Question about Teac PD-H300 CD Player
Cd drawer will not open
If there is no cd in the tray /tray will not open unless you tap the side
if you leave a cd in it/ it will open every time
  • Anonymous May 04, 2009
    I have the same problem with a PD-H200.
    My workaround is to always leave a dummy cd, one of those that come at the botton of a spindle of cd-rw's or dvd's. When I want to play a disk I remove the dummy, and I put it back when I end listening.
    The cause: the belt from tray motor to the tray mechanism skips, and it does not worth the while to try to replace it, you risk to broke the tray. This problem also happens in other Teac components, I suppose the belts degrade with time and temperature (warmer more skipping problems).
2 Suggested Answers
  • 274 Answers
SOURCE: CD drawer will not open
Try manually opening the drawer. There's a little hole on the front, Insert a pin or bent paper clip in the hole with the machine "on". Should open for you.
Posted on Jul 16, 2007
Sharp CD-BA2100 cd drawer won't turn or close.
Take the 4 screws out of the top, lift the CD drawer out, disconnect the two wire harnesses, take the top off, lift the 3 disc tray out, then force the drawer open and closed a few times until it slides freely. Put it back together and it may or may not work. Worked for me.
Mar 28, 2013 | Sharp CD-BA2100 CD Shelf System
Problem with the Konica Minolta bizhub C450P Laser Printer Bizhub C450 error (C-0212) , HOW TO FIX IT?? PLEASE GIVE ME THE FIX STEP!! TKS!!!!!
This code is for LCT (Large Capacity Tray) lock release failure. This means there is a problem with the LCT, usually the large paper drawer at the bottom. This code is usually reset by opening then closing the front door. Sometimes turning off then on the main power switch on the right side will clear it. Try releasing the LCT and get it open. Then check the paper in the tray. Most of the time when there are problems with these LCT's it is because too much paper has been loaded or it has been loaded improperly. If you get it open, remove all paper. Then load smaller amounts of paper at a time to insure that it is loaded perfectly. Only load the tray half full at first and then close the drawer and allow it to lift. Then make a copy from that drawer to be sure it feeds paper. Then release the drawer again and finish loading if you want. If you continue to have the code then you can leave the drawer open an inch or so to de-activate it so you can still use the printer from the other drawers until you can get a technician out ot service it.
Good Luck and Thank You for using Fixya.
Wheatland Services
Feb 16, 2011 | Konica Minolta bizhub C450P Laser Printer
Dell dimension 2400 cd drawer opens up when
The latch which holds the CD tray in place once the drawer retracts must be faulty. You will need to take it to a repair shop in order to have it fixed, unless you are comfortable with pulling apart the computer shell in order to test the latch to see if it is functional.
If you are not a professional, I would suggest taking it to your local computer repair store for service. They will be able to assess if that is the issue you are having.
Jan 06, 2010 | Dell Dimension 2400 PC Desktop
Unable to open DVD drawer
If you take a paper clip and straighten it, there is a little hole in the front of the CD drive, push the paper clip into it and your CD drive will get pushed open. This will get a CD out, but will not fix it.
Try re-seating, or connecting a different power cable to the back of the CD drive. Does your PC even recognize that the CD drive is present?
Most of the time the CD drive needs to be replaced.... they are very cheap.
Sep 09, 2009 | Dell Dimension 8250 PC Desktop
Dredge drawer full and it is empty
Hi
One thing you want to make sure you do is leave the machine on when you remove the drege drawer other wise the machine doesn't know that you emptied it. Remove the drip tray and pull the empty drawer out about half way and leave out for 15 seconds. Then push the drawer back in from the right front side with 1 finger. That way you make sure that you engage the switches in the machine. If you slam the drawer in you can pull it away from the switch and it will say drege drawer missing. If you put the drip tray back in, it can sometimes lift the drege drawer and disengage the switch. There is a notch in the right side of the drip tray that has a flashing on the back side of it. You can remove about an 1" of the right side of the flashing and it will stop the lifting of the drege drawer. Remember to leave the machine on when you empty the drege drawer other wise it doesn't know.
Jul 17, 2009 | Saeco Royal Professional Espresso Machine
Internal CD ROM will Not Open
Unless you can do electronic repair yourself and have the schematics for the drive it will be far cheaper and easier for you to simply replace it. Any DVD drive for computers will fit in there. I would buy a new one rather than used so you make sure and get the software with it. Replacing the drive is a 30 minute job at most.
Dec 31, 2008 | Sony DVD-ROM DDU1615-ZB 16X IDE 512KB 100...
I can't open the tray on the recorder side.
I had similar problem with both drawers. The belt from the drive motor to the drawer pulley is worn. mcmelectronics.com has two belts 42-1050, 42-045 that are close enough in size to work. Remove cover, press down on tray, slide tray forward about half way and you will see the worn belt. Total cost of fix is about $12.
Dec 16, 2008 | Harman Kardon CDR30 2-Disc CD Recorder
TDK DA 3826 disc tray not functioning
Is the motor spinning to try to open the drawer?Can you hear it? Can you get something under the tray edge to try to 'help' it out when pressing eject?
Jan 05, 2008 | TDK DA-3826 2-Disc CD Recorder
Tray Opens and Closes Repeatedly After Disc Jam
check to see if tray is out of alignmnet ..also check to see if 5 or 7 pin flat ribbon cable form servo drive board to tray got dislodged from connector or is bent,cut etc...
Dec 03, 2007 | Sony DVP-NC650V Multi-disc DVD Player
Teac PD-H300 CD Player Logo
111 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
