Question about KitchenAid KBRS36FK Bottom Freezer Refrigerator
Kitchen aid KSRG25FTBL ice maker not working
The icemaker in my kitchenaid KSRG25FTBL side by side refrigerator is not working. No water is being dispensed into the icemaker. I checked to make sure the red on light does not blink when the panel on the other side is depressed (when freezer door is shut). This is the second time it has not worked. The first time it did not work, the water inlet hose at top of icemaker was frozen, broke the ice loose, closed the freezer door and heard water being dispensed. Now nothing. what should I check on the icemaker.
  • sylcore Aug 25, 2008
    Unable to make ice cubes in my bottom freezer refrigerator after it was disconnected for five months. Filter replaced. No indication from warning lights that there is a malfunction.
3 Suggested Answers
SOURCE: Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Posted on Sep 16, 2008
  • 9 Answers
SOURCE: Freezer and icemaker freezes, jams.
I have run into this before and found it very helpful to re-level the refrigerator. By leaning the fridge back toward the wall about an inch helped keep the water and ice in the tray. Remember to remove items that block air flow in the freezer. Remove the ice bin and clean it then start over with the fridge leaning back a little. Hope this helps.
Posted on May 01, 2009
Water, but "no ice" in my Kitchen Aid
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 28, 2011 | KitchenAid KSCS25FKSS Side by Side...
Kitchen aid icemaker won't dump
Sounds to me that you need parts or as most Whirlpool/Kitchenais Ice Makers their averagte life is 5 years. Call before purchace to confirm but here is what I have for the complete Ice Maker=> 4317943 Ice Maker Assembly
For much more info click here=> Broken Ice Maker Repair
I will be here if you have any other questions, Thanks, Sea Breeze
utube.png You-Tube video "VCUgA5T5ASw&feature=player_embedded#!" placeholder
Sep 18, 2011 | KitchenAid KSCS25FKSS Side by Side...
I turned my water off when we left town for a month. After turning my water back on the ice maker has stopped working. Our refrigerator is a Kitchen-aid superba model and is approximately 4 - 5 years...
The issue is likely that the icemaker fill tube is frozen due to poor water pressure. You can use a turkey baster to thaw this tube which fills the icemaker. Make sure you use plenty of hot water because they often freeze back several inches!
Sep 11, 2010 | KitchenAid KSCS25FKSS Side by Side...
May 01, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Ice maker in my Kitchen Aid side by side is not getting water
there is only 2 things that would cause this. either the icemaker is bad and not calling for water or the fill valve that allows the water to come into the icemaker is bad. how old is the fridge ? also check the ice maker and make sure it has not accidently been cut off inside. if this is the old type theres a bar that raises and lowers. make sure the bar is down. in the up position this would turn your icemaker off
Mar 31, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not filling with water
I have a model KSRG25F and found that the solenoid that controls the water to the icemaker was not working. I tested by switching the water dispenser connection to the ice maker coil.
And then had the wife push the water fill in front of the fridge. I had aready changed out the control board in front because I didnt have the flash codes or solid led when simulating door closed. the parts is about $55 and hope that does it. Good Luck
Jun 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Aug 02, 2007 | KitchenAid KSCS25FKSS Side by Side...
KitchenAid KBRS36FK Bottom Freezer Refrigerator Logo
55 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
