Question about Sub-Zero 690 Side by Side Refrigerator
Sub Zero 690 replaced lights but fan and lights dont work
I have removed the light pannel on the refrigerator side and have put new light bulbs in but the light still doesn't come on. Also the fan doesn't work. I am assuming that the problem is the switchs or something else.
How do you gain access to the switches, how do you replace them, what parts or is there a circut or fuse that needs to be replaced or reset
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
The fan will only run when the compressor is running. Check it a couple of times to see if it actually is not going on. There is alos a light terminator located behind the fan cover. We will assume it is the light switch. For the light switch go to http://subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code. This will take you to a locator to find the authorized parts distributor for your area I believe the part number for the light switch is 3060140 have them check it using your model and serial number. Once you have the part remove the three phillips head screws that hold the grill in place, this is assuming you don't have the louvered grill. You access these inside the fresh food and freezer compartments. With the door open you look up in to the metal you will be able to see them. Once you get the grill off there is a grey power cord with a white quick connect disconjnect this or turn the power off at the circuit breaker. You will be working on live electricity if you don't.Not good for your life expectancy. There is one more phillips head screw for the cover of the two switches. The light switch has a white back and the fan switch has a black one. Remove the two wires then push it down and slip the new one in. Replace all that you took off. While you have the grill off vacuum the condensor. If this is too much the link above also is for authorized service in your area.
Posted on Dec 27, 2008
The refrigerator lights do not come on when the door is open but the bulbs are fine. The fan does come on. What can I check to find the problem?
Sub-Zero units have a light and fan switch for each compartment... Check for continuity of the light switch when it is pressed and if it tests good, make sure the contacts in the bulb socket are making contact with the bulb... Be sure not to mix-up the light and fan switches as they operate opposite of each other...
May 27, 2016 | Sub-Zero 690 Side by Side Refrigerator
On sub zero 690 like to change bulb in lighted electronic control panel
you will have to remove the light shield, remove the plastic trim that says the model number in front of the light shield, then the 2 screws holding the side cover on the left side of the fridge section. Then the cover will need to be pushed towards the rear of the fridge then tipped out at the front. It has springs holding it in the back.That should access the bulb you need to change
Nov 07, 2013 | Sub-Zero 690 Side by Side Refrigerator
My sub zero 690 has the fridge & freezer light out as well as the screen
Well the most likely cause is 2 bad door switches, though I rarely see the door switch go bad in the freezer. At the top of the door openings you will see 2 switches in the freezer and the fridge. If you pull down the grille and remove the cover over those switches, the light switch will be the one with the white back, and the fan switch will be the one with the black back. I would try changing the switch in the fridge, and maybe start in the freezer by changing at least 1 bulb before blaming the switch. If that 1 new bulb doesn't light, change that switch too.
Mar 24, 2013 | Sub-Zero 690 Side by Side Refrigerator
Side by side Sub Zero light switch works intermittently.
I had the same problem with my sub-zero and finally resolved it (much to my wife's delight) by just replacing it. R&R was a lot simpler than having to work on it every time my wife had a problem.
Dec 14, 2011 | Sub-Zero 690 Side by Side Refrigerator
Light went out on refrigerator side
Your Sub-Zero unit contains standard 40 watt appliance bulbs in all compartments.
You'll need to remove the light shield in the top of the refrigerator or freezer to replace the bulbs. Place your hands under the light shield and release the two clips on the back of the light shield, then lift up and slide back slowly until the key slots on the side of the light shield drop past the mounting studs in the side walls. Then remove the shield.
The bulbs are now accessible.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Oct 27, 2011 | Sub-Zero 690 Side by Side Refrigerator
The light on the refrigerator side of my Sub Zero does not work
The light switch at the top of the door frame is bad. it controls all the lighting including the display for the board. you will have to remove the grille up top, remove the cover over the 2 switches, and replace the switch that is all white. the one with a black back is for the fan and rarely goes bad. Just unplug the unit or at least turn it off before changing this switch, as it is live any time the unit is turned on.
May 05, 2010 | Sub-Zero 690 Side by Side Refrigerator
Display will not come on in refrigerator. freezer light working not sure if cold but you can hear it running
2 posible problems. 1) light switch. open the fridge side in the upper part you have 2 switches one is for the lights the other one is for the fan. replacing a switch is really simple EASY an cheap. is the WHITE SWITCH. 2) light bulbs really simple too
Mar 29, 2010 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 690 Side by Side Refrigerator light switch intermittent
This is a common problem - replace the left light switch with Sub Zero Part # 3060140.
Nov 25, 2009 | Sub-Zero 690 Side by Side Refrigerator
Fridge side light is off. fridge works
check if your bulb is busted, have it replace
Nov 14, 2009 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 690 Side by Side Refrigerator Logo
512 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
