Question about HP Pavilion zd8000 Notebook
Need to find out how to restore to factory settings on HP Pavlion z8000
  • brett_telfor Mar 29, 2009
    how do I reset to factory settings on a pavillion zd8000
HP PAVLION DISPLAY PROBLEM
yes , that NVIDA Issue , you have to refllow VGA chip-set
Mar 20, 2013 | HP Office Equipment & Supplies
Need too restore to factory
The HP Mini laptop comes with either the Windows 7 or Windows Vista operating system.
You can restore the HP Mini to its factory settings using the laptop's recovery partition.
Restoring the HP Mini to its original factory settings will get rid of hard to eliminate viruses on the laptop's hard drive.
A factory restoration is also a good way to get rid of older files still stored on the computer that you no longer need and start with a clean slate.
Windows Vista
Click "Start" in the lower-left corner of your HP Mini Windows Vista home screen, then type "Recovery" into the Search box at the bottom of the Start menu. Click "Recovery Manager" in the list of options that appears above the Search box. The HP Recovery Manager will open. Click "Advanced Options" and then "System Recovery." Click "Next." Your HP Mini will restart. The HP Recovery Manager will open up automatically after the restart is complete. Click "System Recovery," and then click "Next." Click "No" if a message pops up on your screen asking if you want to use Microsoft System Restore. Select "Recover without backing up your files," and then click "Next." The restoration process begins. This could take between 30 and 90 minutes, depending on the of your hard drive and how much information you have stored on it. The HP Mini will restart when the laptop has been restored to its original factory settings, and you will be prompted to set up Windows Vista. Windows 7
Click the "Start" icon in the lower-left corner of your HP Mini Windows 7 home screen. Click "All Programs" and then click "Recovery Manager." Click "Recovery Manager" again to open the HP Recovery Manager program. Click "System Recovery" from the list of options beneath the "I need help immediately" section on the left side of the program. The HP Mini will automatically restart and open the HP Recovery Manager. Click "System Restore," and then click "Next." Click "No" if a message pops up on your screen asking if you want to use Microsoft System Restore. Select "Recover without backing up your files," and then click "Next." The restoration process could take between 30 and 90 minutes, depending on the of your hard drive and how much information you have stored on it. The HP Mini will restart when the laptop has been restored to its original factory settings, and you will be prompted to set up Windows Vista.
b>
Feb 04, 2013 | HEWLETT-PACKARD HP Mini 5101 Netbook
Reset factory settings on hp deskjet 1050
Reset the Printer to Factory Default Settings Restore factory settings Restoring the factory-set defaults returns most of the settings to the factory defaults. It will not reset the page count, tray size, or language. To restore the product to the factory-default settings, follow these steps.
  1. Turn the product off. Disconnect the power cable from the product for 30 seconds and then reconnect.
  2. Turn the product on while you press and hold the Resume c02469297.gif button for 10-20 seconds. The Attention c02469293.gif light turns on.
  3. Release the Resume c02469297.gif button. The Attention c02469293.gif and Ready c02469296.gif lights cycle while the product restores factory defaults.
Reset HP 1050 DeskJet Series Cartridge
Jun 07, 2012 | HP Office Equipment & Supplies
Reset hp 1515n
? Restore defaults-used to reset all customer-accessible menu settings back to the factory default
settings (except language) via the control panel or software
NOTE: This service menu item does not reset factory-settable settings, including formatter
number, page counts, factory paper settings, language, and so on.
NOTE: Before restoring defaults, print a menu structure report and a configuration page. Use the
information on these pages to reset customer-specific settings.
CAUTION: All HP Jetdirect settings are also reset. Be sure to print a configuration page before
restoring defaults. Make note of the IP address that is listed on the Jetdirect configuration page. You might need to restore the IP address after performing a cold reset.
Restore the factory-set defaults on the (HP Color LaserJet CP1510 Series Printer
1. Press OK to open the menus.
2. Use the Left arrow or the Right arrow button to select Service, and then press OK (Select).
3. Use the Left arrow or the Right arrow button to select Restore defaults, and then press OK.
The product automatically restarts.
Jul 13, 2011 | HP LaserJet CP1515n Printer
How to restore HP Mini 5103 to factory settings?
Restoring the HP Mini to its original factory settings:
1. Click the "Start" icon in the lower-left corner of your HP Mini Windows 7 home screen. Click "All Programs" and then click "Recovery Manager."
2. Click "Recovery Manager" again to open the HP Recovery Manager program.
3. Click "System Recovery" from the list of options beneath the "I need help immediately" section on the left side of the program. The HP Mini will automatically restart and open the HP Recovery Manager.
4. Click "System Restore," and then click "Next." Click "No" if a message pops up on your screen asking if you want to use Microsoft System Restore.
5. Select "Recover without backing up your files," and then click "Next." The restoration process could take between 30 and 90 minutes, depending on the size of your hard drive and how much information you have stored on it. The HP Mini will restart when the laptop has been restored to its original factory settings, and you will be prompted to set up Windows.
Jun 25, 2011 | HEWLETT-PACKARD MINI 5103 Netbook
I need to restore my HP mini 210 to factory settings
try pressing f11 on boot up to see if you have a recovery manager insalled
Feb 20, 2010 | Computers & Internet
How can I restore to factory settings
Compaq/HP: When you first turn on the laptop and see the Compaq/HP logo screen, press the F11 key (you need to do this before the Compaq/HP logo disappears).
pls rate well
May 07, 2009 | HP Compaq Presario V2000 Notebook
Format/restore computer to factory settings
Press F11 at system startup to get to the NEC recovery menu. From there, you can restore your factory settings. However, a "destructive" recovery will wipe the hard drive, including your personal files. Best to back those up first before performing the recovery.
Hope this helps - remember to rate :)
Oct 02, 2008 | HP 419320-001 - HP Pavilion dv4000 Series...
Hp pavlion dv6609mw xp audio driver
Hi Karl, you're notebook came out with vista installed on it. So the main driver site for the HP Pavlion DV6609MW has a limited drivers for XP on HP's web site. Case in point the HD audio driver. You will have to install the Vista software for you're Conexant High-Definition Audio Driver. Click on this link to open the correct page.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-52105-1&cc=us&lc=en&dlc=en&product=3632302
This next site is the main download site for the HP Pavlion DV6609MW. Windows XP software.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=3632302&lang=en
When you need another driver that is not listed here, type what you want in the space above to the right of the words, Question or keywords:
You will be taken to another HP site. Look for the driver you want. Do not be suprised it is named for Vista. Chances are it will still function with XP.
Good Luck!
Have more questions? Please feel free to ask.
Mike
May 11, 2008 | Computers & Internet
HP Pavilion zd8000 Notebook Logo
349 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
