receiver to enable HDMI for the DVD function rather than being defaulted to "No". At that point, with the default ps3 setup, I was able to get video to pass through.
Next, i went into the video options on the ps3 and changed it to 1080p (since my tv supports that).
Where I"m having my problem is that the sound from the ps3 outputs directly to the TV and doesn't output on my receiver for some reason.
How I've rigged that to work is to take the HDMI to RCA cable that came with my PS3 and i plugged in the Red and White wires on the back of the receiver in the DVD section of inputs. At that point the sound comes through the receiver.
What I don't know how to do and would really like to know is how to get the sound to output on my receiver via HDMI only and not with the extra cable.
Anyway, if i'm making sense above and you follow that, you should be up and running (but maybe not in an optimal configuration).
Let me know if you ahve any questions.
Also, if anyone knows the solution to my issue, i'm all ears.
Thanks.
Nov 09, 2008 | Onkyo TX-SR803 Receiver
PS3 HDMI & AV outputs not working?!?!?!?
change the sound output to HDMI? does the sound work on just like a normal tv channel?
Sep 03, 2008 | Sony Playstation 3 (PS3) Console
HDMI ON ILO 32HD
it sounds like there is a problem with either the output on the PS3 or the input on the circuit board of the TV. I would try a reset on the PS3 first. Also make sure that there are no other video or audio cords plugged into the PS3 because this will cause the PS3 not to send the signal via the HDMI.
Mar 14, 2008 | iLO 2600 Television
Ps3 Surround sound
ttttttttttttttttttttttttttttttt
Nov 22, 2007 | Sony Playstation 3 (PS3) Console
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Video Game Consoles & Games Logo
57 people viewed this question
Top Video Game Consoles & Games Experts
Marvin
Marvin
MegaByteMe
MegaByteMe
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
