Unable to connect to the internet, I have a connection from my dsl but cannot connect
    Champion:
  • 209 Answers
Check your network connection, does this appears limited or no connectivity? try to disable and enable or you may restart your computer. this is the common problems for those having a dynamic ip address specially if you have 2 or more computers connected in your router. you might be having an ip address conflict. in order to eliminate the repetition of this kind of problem, you need to switch-on first your modem/router wait for all the LEDS lighted prior from switching-on your computer.
Posted on Dec 29, 2008
No interent connection
Your Linksys wireless router needs to be connected to a DSL or cable modem which needs to configured with the settings that your Internet Service Provider gave you.
To test your Internet connection connect a LAN cable fron your conputer to the DSL/cable modem. If you cannot connect to the Internet using this methos, you need to contact your ISP and the can check the connection to your DSL/cable modem.
Apr 12, 2012 | Linksys Computers & Internet
I have configured my d link router and able to connect it with my win xp laptop and after i connect internet cable to the wireless router i am unable to access the internet through my win xp and win 7...
If initially the Win XP laptop was connected to internet at the cable/dsl modem, its MAC address would have been registered on service setup. If the router is now in place between the Win XP laptop and the cable/dsl modem, you would need to go on the Win XP laptop and log into the router as admin to clone the Win XP laptop's MAC address to the dlink router's WAN interface (internet facing side) so that the cable/dsl modem will see the previously registered MAC address and will enable the internet access.
Mar 23, 2011 | IBM Computers & Internet
We have 2 desktop pc's. One in one room and the other in another room on the far side of the house. Both are connected to the same telephone line. The 2wire homeportal 100 hg died and I went to Radio Shack...
well in a hard spot if your using dialup as means of connecting to the internet then only one PC at a time can use dialup connections now if say it was a DSL modem then from the DSL modem or DSL Router Modem you would need RJ-45 cables from the DSL router modem to the two PCs
Apr 22, 2017 | 2wire HomePortal 1000HG DSL Modem and...
Unable to connect internet
hi,
theres a possiblity that the modem is set to bridge mode,in that way,you will not be able to connect to the internet direclty to the modem,192.168.1.1 is usually the deault gatewayy address for almost all verizon modem and username is admin and password is admin as well,if admin didnt take for the password,try using password as the password
thanks and God Bless
Dec 10, 2008 | Toshiba WRC 1000 Wireless...
Modem settings for Siemens SL2_141
First of all check whether dsl yellow light is on or not.
if it is not on then contact bsnl local branch.
otherwise
remove dsl line from modem.
Then
open internet explorer
type http://192.168.1.1
username= admin
password= admin
click WAN
edit pppoe 0_35_1
connection type=bridging
encapusulating =LLC/Snap-bridge
next
again next
save
save/reboot
close IExplorer
connect DSL line.
if its work plz reply me
findme_rohit@yahoo.co.in
Sep 14, 2008 | Computers & Internet
RE: DSL 302G WINDOWS VISTA
Try the following forum - it works!
http://forums.whirlpool.net.au/forum-replies.cfm?t=716454#r2
Jan 28, 2008 | D-Link DSL 302G (DSL-302G) Modem
D-Link DSL-2640
First I will need to know the type of ISP service you have, T1 - DSL - ADSL - CABLE - etc. And the connection type, STATIC IP - DYNAMIC IP - PPPOE - etc. BPCS
Dec 11, 2007 | D-Link ADSL2/2+ Modem/Wireless Router...
Problem with belkin router
assuming you are connecting wirelessly; you may have to check that the router is allocating ip addresses automatically to your pc's. connect one of your pc's to the router via the RJ45 network cable that was supplied and not wirelessly and type 192.168.2.1 in your internet browser, this will take you into the routers setup menu. Look for a menu refering to 'DHCP' and make sure that this is enabled, then look for the channel number that the router is using (normally 6 or 11) and make a note as if you are still experiencing signal loss, you can get back into the router and change to any channel between these numbers incase you are getting appliances interfering with the signal, save and exit from the router menu. disconnect the cable then go to control panel, network connections and right click on the connection you are using whether it is wired or wireles and click on properties. Look for the line TCP/IP and again click on the line and select properties, then make sure automatically obtain ip address is selected, ok and close window. Restart the pc's and you should have a connection.
Jul 08, 2007 | Belkin (F6D3230-4) Router (F6D32304)
DSL/dialing connection?
No, the router will do the connection for you. All you will need to do is open up your Internet browser and you will be able to connect to the Internet without having to use the connection icon from your DSL provider. If you are still unable to browse the Internet but the Router screen does say it is connected try restarting the computer.
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
DSL
Feb 16, 2006 | Belkin (F5D5230-4) Router
Computers & Internet Logo
35 people viewed this question
Alun Cox
David Payne
David Payne
