Question about Maytag MAT13MN Top Load Washer
The machine motor will not operate to agitate or spin
A daughter included a long scarf-like piece of material in the wash which apparently jammed the machine which was found by another daughter to be sitting idle in a mid-cycle and smelling to me of electrical/motor insulation.
How do I determine what is shot? If the motor is shot, how do I repair/replace it?
Thanks you and HAPPY NEW YEAR!
  • enecowind Dec 27, 2008
    Re: enecowind problem:
    For clarification, this concerns a Maytag Washer Model MAV6548AWW just 4 years old..
  • enecowind Dec 29, 2008
    Thanks. I am unfortunately not able to discern what or where on the diagrams "some rubber bush" may be or may be the cause. Since there are so many diagreams weach with so many parts, a specific diagram and circle part # ould be helpful.
    Again, thanks for trying!
    Problem Solver:
  • 18 Answers
Sir/madam.. click this link for detailed images of your machine.. likelihood is some rubber bush may have given way due to jamming.. but you can check and replace by these diagrams.. hope this is of help. parts are available here too. please be aware that if you require parts for your machine,they will require the machine serial number to correctly identify the exact part/s you would require
link here:-
http://www.easyapplianceparts.com/AdvancedModelSearch.aspx?ModelNum=MAV6548AWW&mfgModelNum=&fkMfgID=1
Posted on Dec 27, 2008
  • brightbear_4 Dec 29, 2008
    look in the base diagram for the motor... that is where you will find it and should be able to remove this by the diagram.it gives also the motor part number should you require it.. the transmission is where you will find the bearings/bushes if the motor checks out ok..click the appropriate diagram and enlarge the picture..
    you say the motor isnt working... then if it isnt working you have no means to check to see if this is ok... unless it has blown a fuse and no power is getting to it..so,either the motor is burnt out,or there is something jamming the motor preventing it from doing its job.some motors do have thermal overload protection and reset after a certain time if overheated.
    take out the agitator and see if the motor turns.. if not,then the likeliehood is the motor,to which you can see on the base diagram,and replace.
    if the motor rotates with power then the likeliehood is transmission failure, to which you would need to check the parts in the transmission diagram, and replace accordingly
    hope this is of more help to you
Motor start capacitor burned and melted......
capacitors fail for no apparent reasons
they can last for ever or just days
basically they are two separated plates that energize with positive and negative electrons that form an energy source when the plates are connected switched on but recharge when switched off as in an ac current
quality has little bearing in the issue and the materials used in the construction are varied but they still crack and the insulation ( grey/ black material ) melts out the failure
The have to be in the right capacitance area for the motor they control
there are pages on the net that may help you if you go google and type in -- capacitor construction, application and failures for electric motors --
Nov 14, 2015 | Whirlpool Washing Machines
How do I remove scarf that is caught in washing machine agitator
You can manually reverse the motor while tugging at the scarf as it has wound up on one direction. Gradually pull while the motor is moved and it must come out freely.
Feb 12, 2013 | Washing Machines
Agitator sounds as if it's stripped
The agitator and drive gearbox are all one part and are not serviceable (sealed), if it is the gearbox the machine is possibly scrap as the part is more expensive than a new machine. Will need further investigation.
Is the spin OK (quiet) the motor rotates one way to agitate and the other way in fast to spin, the belt may be removed at the middle pulley (Below) rotated in each direction to test. try the machine without the belt and listen to motor.
Nov 25, 2009 | Admiral AW22 Top Load Washer
GE WDSR2080D4WW top load washer agitator - Is there a cog type thing in the agitator that could be jammed & if so, how can the agitator be removed? I think whatever connects the agitator to the motor...
pull out the agitator. this may be difficult because soap gets built up underneath and250 acts almost like a glue. use a leather belt and put it under the agitator and pull straight up. once you get it off you will see a bolt holding down a coupling. take the bolt out and replace the coupling with a new one. this should solve your problem with the machine not agitating. the part # for the bell coupling is: WH43X10009.
Oct 24, 2009 | GE WBSR3140DW Top Load Washer
Motor just humm's when put on spin. Doen's seen to
Assuming that this is the basic Kenmore / Whirlpool top load, direct drive, neutral drain two piece agitator model.
There is a Sears repair parts site:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and a list of major sub-components will come up.
Since it isn't agitating (I assume not at all rather than just the top part of the agitator. If just the top part isn't turning then the easiest solution is replacing the 4 "agitator dogs" ) or spinning the solution points to a couple of places.
1. The motor coupler may be broken. This piece is a fail safe between the motor and transmission. and basically transmits power to the transmission.
Remove the cabinet and inspect the coupler. Following is a good description of how to replace it if necessary.
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The coupler consists of three pieces. Two plastic pieces with three prongs each that fit on the shafts of the motor and transmission and a rubber piece with six holes that the plastic prongs fit into.
If the prongs are broken off, or the rubber piece is broken, the motor cannot apply power to the transmission for agitating or spinning.
If the coupler is OK, the problem points to the motor or transmission.
If you move the timer to the spin cycle, and the machine drains the water , the motor is probably OK.
I'd also check the Lid Switch that prevents the motor from turning in the spin cycle.
Following is a Whirlpool PDf on how top load, direct drive washers work with a troubleshooting guide and description of how to bypass the LID Switch.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Oct 02, 2009 | Kenmore Washing Machines
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Scarf stuck around agitator.
remove cap and ,,remove 1/2 inch agitator screw and pull straight up
Aug 15, 2008 | Maytag Atlantis MAV6260AWW Top Load Washer
Maytag MAT13MN Top Load Washer Logo
103 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
