Question about Tomtom ONE GPS Receiver
Change mileage to us miles
How to i get to thate screen
As far changing the milage from km/mi..reset the system and then go back to tools
Posted on Dec 28, 2008
Mileage
There is no reason you cannot go 6000 miles between oil changes. I have a Ford explorer with 250000 miles and I changed the oil every 10000 miles. I never had any engine trouble - it is still running very well.
Apr 17, 2014 | 1997 Ford Explorer AWD
Do the miles transfer when changing cluster on 2004 mazda 3
A magician might be able to do that, but no mechanic can. Whatever miles is on the cluster from the previous car-that's what your "new" mileage is. Write it down when installed, then you can always figure the true miles on your car and engine by comparing the old cluster's odometer with the new one. See? The old odometer is the true mileage. Whatever miles you put on the new odometer should be added to the old odometer's miles to give a true mileage of the car and engine.
Feb 11, 2013 | 2004 Mazda 3
Is there a recommended mileage for the replacement of the timing chain/belt for a 2.4 liter 16 valve 2004 Camry Toyota
It has a timing chain..Can't find any info on mileage to change?? belts are about 60.000 miles, i don't think you have to worry about changing by miles ??
You may call Toyota dealer and ask service manager?? Hope this helped you ?
Jun 28, 2011 | 2004 Toyota Camry
The car I want to buy has a low mileage
yes you should check for finger prints on the inside of the glass and see if the #s are aligned exept for the the last one on the right
Jun 02, 2010 | 2001 Mazda MPV
What is the recommendation for mileage to change
needs to be replaced every 100,000 Miles
Nov 14, 2009 | 2004 Saturn VUE
Ford fusion 3 1600 diesel cam belt mileage change
75,000 miles for heavy urban city driving.
100,000 miles if you drive a lot of freeway.
Mix driving should be under 90,000 miles.
If your the timing guide (on the side of the timing belt cover) making noise then you should change it ASAP.
A loose timing belt will offset timing on the injector and decrease mileage.
Aug 26, 2009 | 2005 Ford Fusion
98 jeep computer replacement does this need to be done by dealer
Fuel mileage or miles on odometer? Miles on dash will remain the same...fuel mileage should improve if there is a fault in the old computer (reason for change) Unless the computer is not the main computer but is the one that stores miles etc for dash display.
May 05, 2009 | 1998 Jeep Cherokee
My gas milage has become worse
There are several items that can, and do, affect your mileage rating:
How long has it been since you changed your air filter?
How many miles has it been since you've done a tune-up?
Have your driving habits changed at all?
Have you checked the air pressure in your tires lately?
Have you had a geographical change in your driving routes?
All of these conditions, and a few more, do affect your mileage.
Try updating everything when you can, and see if your mileage goes up.
Even something as small as a different spark plug can do what you're experiencing.
Hope this helps you some.
Feb 01, 2009 | 2002 Volkswagen Jetta TDI
Changing the mileage clocks
push in on the little mileage reset knob and hold it in for a couple seconds.  Works on cars other than Renault ... hopefully there too.
Oct 30, 2008 | 2000 Renault 181
Gas consumption
My Answer:
Poor gas mileage can be a result of many many things.
First of all you need to find out what is the factory normal gas mileage for your model year Jeep SUV. It should have said on your window sticker if you bought it brand new. If you are a 2nd or 3rd owner then a Jeep dealer would have info. Google search will tell you as well, and only takes a couple minutes to find.
I did a quick Google search and for a 2003 Jeep Grand Cherokee with a (4.7L V8 engine) the average mileage is roughly 14 mpg.
Not sure what engine you have as to options, etc?
How you drive will greatly change that number up or down depending on a number of driving and driver variables.
A few being -
Driving habits?
Tire pressures?
Engine tuned up?
Lube & oil/filter changes (every 5,000-7,500 miles? Air filter changes (every 10,000-15,000 miles)? Read your auto manual for exact recommended intervals.
How many people in the SUV on average?
Are you towing anything?
Type gas you are burning - BRAND? (See injectors below)
Area you are driving in (hills and valleys verses flat out,
etc)
Jeeps in general don't have a good track record for great mileage, and rough engine idling is always a clue that your fuel injectors are dirty. Typical on all Jeeps with port fuel injection systems! On Jeeps with dirty fuel injectors your mileage will go way down accordingly. If your not putting at least a 12 oz bottle of say Walmart brand Super Tech Fuel Injector Cleaner (~ $1 each) in your gas tank religiously every logged 1000 miles, or every 2 tank fill ups, then you are just inviting dirty fuel injectors and POOR fuel economy!
My 1993 Ford XPLR with a 4L V-6 engine (and ~ 160,000 flawless driven miles) gets roughly 22 miles per gallon on the highway with cruise control on, and about 17 around town on average. I religiously put a 12 oz bottle of the above injector cleaner in my gas tank every 1000 miles!! Of course I do all my own tune-ups, general repairs, and suspension maintenance (shocks, O2 sensors, trans oil changes, lube & oil/filter changes, code reading and clearing, etc) myself and it shows! I don't trust repair shops except for say Tires and Balancing at SEARS.
Hope that helps ease your mind about gas mileage as it relates to your Jeep there.
Frank
Aug 01, 2008 | 2003 Jeep Grand Cherokee
Tomtom ONE GPS Receiver Logo
46 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
