Question about Western Digital 160GB MyBook Essential Edition 160 GB USB 2.0 Hard Drive
No driver installed for the device
I have had a MyBook Essential for about a year and have had no problems with anything. Suddenly computers it try to plug it into cannot recognize the hardware. The Device Properties dialogue says that there are "no drivers installed for the device." I've never had to install anything to get the hardware to work, and I'm not sure how to fix the problem.
    Problem Solver:
  • 56 Answers
Download testdisk and run to see if a boot sector can be ressurected
Posted on Oct 11, 2017
SOURCE: Mybook essential
Hi guys...
I had kind of the same problem like u...when i plugged it into the usb all i got was a "unknown usb device found"
I opened the external case hoping the hdd was still ok only to find out that the hdd cables had been moved slightly out of position..propably from a fall or a knock I didn't even noticed..
I just pressed them back in..click..and everything was back to normal..
These sites have info about how to open the external case..
http://rebootdaily.blogspot.com/2007/03/how-to-open-western-digital-my-book.html
http://anotherdeadblog.blogspot.com/2007/09/how-to-open-western-digital-my-book.html
Hope that helps!
Posted on Dec 10, 2007
Ynnoj
  • 4 Answers
SOURCE: WD My Book Essential Edition Unidentified Device
Well this has happend to my before thogh with another device. What I had to do in the end was hook it up to another computer I had never ran it on before, back up the device then reformat it. This should work.
If it does not or this first option is unavalible to you there is some thing else you can try. Go into the program files and find where your driver softwear is located. First back the files up on a flash drive or cd (just in case), then delete all files(this is why to back them up). Restart your computer wait for it to fully load then trypluging in your device again.
These have served me well in the past hope it helps.
Posted on Feb 25, 2009
efs_perpends
  • 1996 Answers
SOURCE: Computer doesn't recognize WD MyBook 500GB but no error message
Try using the western digital knowledge base info to help you resolve the problem...click here.
Otherwise, we need the full model # and the OS you're using to give better solutions....
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 24, 2009
bob_computer
  • 3153 Answers
SOURCE: MyBook doesn't show up in My Computer..
I devised these simple steps that tend to remedy quite a few issues with most portable / external hard drives (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply
Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again.
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select Computer Management.
Now select Disk Management and expand the window.
Your drive should be listed here, if not then you need to check your computer hardware has not got any issues before proceeding.
If your drive is listed and says healthy then right click on it an select Properties, click Tools and then Error Checking, Check now, tick the two boxes and then Start.
This will attempt to fix most minor / common errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed but did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. When it is done restart your computer and you should be good to go.
If you still have problems with the drive you might want to look at other areas.
Posted on Aug 23, 2009
Testimonial: "That was great thanks. Unfortunately I discovered that there was a hardware malfunction within the external device itself. But thanks for the help!"
marked
  • 6487 Answers
SOURCE: Our computer has stopped recognizing
Base from the description of your problem this issue has something to do with the actual hard drive , but we can also try some things here.
First connect the drive on different USB port on your computer if possible try to connect it on different computer and see if it will be recognized.
But if still not being recognize try a different USB cable because sometimes the problem can be with the cable.
After doing those and still same problem the external drive needs servicing for you to be able to retrieve the data and the drive itself , you can take it to a service center or send it back to Western Digital.
Posted on Sep 14, 2010
Change mybook from one pc to another
You have to install the backup software on the new computer. Either download from WD to use what came with the MyBook. Attach the MyBook and find it in My Computer. If it is not there, you have to reboot and find the attached device. After Windows recognized the drive, the backup software will ask you for a new backup but just decline and reactivate the plan (actions/reactivate). That should do it!
Dec 05, 2011 | Western Digital My Book Essential Edition...
I have bought a WD My Book Essential and I want to install it. My OPS is Windows 7. Drivers software installation (the PC saids OK) " Yours device is ready for use" USB mass storage device...
You have to expand the "Disk Drives" device manager entry to see your MyBook Essential external drive.
These drives are formatted at the factory, and you should also be able to see it in Windows Explorer. It will automatically be assigned an unused drive letter, and accessible immediately.
Oct 08, 2017 | Dell Computers & Internet
Windows XP/My Book Essential 1 TB Recognition Problems
Fact is, unfortunately they're right - you shouldn't need any special driver for the MyBook, it's basic USB storage and XP should be able to use it without problems.
Apparently Windows is recognizing it as something else. Try booting in Safe Mode and checking hardware devices, uninstalling any Western Digital related stuff. Then, reboot the PC and power up the unconnected MyBook and wait a couple of minutes for it to stabilize, then connect it.
Check it also on another PC, just to be sure it does work.
Oct 27, 2009 | Western Digital My Book Essential 1TB...
Mac won't acknowledge Mybook!
try restarting your computer with the mybook plugged into it. also, leave it plugged in for a while and check back to see if it shows up on the desktop. I had a similar problem with my hard drive too, and this seemed to work.
Jul 21, 2009 | Western Digital My Book Home Edition 500...
My Western digital 1tb wont work inspite of drivers being instal
Mybook does not require any additional driver to work on systems from Win XP onward, same for recents Linux and MAC OS.
If the drive is not detected on more of one computer, then it is usually because of a fault.
Try a replacement cable (mybook uses Mini USB to USB, available at computer and at camera shops). If still no luck contact WD, mybooks have one year warranty. If you want to recover data, the disk must be mounted on a different enclosure, that service can be asked when discussing repair.
Regards
Jul 12, 2009 | Western Digital My Book Essential 1TB...
Mac not Reconize my MyBook
load the driver for mac use, the external hard drive comes with cd, the mac driver should be inside, load it to your mac computer. if you donot have the cd go online to western digital and download it. just load the driver and u will be fine, make sure u connect the cable in right places.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 09, 2009 | Western Digital My Book Essential Edition...
Feb 24, 2009 | Western Digital My Book Essential Edition...
Connection problems with my Western Digital MyBook EE 2.0 320 GB.
Go to Programs and Devices and see if your Western Digital MyBook is even listed on your computer.
Jun 28, 2017 | Western Digital My Book Essential Edition...
WD My Book Essential -- Can't find drivers
It should not really need drivers in Win2K or Vista, you might have a problem with your USB drivers. Go into device manager, remove any devices under the USB heading and reboot. All the drivers should reinstall and hopefully your MyBook will come alive again. Otherwise, try the MyBook on a friend's computer, if it doesn't work there then the MyBook may be faulty itself.
Jan 15, 2008 | Western Digital My Book Essential Edition...
Mybook failure, now failing as internal
Dude you can still read the drive in Windows. The drive is formatted in Fat16. The partition you are talking about is only to get the USB to recognize the FAT16. Just a boot loader for the device. The problem is the voltage regulator. They are only using a 1 amp that should be a 2 amp. The harddrive has some current draw. When the drive starts flashing it just overloaded the power supply and cant be read by Windows. Simply remove the drive plug it in a IDE interface on the computer and you should be ready to go. You could also replace the voltage regulator with a higher current model, but you must be an expert in soldering SMT......
Jan 04, 2008 | Western Digital My Book Essential Edition...
Western Digital 160GB MyBook Essential Edition 160 GB USB 2.0 Hard Drive Logo
184 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
