RCA D52W27D The Three Blinks of Death
Hello Willtab,
I have a RCA HDTV Model D52W27D. Similar to others' problems, the front light will light up and turnoff three times. However, twice now it has come back to life. It still blinks three times, but comes on after the third. This morning it did the three blinks of death so I gave it a minute and then tried pressing the DVD power button and it came on.
When the TV finally comes on, the picture and sound are fine.
I opened the DVD and removed the disk that was in it thinking that may have something to do with the problem.
Also, before the three blinks of death started, I noticed that at powering on, the TV was not starting on the channel I was watching the night before, but on channel 2.
I hope I've given you useful information to help me fix this problem.
Star Smith
Somerset, KY
star0200_2000@yahoo.com RCA HDTV D52W27D start problem - The green light blinks three times ,but my set does not start at all. I need to know what to do next. Can anyone help? Need to know if it is something I can fix or should I call a repairman? Is this an expensive fix? Please let me know.
Thank you ... Jeanne
  • babiegurrll Mar 13, 2009
    Over the past few days my T.V., the same as all of your models, would take a few minutes after you pushed the button for the screen to come on. When it finally came on it would be on channel2, not three and theinput mode would be switched away from my cable input. This morning I tried to turn the T.V. on and the light came on and went out 3 times, it sounded like it was trying to start, but nothing.
RCA MODEL D61130 Three green blinks of death fix
Should be a damaged component at its horizontal output section circuit. Might be its horizontal output transistor. Replace it and check. Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and five hundred posts. All are related to television and other domestic electronic equipment service help.
May 20, 2013 | RCA Televison & Video
RCA tv/dvd combo model # D52W27D. I am having similar problems with the front green light blinking 3 times but mine doesnt come on. I cannot open my dvd player or anything. It sounds like it trying to come...
Sounds like your power board has issues and needs repairing or replacing, if your tech savvy you can repair it but it might make more sense to order a new one, this board is known for issues in tvs like you have
Feb 09, 2018 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD56WW66 green light blinks three times then nothing
install the RCA repair kit called the CP50, CP120 and CP114 repair kit from www.tvrepairworld.com the kit also contains the instructions on Cd
Apr 14, 2010 | RCA HD56W66 56" HDTV
My tv will not turn on
CK for Bad capacitors on your Deflection Board its the bottom board on left hand side cp150 cp114 cp120/ if (cp150)- 2200uf 16v is puffed up on top It is Bad replace all 3 capacitors 220uf 35v is the other 2.
Jan 02, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
POWER WILL NOT COME ON. BLINKS 3 TIMES WHENEVER I TRY.
Look at the upper left hand corner of the main board for two bad electrolytic capacitors. They will have a bulged top if bad.
- Dan
Apr 28, 2009 | Televison & Video
I have a model number D52W27D big screen hdtv will not power on tries three times then shuts off. Also if i push and hold power button, it flashes 9 times. How can it be fixed.
your set is going into shutdown for some undeterined reson the processor has detected a fault in one of about 25 cuircits. are you a tech. As a tech there are few thing i check. there is a special computer interface we use that reads error codes from the processor. but the only thing you can try is to unplug the set and try again in 30 minutes. in general common problems include what is known as the horizontal output transistor, flyback, but this involves troubleshooting it down
Apr 04, 2009 | RCA HD52W59 HDTV Projection Television
Tv's green light comes on then off three times
Check capacitors cp150 ,114, 120 ,if cp150 is puffed up on top it is bad.2200uf 16v and the other 2 are 220uf 35v.
Feb 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD R56WH78 projection TV, picture just got ascew,
You are haveing form the sounds of it convergence problems. I see this all the time on this set at the shop. FIrst question in customer menu under setup do you have the convergence option if not consult the tips and tricks section under fl231 problem. if you do have this you may have other troubles the convergence is controled by three seprate boards.
Nov 08, 2008 | RCA HD52W56 52" Rear Projection HDTV
Check 3 capacitors on deflection board cp150,cp111,cp114 most of the time this is the problem 2200uf16v /330 uf 35v /220uf 35v.
Oct 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
319 people viewed this question
Top Televison & Video Experts
