Question about Kenmore 24032\24036 Top Load Washer
Lid switch is bad and needs changing
I would like to know how to raise the top of my top loading Kenmore washing machine to gain access to the switch wiring to remove the switch. Its a Kenmore 110. 24622300 machine. The P/N of the switch is 3949238.
Any help would be greatly appreciated
  • rvh_iii Dec 29, 2008
    Your instructions were absolutely the only way I could have changed this switch. They were right on the money, except my switch wiring is white and grey with the green gd wire. Thank you ever so much. You saved me a $75.00 service call plus the part expense and it cost me the $32.00 for the part. Again thank you so much. FIXYA.COM is the only way to gop.
    Bob Hardisty Southlake, Texas
  • 640 Answers
Ready ok lets go...hi always unplug unit first,,facing unit take your hand and grasp corner caps on console,,on right and left corner,of console pull firmly and they will un snap..now remove the 2 phillips head screws..flip console back,,dont remove just flip back..now you will see the lid switch connection it has a gray and brow wire with the green ground,,pull apart,,,now there are 2 brass clips at each corner,,pry up with small screwdrivers from front of clips..pull cabnit towards you,,and leave machine..now on the cabnit theres 2 phillips head screws holding switch,,pull wire over 2 clip at recess in cabnit,,reverse to put together,,
Posted on Dec 28, 2008
  • onthethejob1
    onthethejob1 Dec 29, 2008
    thank you rvh,,anytime
My Kenmore 22712 Top load will agitate, but when it switches to the spin cycle I get nothing. The motor wont run and the tub doesn't spin.
open the lid a lttle and close it down a few times,if you don't hear a clicking sound when it closes you have a bad lid switch,or open the lid and stick a screw driver in the hole where the piece on the lid goes down into when the lid is closed, if it doesn't click and the machine doesn't run then the lid switch is bad.,they don't want the machine to run with the lid open when it goes into the spin cycle,if you send the full model number located beneath the lid when it's open on the back panel under the lid.let me know how you make out
Jan 13, 2011 | Kenmore Washing Machines
How can i change top load door switch?
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
It sounds as if your lid switch is jammed or broken.
Go to the section on the Sears site for the Top and Cabinet parts and you should see the Lid Switch.
See the following for how to release the console and remove the cabinet to gain access to the Lid Switch.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Feb 20, 2010 | Kenmore 22422 Top Load Washer
LS error
The machine control detected that the lid switch is not functioning properly. Raise the top part of the washer to gain access to the lid switch.
Disconnect the machine from the power source. Gently pry the emblem from the front of the machine and remove the T20 torx screw hidden behind it. Slide the top of the washer forward and raise its front. Prop it up high enough to allow easy access to the lid switch.
The lid switch is activated by an actuator (part number 19119) mounted on a hinge. It will not work properly if the actuator is damaged.
Check the operation of the lid switch using a multimeter. Disconnect the lid switch wiring harness and connect the test leads of the multimeter (set to X1 or ohm) to the terminals of the lid switch and activate it. The multimeter should read zero ohms while the lid switch is activated and open when deactivated.
Replace the lid switch if it is broken or if it fails the test above. Remove the lid switch mounting screw and install the new lid switch. Reconnect the wiring harness and slide the top of the washer back into position. Reinstall the T20 torx screw and the emblem.
Feb 11, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Wahser wont run spin cycle.
Door switch is probably bad or connection is loose. Remove the top cover to gain access to the switch.
David Le
Apr 21, 2009 | Kenmore 22422 Top Load Washer
I have a kenmore 111 series. the top of the agitator is not working like it should. It does not move. Help
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Mar 22, 2009 | Kenmore 22422 Top Load Washer
Need to replace lid switch
what brand machine? whirlpool take off the cabinet and the switch is on the rhs under the lip
Jan 30, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Replacing lid switch
me too...exact same washer and same problem...how do u fix it?
Apr 20, 2008 | Washing Machines
Replace lid switch kenmore mod# 110.29902200
remove the two screws in the top of the console they will be in the rear left anmd right side
then flip up the console and remove the 2 spring clips and the lid switch molex plug the cabniet will come off tilt forward and pull out you will see the lid switch running on the underside
Mar 03, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series
I am assuming there is no noise coming from the machine, if not check the lid switch. open the lid and look for a small slot in the top of the washer. With the washer set to run, press down on the slot with a screwdriver or something (make sure everything is clear from the tub) see if there is a clicking sound when you push down. If the machine starts you need a depressor piece on the door. if there is no clicking sound you may need something else. lets start with the simplest, like the door switch and go from there.
Nov 02, 2007 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
201 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
