Question about Kenmore Refrigerators
Need to replace water purifier at base of Kenmore Refrig.side/sid
Does this purifier automaticly shut off when pulled out? Or do I have to shut off a shut off valve on the copper line.
  • 700 Answers
You need tro shut off the water supply to the refrigerator before replacing the filter. After replacing be sure to run the water to get the air out of the lines Thanks for using FixYa and don't forgat to rate this reply.
Posted on Dec 27, 2008
What should I do to shut down a kenmore side by side refrig for the winter?
Basically their is not that much ya would need to do to it,just if it has icemaker be sure to turn off the water supply to it and that pretty much it.
GENE
Oct 17, 2011 | Kenmore 56983 Side by Side Refrigerator
Have Kenmore sid-by-side refrigerator: 7909621940B - Just changed water filter. Now, no water or ice dispenses. Ice maker is making ice - filled the bin over a few days. But, when I push to dispense...
We also have a kenmore side by side refrig and had the same problem,,,
FIRST, CHECK THE CONNECTION BETWEEN NEW FILTER AND ATTACHMENT POINT,,
IF THE RUBBER GASKET CAME LOSE DURING THE CHANGE, IT MAY BLOCK THE PATHWAY FOR WATER TO FLOW
NEXT, CHECK THE WATER/ICECUBES/CRUSH LEVER SWITCH TO MAKE SURE IT IS NOT PART WAY BETWEEN ONE OF THE SETTINGS,
NEXT,CHECK TO SEE IF YOUR UNIT HAS A RESET BUTTON,
THE RESET BUTTON IS USUALLY IMMEDIATELY INSIDE THE OPENING WHERE THE WATER/ICE DISPENSES AND UP, YOU WOULD NEED TO PLACE YOUR FINGER RIGHT DIRECTLY UP BEHIND THE FRONT PLASTIC COVER, AND IT'S GOING TO BE A VERY SMALL BUTTON, I AM NOT SURE WHICH SIDE ON YOUR UNIT R OR L, BUT DIRECTLY UP IN THE CORNER,,
I HOPE ONE OF THESE HELPS !! angi
Feb 05, 2011 | Microwave Ovens
I purchased a new kenmore in 2009, and the delivery co. did not provide me with any manuals. I replaced an old Kenmore of exactly the same type, except this one has a WATER PURIFIER. No where do I find the...
www.managemylife.com/mmh/owner_manuals/5365/KENMORE-Side-by-Side-Refrigerator-L0804114
The instructions for changing the water filter begin at the bottom of page 12.
Dec 29, 2010 | Kenmore 53642 / 53644 Side by Side...
Kenmore icemaker
It sounds like the icemaker is making hollow cubes , and the unfrozen water in the cubes , after dumping , freezes and causes the ice shells to stick togather . This is a sign of " not enough water going into the icemaker " . Replace the water inlet valve , behind the refrig , the piece the wall water line connects to , on the refrig .
Oct 06, 2009 | Kenmore 57029 Side by Side Refrigerator
I have a Kenmore side by side refrig (no ice maker) Freezer works fine. The refrigerator side is not cooling. I have cleaned out the vent between the freezer and the refrigerator section by defrosting the...
Check to make sure the evap fan is running.
IF so, then let unit defrost, then turn back on, check for air comming thru top of refrig vent, if air moving ok, then let run for a few days and see if refrig warms again, if so then check for frost build up on back wall of inside freezer, if so, you have a defrost problem. With a defrost problem, defrost heater may be bad, defrost timer/electronic control may be defective. Either way, in most cases it is a defrost problem unless you don't have air moving and fan is running in this case you have a damper door problem inside air duct in refrig.
Sep 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My kenmore side by side refrig icemaker stopped working no water ?
Check for frozen water lines. if the lines are ok and, the wall shut off valve is open. replace the inlet water valve assembly.
Jun 22, 2009 | Kenmore Refrigerators
Water is freezing in the supply line for the ice maker
This usually means you have a weeping water valve. The water valve doesn't completely shut down after filling the icemaker. This deposits a staedy flow of water which freezes and accumulates in the tube, eventually blocking it off. You would need to replace the water valve which is located at the rear of the refrigerstor. One othe thing to check would be the water supply to the refrig. If the water dispenser is working fine then that isn't an issue. However, if that is flowing slowly you would need to replace the saddle valve which is tapping into your house water supply.
Apr 09, 2009 | Kenmore 53502 / 53504 Side by Side...
Dirty water out of dispenser
Spoke with Sears help line. They said I need to replace my water line. I'm going to look into replacing it myself. I'll let you know how it goes.
Jan 21, 2008 | Kenmore 53603 / 53606 Stainless Steel Side...
Fridg
water line in freezer door is froze up. Call GE customer service to see if your ref. has a service bulletin.
Jan 05, 2008 | Hotpoint HSS25GFP Side by Side...
Kenmore Refrig with Filters water and ice dispenser- water is dripping when not in use, no flow when activated
valve needs to be replaced. it is located in the back, just follow the water line to it. to shut off water there is eaither a shutt off behind ref or in the basement. again try to fallow the water line
Oct 22, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
89 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
