Question about Dryers
WHIRLPOOL LER7646EQ2 will not turn on.
The dryer worked this morning. Now you close the door and push the start button and absolutely nothing - noise or action. The power is on the breakers are fine.
  • estenner Dec 30, 2008
    I have the same problem wiTh mine but a different make.Zanussi TCE7276W.
SOURCE: Whirlpool Supreme Dryer will Not Start
I have a whirpool heavy duty dryer that is not working. When I push the button to start the dryer it only roars, and the drum will not move.
Posted on Jan 27, 2009
  • 93 Answers
SOURCE: Whirlpool Dryer LER7646EQ2 Belt
sure he will if not get back to us we will help thanks from gilles
Posted on Mar 15, 2009
garing
  • 998 Answers
SOURCE: whirlpool dryer makes a buzz noise when push
pull motor switch out(the one with wires go in motor) best use compressed air.... lint is stopping lever... this all happens after you turn breakers off...hi hi
Posted on Aug 27, 2009
  • 1218 Answers
SOURCE: Inoperable Whirlpool dryer, Model LER7646EQ2
Good day,
Sorry, no reset you can get to. There is one embedded in the main motor itself, that if the motor draws too much current, and/or gets too hot.
If you shut the machine off for a 24 hour period, then it will many times appear to run normally again, but it's the motor getting weak.
It's usually a slow progressive problem, and if you choose,you can, at least for the short period use the machine by either lightening the loads, or spread the loads over a longer period of time.
Eventually the motor will need to be replaced.
Posted on Feb 21, 2010
  • 784 Answers
SOURCE: My ler7646eq2 will not start, button makes a click
The capacitor is probably bad. The relay is still working that is why you can hear a click noise. It won't come on since the motor needs to have enough voltage from the capacitor to initialize. Good luck.
Posted on Apr 19, 2010
Will not start
From your description it sounds to me like a lid switch. This is not a very costly part, but would you be able to replace it? This switch is located at the area where the door closes usually on the handle side of the door. Good Luck Friend.
Dec 26, 2017 | Whirlpool Dryers
My Whirlpool dryer(supreme) does not start. The timer switch, door switch, start switch can all be heard to electronically switch on and off when I turn the timer around and open and close the door....
the thermal fuse may be faulty. Remove the outer back of the dryer. the thermal fuse is located on the blower assy with 2 wires connected to it. It is white plastic. connect the wires together, then try to start the unit again. If the unit starts, clean the exhaust duct after replacing the thermal fuse.
Jul 20, 2010 | Whirlpool LEQ8000JQ Electric Dryer
I have an electric whirlpool with start switch not working
OPEN THE DOOR/PUSH THE START SWITCH ON DRYER/THEN PUSH THE DOOR SWITCH/HAVE A PERSON TURN THE DRUM/IF IT STARTS TO TURN (DRUM) OR STILL HUMS AND DRUM WILL NOT TURN YOU HAVE A BAD MOTOR/REPLACE MOTOR.
FREDDY
Feb 14, 2010 | Whirlpool LGB6300 Gas Dryer
Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
Oct 21, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer makes a buzz noise when push
Aug 27, 2009 | Whirlpool ET8CHEXSQ Dryer
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Dec 30, 2008 | Whirlpool LGR7646E Dryer
Kenmore 600 Series gas dryer
trigger broken dryer will not turn on. I need a replacement. Where can I buy this part.
Nov 02, 2008 | Dryers
Whirlpool lgr4634eqo makes a buzzing noise when trying to start
Try holding the door switch lever in and turning the drum hard by hand. It sounds like you have a start switch out in the motor.
May 20, 2008 | Whirlpool LGV4634JQ Gas Dryer
Dryers Logo
139 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
