Question about GE Nautilus 24" Built-in Dishwasher
TOP RACK WILL NOT GET CLEAN
THE BOTTOM RACK DISHES WILL GET CLEAN BUT THE TOP RACK WILL NOT
  • 1 more comment
  • Anonymous Dec 31, 2008
    My dishwasher does not clean the top rack. I tried cleaning the back filter and even used expensive dishwasher detergent.
  • michigancana Jan 05, 2009
    Top rack cups will not come clean, plus leaves residue. Has improved a little since I found the drain pipe kinked, but still does not was very clean on top rack. Bottom rack washes well.
  • Anonymous Mar 12, 2014
    I have a GSD2200 series Dishwasher. I've replaced the water in let valve, but the top rack is still not getting clean.
Look in the owners manual on how to clean the food particle grate on the pump.....
Posted on Dec 28, 2008
Why doesn't the top rack of my dishwasher clean dishes?
the water tube may be clogged at the sprayer on the top of the basin. probably have to disassemble and clean
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Apr 14, 2016 | GE Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
The top rack is not cleaning. The dishes on the bottom rack come out clean but the ones on the top rack don't look like they have even seen water?
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it
Oct 19, 2010 | KitchenAid 24 in. KUDS02SRSS Stainless...
My dishwasher wont clean the dishes. The bottom rack gets kinda clean and the dishes on the top rack come out dirty and covered in film.
Check whether the top rack spray arm main hose sits firmly into the
machine. If there is a leak in this area water pressure may not develop.
Also check the water pump in the machine!
Oct 01, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
My whisper quiet dishwasher is not cleaning the top rack dishes
I'm having the same problem. Did some testing and found that the sprayer on the top rack is not even moving and hence not getting any water. Not sure what to do.
Sep 07, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Our GE Potscrubber 640 isn't cleaning the top rack items. They are neither cleaned nor rinsed. Does it have something to do with the "Rinse Dispenser" knob on the door? It's always been fully screwed in.
likely not .....the problem may be how you stack the dishes ....try doing a load with nothing on the bottom rack ....if the top rack items come clean then you may be stoping the water from reaching the top rack with the dishes on the bottom rack ....it's important to keep the center of the bottom rack free this is where the water comes from (on most models). to clean your upper rack .....have a close look at the inside of the machine to try and figure out where the water comes from ...it helps a lot to understand this ....good luck
Jul 25, 2009 | Dishwashers
Kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Nov 25, 2008 | Dishwashers
Dishes not clean in bottom rack of Whirlpool Quiet Partner I (du1048xtps4)
check to make sure your lower spray arm openings are not blocked.
Nov 07, 2008 | Dishwashers
GE Nautilus 24" Built-in Dishwasher Logo
390 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Steve Allison
Steve Allison
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
