Question about Toshiba gigabeat S MP3 Player
How do I replace a battery in this device?
The battery only holds a charge for 30 minutes or so.
  • 3 Answers
Replace the Battery
  1. Remove five screws: two on the side, two on the bottom and one on the back behind the lanyard hook. When that screw is removed, remove the lanyard hook insert.
  2. Slide the metal backing down as shown in the photo. Then pull it straight up.
  3. Unhook the ribbon connection attached to the metal backing by lifting up on the brown flap where the ribbon is connected. The ribbon will then slide out.
  4. Pull the hard drive back as shown in the photo.
  5. Remove two screws near the bottom of the player. One is on the bottom and one is on the right side near the battery switch.
  6. The battery is now exposed. You can disconnect it by gently pulling on the red and black cables.
http://www.anythingbutipod.com/archives/2006/06/toshiba-gigabeat-s30-teardown.php
Posted on Dec 27, 2008
  • ymee232 Dec 27, 2008
    The link above didn't work maybe this one will:
    http://www.anythingbutipod.com/archives/...
My Roomba 561 will only run for about 30 minutes and then needs to charged. Is there a way to charge the battery longer?
The battery may be getting old and unable to hold a charge. I would recommend checking with the manufacturer about replacement batteries.
Mar 11, 2018 | Roomba Vacuums
Tablet won't charge
With your tablet unplugged, press and hold the Power button for around 30 seconds. Then place your tablet on the charger (preferably the home charger) and wait a couple minutes. Then press and hold the power button for around 30 seconds again. If this does not help, then the battery may be bad. Storing a lithium-ion battery should done with no less than 40% battery life left, otherwise the battery voltage or power can go below the safety net (li-ion batteries are not fully dead when your device tells you they are. Once the battery reaches below the safe level, the battery is no longer good or safe to use anymore).
Aug 10, 2013 | Samsung Galaxy Tab Tablet PC
My phone has been ringing 30 minutes with black screen not allowing me to slide ON..It also does not allow me to power down. This could go on all night if my battery does not run down. WTH?!
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 06, 2012 | Apple iPhone Smartphone
Shuffle not working
If an iPod appears not to turn on, check the hold switch on the device.
If this switch is activated while the device is off, it will not power on again until the hold switch is turned off.
If that is determined not to be the problem, the battery's charge should be checked.
When the battery is no longer holding a charge, the device will not power on, but will show a battery icon on the screen for a few seconds.
If you see this icon while trying to boot up the iPod, just connect it to the USB cable and allow the battery to charge, which can sometimes take up to 30 minutes before the iPod becomes operable again.
If no battery icon appears when trying to turn on the device, try resetting the iPod.
Once reset, the device should turn on, but if it does not, the battery may need to be drained first (by leaving the iPod disconnected from power for up to 24 hours), and the reset procedure tried again.
hope this helps
Oct 15, 2012 | Apple iPod classic 6th Generation Digital...
My samsung CE0168 will not turn on??????
5.Wait 10 seconds.
Step
Thanks
Sep 14, 2012 | Samsung SGH-t639 Cellular Phone
Phone not getting switched on
5.Wait 10 seconds.
Step
Thanks
Sep 03, 2012 | Apple iPhone 3G
My I pod stopped working
How old is the battery ipod batteries can only be recharged a certain ammount of times before they need replacing
If that is determined not to be the problem, the battery's charge should be checked. When the battery is no longer holding a charge, the device will not power on, but will show a battery icon on the screen for a few seconds.
hope this helps
Aug 19, 2012 | Apple MA146LL/A 5th Gen Video iPod 30GB -...
When it is fully charge and i unplug it showing 80% but with in 30 minute it shows battery low.
All batteries have a certain lifetime to them. After so many charges the battery will eventually stop holding a charge. When this time comes, there is nothing to do except check the warranty on the battery and get it replaced or buy a new battery.
Mar 23, 2011 | Computers & Internet
No power off charge
Sounds like you need a new battery.
Jan 07, 2009 | Samsung V20 XVC 2400 Notebook
How Long to Charge??
sandisk recommends 3+ hours for the initial charge and then about 1.5 - 2 hours for after the battery is drained. More information is needed to diagnose this problem. but here is some info. After 45 minutes on the phone with sandisk to get them to send a new battery, they ran me through these troubleshooting steps, hope they help. do one at a time and see if you get a result -Reset device take out battery hold power button for 30 count put battery back in turn device on. -Upgrade firmware Go to website, download firmware update This was the URL at the time of writing this http://sandisk.com/Retail/Default.aspx?CatID=1376 or try http://sandisk.com/Retail/DriverDownloads.aspx Install according to instructions. let the device reboot. -Format memory. turn hold switch on, orange should be visible hold pause/play button and press power. click forward button when the screen comes up. let this run. after reboot flip the hold switch off. then they put me on hold for 10 minutes...
Aug 19, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Toshiba gigabeat S MP3 Player Logo
168 people viewed this question
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
James DuPont Jr
James DuPont Jr
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
