Question about Kenmore Washing Machines
Washing machine doesn't spin
Have Kenmore washing machine model 110.25842400 When it goes into the spin cycle it makes a clicking noise and doesn't spin. Guess it's direct drive, don't see any belts!
  • 15,935 Answers
This is NOT for older models equipped with a wig-wag transmission that are BELT driven. Read the instructions thoroughly BEFORE attempting. This is a repair of MODERATE difficulty that can be accomplished easily if you follow the steps provided:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
7. Remove the water pump. This is a small pump located in the front of the washer directly under the wash tub. It has two hoses leading to it. LEAVE THE DRAIN HOSES IN PLACE and remove the two retaining clips. The front of the clip pops off with a gentle pry of a screwdriver, while the back is in a keyed slot. Once released from the pump, turn the clip to remove from the slot. Pull the pump off the motor shaft and push it aside while leaving the hoses attached.
8. Remove the Drive Motor. Remove the electrical connection(s) first using care not to break any of the wires. Loosen the two 1/4" hex bolts that hold the Drive Motor retaining clips in place. Now, place one hand under the motor and lift gently while prying the top retaining clip with a screwdriver. This will release some of the tension on the clip and make it slightly easier to remove. (WARNING: the motor has some weight to it, so be prepared to support it when you release it). Once the top clip is released, the bottom one should come out fairly easy. The clips are similar to the ones that hold the water pump in place. They are inserted into a keyed slot and are slightly longer.
9. Once the Drive Motor has been removed, there is a Motor Coupling is directly behind it. There are two plastic three-pronged pieces with a rubber bushing connecting the two. One plastic piece is inserted on the Drive Motor shaft, while the other piece is inserted on the transmission shaft. NOTE: Inspect the motor coupling. If it shows signs of wear, this would be a good time to replace it.
10. Install the new Drive Motor. Make sure all the black rubber pads are on the motor (there are four of them). These help to reduce noise and vibration. Also, make sure the white cardboard piece that covers the bottom of the motor remains in place. This is a splash guard to prevent water from splashing into the motor in the event of a leak or overflow. Now, line up the motor coupling correctly and place the lower motor retaining clip in its keyed slot so that it is resting on the floor. That way, when you get the motor in place, you can reach down while holding the motor up and snap the lower bracket in. You will still need to support the weight of the motor until you get the top bracket keyed into its slot and snapped back into place.
11. Reinstall electrical connector to the Drive Motor.
12. Reinstall Water pump. You may have to rotate the motor shaft slightly to get the slot on the water pump to line up correctly. Make sure you re-install retaining clips.
13. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
14. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
15. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
16. Reinstall console.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
My kenmore model #110.42722200 washes but won't drain or go into spin cycle,it just makes a clicking noise.
this is caused by a faulty drain pump or broken lid switch tap the pump if it goes then replace it
Dec 26, 2015 | Kenmore Washing Machines
Kenmore 80 didn't drain during the spin cycle and leak underneath machine. Makes buzzing noise in the wash cycles.
The pump is likely damaged if it was leaking. Look for a ring of melted plastic on the face side of the pump. Check to make sure the hole is not rounded where the motor shaft enters the pump.
I'd replace the pump just to make sure the washer doesn't flood some time in the future even if the pump turn out to be ok now.
Vlad,
First Choice Appliance Service. Sacramento, CA
Jul 05, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My Kenmore washing machine, model number 26812690, won't agitate or spin. It goes through all the cycles but the tub doesn't move
if its a direct drive , make sure the brake is releasing for starters, If the spin basket has difficulty getting up to speed, you have a slipping clutch. You can determine this by slightly holding the spin basket when you select spin.A rapid spin up to speed shows a "good" clutch. other things to check for are a broken coupler, or any item trapped between the drum and housing, ( which is what happens most the time, )
Jul 09, 2011 | Kenmore Washing Machines
Making loud noises on spin cycle. The whole
i have this same model and mine does the same exact thing.
Dec 12, 2009 | Kenmore Washing Machines
Kenmore 90 series with speed selector switch set to heavy duty cycle it works fine any other setting , regular , hand wash setting the agitator makes a loud clicking sound as it agitates
sounds like a transmition problem. does the noise happen when it goes into spin on the other settings? If no noise in the spin cycle on the other setting, then it sounds like a the gears in the transmition internally when bad for the agitation.
Jul 30, 2009 | Kenmore 15864/15862 Top Load Washer
MY KENMORE ELITE MODEL 110.2497 WONT CYCLE TO WASH, SPIN OR RINSE CYCLE . WHEN I TURN IT ON IT FILLS BUT DOESNT CYCLE AN FURTHER, IT JUST MAKES THIS CLICKING NOISE....
hi..the reason to this problem is probably due to the
motor control board.
check this out..
thank you..
kindly rate my response..
Jul 20, 2009 | Kenmore Washing Machines
Model nbr 110-92580100 ser cd 3347297. wouldnt
your kenmore sounds like it lost the coupler do you feel ok opening the machine and inspecting the part?
the loud noise may be the coupler. I think your timer is working ok. because it goes through the cycle..
If you inspect it to be a bad coupler you can go here www.techray1.com and click on the link
let me know
Jun 14, 2009 | Kenmore 22422 Top Load Washer
Washer making noise during the spin cycle
Hi!!! it looks like your motor coupler is failing..Good luck..
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Spin cycle noise problems
It is likely that you have an unbalanced load. Try spinning the machine with only water in it. If there are no noises now, you will need to re-distribute the load. We clothes are heavy!!
Jan 13, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
87 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
