Question about Sanyo DRW-1000 DVD Recorder/VCR
What kind of dvd's can be used in this dvd player?
So far only the original dvd could record on the player. What kind of dvd's can be use with this unit? I have tried sony 1x-16x ,memorex 8x , and fugifilm 8x and none have recorded. It continues to say disc not recognized and ejects.
    Problem Solver:
  • 12 Answers
That will write on -R or -RW ONLY ... for +R or +RW disks, it can read but not write. You can see this on the recordable media section on this page: http://www.dealtime.com/xPF-Sanyo-Sanyo-DVD-DRW1000-Recorder-Hi-Fi-VCR-Combo
Posted on Apr 23, 2007
I have a Panasonic DMR-ES35V DVD Recorder. The manual recommends their lens cleaner RP-CL720PP which is discontinued. Is it safe to use a generic CD/DVD lens cleaner for players? Or do I need one...
You should use a specific DVD lens cleaner for your recorder, there are generic ones available I am sure. I do not recommend CD/DVD lens cleaners - far too abrasive, and there is a risk of damage to your unit if you use this type.
A generic DVD lens cleaner should do no harm and does not cost a lot. The type of cleaner I have used in the past is exactly like a DVD disc, with fine bristles, is a dry type, and it gently removes the grime and dirt film from the lens eye (you can probably obtain a wet and dry type that comes with a small bottle of fluid). These are the most reliable, and, unlike original CD lens cleaners, are far less abrasive. These lens cleaners usually work in DVD players and recorders, I've never had any issue after using this type.
Give that a try, see how you go.
Feb 02, 2011 | Panasonic Televison & Video
I have a samsung dvd-v4600...and when i put the dvd disc in it just keeps loading and will not load ..what do i do to fix this?
Does it do with original DVD or copied DVD ?.
if the original one works fine but the others not, your DVD may not capable of playing copy -R/RW discs..even though your DVD specs says: Plays DVD-Video, video-mode DVD-R/RW and DVD+R/RW, CD-R/CD-RW, MP3 CD, Kodak Picture CD, and JPEG image CDs, sometimes this happens due to bad recording of DVD .Try to use better recorded DVD or if possible use the original ones..
Thanks in advance for rating me..Regards
Oct 22, 2010 | Samsung DVD-V4600 DVD Player/VCR
Tried dubbing VHS to DVDs, worked okay. But I cannot get the DVDs to play on my laptop. I used DVD-RWs. What kind of DVD do I have to use?
It depends on the specifications of the DVD drive in the laptop. Go to the website for you laptop manufacturer and look up the specifications. You also have to have DVD playing software. It is was not always included with the Windows operating system, although some kind of player may have been packaged with your computer when sold. DVD-RWs are recorded at slower speeds, which makes bigger dots and make not work with all DVD playback drives.
Jan 09, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
What kind of blank dvds can i use
DVD-R and DVD+R should play once recorded and finalized. RW of any kind is iffy and must be tested to see if they will work.
I don't think any dual layer DVDs will work, but I could be wrong. If you're taking about recording DVDs on this, it's not a DVD recorder as far as I know.
Dec 29, 2009 | Symphonic WV806 DVD Player/VCR
Line Of Distortion Along The Bottom of an Em20 Burned Disc
It's possible there is either a codec problem with your computer player. I would recommend trying a player such as VLC Media Player, to see if that works. If that isn't it, what kind of TV's are you watching the video on? Are they "tubed" or flat screen? If they are tubed, you wouldn't be able to see the line at the bottom like you do when you play the video on the computer.
Jan 09, 2009 | Panasonic DMR-E20 DVD Recorder
Will not record dvd's
There are different kinds of DVD recorders and different kinds of recordable DVD disks.   Your disk must match the format of your recorder.  (eg DVD -rw, dvd -r, dvd +rw, dvd +r).  Look on the front panel of the emerson recorder and see what emblems are printed on it.  Your dvd must match the kind.  Also, if a dvd is of the -r or +r variety and has been finalized you cannot overwrite/rewrite to it.  (From a quick web search it appears your dvd uses dvd -r.)
Dec 28, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Play back not available
you need to finalize the disk in the original recorder to play in other dvd players, you would know this if ou read the manual
Nov 23, 2008 | Philips Magnavox MWR10D6 DVD Recorder
I have a SANSUI DVD/VCR Combo,and cannot record from VCR to dvd.Itcomesup with disc error. Can you help?
1.- Check the type of DVD that the recorder accepts, usually id DVD-R (minus R).
2.- Make shure is a DVD recorder.
3.- Internally, the DVD combo comes with a software that don't alow to copy VHS original movies, is a kind of codification that is with the information content in each movie.
Sep 20, 2008 | Sansui Televison & Video
Won't play dvds.
Model number of the DVD player would really help...\
Bill
Apr 09, 2008 | Televison & Video
Problems with dvd reading
I HAD THE SAME PROBLEM WITH MY LG DVD RECORDER NOT EXCEPTING CERTAIN RECORDABLE DISCS . NO GUARANEES BUT TRY GOING TO YOUR SETUP MENU AND RE-SET THE ORIGINAL FACTORY SETTINGS FOR THE RECORDER THEN PUT A DVD CLEANER DISC IN YOUR RECORDER TAKES ABOUT TWO MINS TO CLEAN UNIT THEN TRY A BRAND THAT DOES WORK IN YOUR RECORDER OTHER THAN VERBATIM OR MAXEL . RECORD SOMETHING THEN EJECT IT . NOW TRY ONE OF YOUR MAXEL OR VIBATIM DISCS AND SEE IF IT WILL READ THIS TIME FOR RECORDING . GOOD LUCK . BEST REGARDS , blc7772001
Jul 21, 2007 | Cyberhome CH-DVR1500 DVD Recorder
Sanyo DRW-1000 DVD Recorder/VCR Logo
122 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
