Question about Engel Freezer 22 Qt. Fridge/Freezer
No water to ice maker or water dispenser
I get water to the water filter but not to the water dispenser or ice maker
    Problem Solver:
  • 10 Answers
You're funny. This is a portable 12/120 volt model. It dosn't have a water dispenser or ice maker :-)
Posted on Jul 14, 2010
Why don't the water dispenser and ice maker work?
You're on the right track. Clear the line, and it will probably work.
May 18, 2015 | Frigidaire FGHF2344MF Gallery 22.6 Cu. Ft....
Ice maker is not producing ice after changing water filter. Water is dispensing normally.
It may take some time for the icemaker to get the water after a filter change or there could be other problems
Mar 14, 2015 | Kenmore Elite 106.54619300 Refrigerator
Ice maker not working on Kenmore Model # 106.54563300 Water comes through water dispenser fine Water came pouring out through ice dispenser door so I flipped bar up to turn it off Removed front box held in...
First the arm has to be in the down position. It sounds like you said theres water in the ice maker. If thats the case then it should have frozed. The ice cannot drop unless the ice maker heater comes on. Then the ice maker scoops the ice and drops into the resoviour thingy. If you have ice in the ice maker tray but no ice in the bucket then the ice maker is defective.
Mar 25, 2010 | Kenmore Freezers
No water to ice maker but I get from the water dispenser
Check the waterline as well as the valve supplying water to the ice maker.
Sep 27, 2009 | Freezers
Ice maker does not fill with water
If your model has a water
Filter, that may need replacing. If that isn't it, the water valve most likely is the problem
Oct 19, 2017 | Freezers
Ice Maker in Freezer in side-by-side not working
CHeck to make sure your freezer is 0 to 5 degrees. If it is warmer than that the water valve wont open to the ice maker. Have you replaced the water filter?
Nov 15, 2008 | Frigidaire Freezers
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
Water dispenser / ice maker whirlpool fridge frezzer
Check that you haven't turned the ice maker off in the menu.
thanks J
Jan 15, 2008 | Freezers
Our fridge does not make ice - Whirlpool Gold side-by-side GS5SHAXNT00
Can you lower the ice maker temp on that model.
Thanks J
Jan 05, 2008 | Freezers
Engel Freezer 22 Qt. Fridge/Freezer Logo
214 people viewed this question
Top Engel Freezers Experts
AJMAL KHAN
John Tripp
John Tripp
Marvin
Marvin
Are you an Engel Freezer Expert? Answer questions, earn points and help others
