Question about Frigidaire PLCF489AC Dual Fuel (Electric and Gas) Kitchen Range
Igniters firing continuously, even when all burners in OFF positi
When I turned  off the large burner, the igniter clicking noise started and won't stop unless I shut off the breaker at the breaker box. All five igniters are firing and all five eyes turn on normally. The igniters just keep firing away, though. What's the deal?
  • 725 Answers
SOURCE: ignitors keep firing by themselves after my aunt cleaned the stove
Hi davemoo2, I would make sure that the all the burners are put together correctly .. next check to see if a selector switch may be pushed in or shorted . also check the that the ingitors are know grounded out.. let me know what you find out... kraxytech
Posted on Sep 22, 2007
SOURCE: Ignitors keep firing by themselves after my aunt cleaned them 24 hours ago
You have water left over from cleaning and it is shorting out the igniters at the knobs, not the burners. I guess the solution is to wait until it dries out unless you can open the top and maybe use a hair dryer.
Posted on Mar 31, 2008
  • 3463 Answers
SOURCE: My large burner will not shut off on my frigidaire stove.
You need to have the temp regulator replaced.
Posted on Dec 14, 2008
SOURCE: Front burner won't shut off. Have to close at breaker.
For $9.99 I will be glad to share the solution.
Posted on Jun 21, 2009
  • 78 Answers
SOURCE: heating element stays on when turned off
The thermostat (that is the dial that you turn to energize the heating elements) is the only thing that connects power to and disconnects power from the heating element. It is bad.
You can unplug the unit and remove the thermostat. Take it to a parts supplier and get a new one and install it. Your problem will go away.
If you would like to see a wiring on this link:
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Posted on Oct 15, 2009
Igniter misfire
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
Mar 25, 2010 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Spark igniters on the burners fire continuously
When cleaning, if the control switches get damp, they will react as you describe.
Unplug the appliance, use a hair dryer and attempt to dry the switches.
Leave it unplugged overnight and try them again tomorrow.
They will eventually dry and be OK.
Feb 24, 2009 | KitchenAid 31 in. KGCC505 Gas Cooktop
Old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Dec 22, 2008 | Thermador PSC364GDZS Gas Cooktop
Ignitors keep firing by themselves after my aunt cleaned them 24 hours ago After she did the major cleaning of the stove I used the oven and it worked fine. I lit a burner (Probably front?) and the left...
Apparently there was a water spill around the burner control knob and in the burner itself; We ran the burner to create heat and then turned it off and let the water dry out and evaporate from the burner and igniter area.
May 26, 2008 | Kitchen Ranges
Jenn-Air part RI302 4 pt gas re-igniter with flame rectification tytronics #Z21-20 and 7431 PO38-60
We had the same problem on a Thermador cooktop with the same RI-302 ignitor. Turns out it was one of the switches that sits on top of the gas valves. These switches cause the ignotor to fire when the valve is turned. In our case, one of the switches had malfunctioned and was "always on" causing the ignitor to continuously fire.
Oct 29, 2007 | Jenn-Air JJW8530C Expressions Collection...
Electronic ignition
Most likely you got water (or some other liquid) into the control knobs. Unplug, go to bed and try it again in the morning. If you continue to futz with it, you run the chance of burning out the electronics in the control knob, like I did. :(
Oct 22, 2007 | Miele 35 in. KM326G Gas Cooktop
Igniter will not turn off once burners are lit.
I've had the same problem for 2 years. Today I removed the four burner tops, the 15/16 inch bolt that holds the burners in place, took everything apart (simple connections underneath), completely cleaned and dried eveything. I also cleaned the 4 knobs and making sure the 4 swiches slide up and down freely then dried everything with a hairdryer. Is now works fine but if the problem comes back, I'll simply unplug the cooktop and light it manually. P.S. I stripped one of the large 5/16 inch bolt that had become weak and brittle. - Try using water or some liquid to loosen the bolts as necessary. Good luck, CHEERS!
Oct 13, 2007 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Had The same problem. I removed the top of the control panel to find out that one of the ignitor switches had turned when I replaced the four large plasic nuts on the control panel. Make sure the switches (block) are aligned, and kept aligned, when re-installing the top of the control panel. Startwreck.
Jul 15, 2007 | KitchenAid KGST307 Gas Kitchen Range
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Frigidaire PLCF489AC Dual Fuel (Electric and Gas) Kitchen Range Logo
44 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
