Question about Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator
Kenmore 106, 56532400 ice maker problem
Hi Tech Master,
The ice maker stops working. I checked the mold is empty (no water); however, the water dispenser still dispenses cold water. The freezer temperature has been always 4 as the factory setting. The ice sensor is red and flashing.
Thank you in advance for your help.
Regards,
Tim Ng
  • 700 Answers
Check to see if there inlet water is frozen up where it goes into the ice maker. If it is you will have the thaw it out before it will work correctly. the water dispenser solinoid valve ane the icemakers feed different lines thats whay you have cold water and no water feeding into the ice maker.Thanks for using FixYa and don't forget to rate this response.
Posted on Dec 27, 2008
    Sergeant:
    Novelist:
  • 327 Answers
he ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
http://www.repairclinic.com/0088_4_1.asp#Level1_10
click the link
My Kenmore refrigerator's ice maker is dripping at the front of the ice maker. it drips slowly but makes a big chunk of ice right at the front of the bucket. What should I do?
This is pretty generic without a model # but holds true with alot of them..this type of icicle is usually caused by water overflowing the ice mold of the ice maker module. The reason for the overflow could be that the ice maker module is not level. Check to see if it is tilting. This could be caused by loose screws or a warping of the liner on the side wall of the freezer.
If the ice maker is level, then the next cause could be that the ice maker is overfilling. There is an adjustment screw on the right side of the front of the ice maker module. You may have to remove the cover from the front of the module to access this screw. Turn the screw counterclockwise to decrease the water fill. Turning this screw one turn may decrease the water fill level in the mold enough to prevent the leaking. If not, you may need to make a second adjustment.
Other problems that could cause this icicle could include:
Wicking of the water over the top of the ice maker mold caused by hard water deposits in the mold.
Leaking of the ice maker water solenoid valve.
Crack or leak in the ice maker module.
If the module is level and decreasing the water fill level does not solve your ice maker problem, then I recommend checking the ice mold for hard water deposits. If you find no deposits in the mold (or clean them and still have the same problem), then you will probably need a service technician to fix the ice maker. if you need more help, re-submit your question with additional details.
or reply in comments.
Jan 02, 2018 | Kenmore Refrigerators
Ice maker all of a sudden stopped working.
Remove the ice bucket and look for ice hung in the fingers. Use a hair dryer to melt a jammed ice cube. Keep at it till the fingers move free and advance to the next harvest cycle. If the ice mold is empty replace the water valve. If the ice mold is full replace the ice maker.
Aug 24, 2011 | KitchenAid Superba Architect KSCS25INSS...
The icemaker stopped making ice. I can still get water, but no ice is being made. I have checked to see if there was ice frozen on the ice maker, but it is clean. What can I do to fix this problem?
If the ice mold is full of ice then the ice mold thermostat or thermistor is faulty. If the ice mold is empty their is a strong possibility the water valve on the IM side is gone. Pour some water in that ice mold and see if it kicks out a batch. If it kicks out a batch then replace the water valve. If it continues to not harvest any ice then get a new ice maker. It is that simple.
Feb 17, 2011 | Refrigerators
I replace the filter and now it dose'nt make ice
Check for a jammed ice cube in the fingers. Use a hair dryer to release the jammed cube.
Add some water to the ice mold and see if that don't speed up the process if the ice mold is empty.
After changing that filter:
Ice in the mold none in the bucket= ice maker problem
Empty mold= water supply problem
More here
Jan 17, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
My ice maker stop working
Knowing how an ice maker works can greatly increase your ability to diagnose and repair it. Just like vehicles, ice makers all may look different but they all work on the same princible. A thermostat starts the ball rolling, turning on a motor and a heater to loosen the ice, as the ice dumps a trigger fires up the water valve and refills it. The whole thing comes to a halt and waits till the thermostat gets satisfied once again.
So what can go wrong? The ice maker will give a clue. If their is ice in the ice maker but none in the bucket that is an ice maker failure. If the ice mold is empty and no ice in the bucket then the water valve is bad.
One thing you can do is get a bottle of water and fill the mold. If it kicks out a batch but no more, water valve replacement needed. If it don't then ice maker problem. If you have shelling or fouled cubes, look for dirty coils below the ice box that make for faulty cooling. Ice forms at 32f but ice mold tstats don't kick in the afterburners till 25f. I have some more detailed tips with videos and manuals: HERE
Jan 10, 2010 | Freezers
The ice maker on amana bottom freezer is not making ice?
Hi
Many top-freezer ice makers have very similar ice makers that are pretty easy to diagnose. Side by side refrigerators have a variety of ice makers so I’ll start with the more common top freezer units. If yours makes crescent shaped ice cubes this will probably be relevant to your unit.
These ice makers have a metal wire bail or wand that senses if the ice level is too high. This sensor stops the ice maker from making ice that would overflow the catch bin. Check to make sure this sensor isn’t obstructed or locked at the far end of its travel. In normal operation the sensor wand should be resting against the ice maker. As it begins a cycle the wand sweeps across the catch bin and will be stopped if ice has risen too high. The same wand can be locked in a position at the far end of its travel to disable the ice maker. This is the most common cause of no ice. This may be what you meant by "made sure the tray was set right and arm was done"
If you have a different type of ice maker just spend a few minutes watching it operate or examine the non-operating unit. If you have a neighbor with a similar unit take a look at theirs. Many have a front cover that easily pops off giving access to the internal works. Listen as you watch to hear solenoid valves open, water flow, etc.
Make sure you look for any other interlock switches that would stop ice making if the tray were removed, the door was opened, etc.
You’ve already checked the water line, I’ll assume you disconnected it and tested for water flow or it was a translucent line and that you saw water in it. While you could do further tests on the water inlet valve, it’s probably easier just to verify that water is making it into the ice mold. If no water or ice is in the mold then you need to check the inlet valve or check the timer’s water switch. If there’s water or ice in the mold then your water supply is working and we need to look elsewhere. If there’s ice in the mold the most likely cause is the heater or ejector. If there's water it could be several things from the freezer temperature to the heater switch.
It's easier to figure out the problem if you have a simplified idea of how the ice making process works. An electromechanical timer controls the sequence of events for the entire process and acitivates valves and switches at the proper stage of the process. An ice mold receives water through an inlet valve. The mold is usually cooled just by the freezer air and relies on it's mass to retain the cold. Once the water has been in the mold for the correct time the cubes are given a brief shot of heat from a heating element in the mold. This loosens things up so a mechanical ejector can push the cubes from the mold. More water is added and the process continues.
please chek this link,for further help..
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Thanks for contacting Fixya.com
Oct 12, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Component Ice Maker, What Else Could It Be...
remove ice maker maker sure is clear and also check the fill tube that supplies water to mold they sometimes have a plug of ice and no wtr comes out to mold that is if you already sure that there is wtr being supplied ok to unit
Oct 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker not working
Depending on the ice maker style, they typically work off a motor timer. The timer motor rotates to set up the ice making process... starting with letting water into an empty ice mold tray, allowing ample time for that water to freeze and then to rotate that mold so that the cubes fall out into the bin. In conjunction with that process, a small heater is turned on to release the frozen cubes from the tray. The 'ice tray full' lever signals the system to stop making ice so you may want to verify that the lever is down and not causing the ice maker to stop, If that's down then I suggest you monitor the position of the motor gearset underneath an access cover. With power applied, the gears should rotate and cycle thru an ice making process. If it does and ice fails to fall out, your heater may be defective. Hope that helps...
Jun 22, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator Logo
609 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
