Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Kenmoore side by side self defrost mode not operating correctly
Freezer coils continuously freeze up ; have tried to manually defrost with hair dryer but coils freeze over after several minutes. Is there a way to put the refrig/freezer into "self-defrost" mode ?
  • 1 more comment
  • denjendiamon Dec 27, 2008
    After manually defrosting, the water does drain and the fan does come on to blow over coils. No styrofoam on back side of panel -- airflow is correct
    The door seals corredtly/tightly; The outside (room) temp has been around 80-81 degrees and humidity near 60-70 %
    Is there a way to put unit into defrost mode?
  • 700 Answers
When the coils ar emanually thawed does the water get removed by the drain ho;le or are you having to soak it all up with a shop vac? The drain may be frozen up and that would cause the water to stay in the freezer and product ice.you said that the coils foreese over after several minutes does tha fan come on and start moving the air over the coils? theres a sensor that should be bringing on the fan and that should keep the coils from freezing up. On thae back side of the panel is there styrofoam on it ? if there is stryofoam is part of it missing and the air flow now incorrect? Just a few more things to lok at. Thanks For using FixYa and don't forget to rate this solution please.
Posted on Dec 27, 2008
  • Todd Born
    Todd Born Dec 27, 2008
    ok is the door seals sealing up correctly and not getting pinched when its closed?
The coils behind the freezer compartment freeze up about once a month. After I take it apart and defrost with a hair dryer it runs fine... for about a month. Is this the main control board?
it can be,but before you replace that $100.00+ board,check the defrost heating element for continuity and also the defrost thermostat(both on the evaporator coil) as these go bad too and are much cheaper than the board
Jan 09, 2011 | GE GSS22JER Side by Side Refrigerator
The freezer saection is freezing up causing the refridgerator to get warm, I defrost and this works for 2 weeks. What would you look for?
remove the rear panel inside the freezer in there will be the evaporator coil,if its covered in a layer of solid ice then defrost it with a hand held hair dryer,then with the power shut off to the unit unplug the defrost heater underneath the coil and test for continuity,if this checks good then test the defrost thermostat on the top of the evaporator coil,you will need to put this on a piece of ice or cool it to below to make the contacts touch otherwise it will show open(bad) if this shows good(closed),then check for 120 volts a.c. on this circuit when is in defrost mode
Nov 19, 2010 | Magic Chef CTF2125 Top Freezer...
This is the second time the freezer accumulates water and freezers at the bottom of the freezer section of the Admiral HMG67158, 26.6 cu ft freez/refrig. The coils behind the panel were completely frozen...
unplug unit, remove back panel inside freezer and manually defrost with hair dryer, sounds like you have a defrost problem, check defrost thermostat, defrost heater or defrost timer, defrosting with hair dryer will fix until it freezes up again
Sep 30, 2010 | Admiral Refrigerators
Freezer does not work at all little cooling in refrigertor side
your evaporator coil in the freezer is frosted up and iced over,you need to remove the back panel INSIDE the freezer behind the freezer shelves and defrost the coil with a hand held hair dryer,then check the defrost heating element located under this coil for continuity,if its good,then the defrost thermostat on the top of this evaporator coil can be bad or the defrost control be it adaptive or timed can also be bad,if you manually defrost it will cool for up to a week if its not too hot and humid outside and you don't open the doors too often
Aug 12, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
THE FREEZER STOP FREEZING AT THE TOP BUT THE BOTTOM
check the evaporator coil in the rear area of the freezer behind a panel for being iced over,if so defrost it with a hand held hair dryer,then check the defrost heater element for continuity under the coil,if this is o.k. then suspect a defective defrost control
Jul 10, 2010 | Frigidaire FRS26H7 26 Cu. Ft. Side By Side...
The coils in the freezer compartment keep freezing over causing the refridgerator temp to rise
Most times the defrost heater and defrost thermostat need replaced. manually defrosting, removing rear panel in freezer, unplugging power from wall and using a hair dryer to remove the ice allows you to visually see th defrost heater burned out. I will get some photos and links and return soon, Thanks Sea Breeze
Apr 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Does using a hair dryer to help thaw out freezer coils that have frozen over on a self defrosting unit damage anything?
I believe not. But if coil continues freezing maybe your defrost thermostat is not working
Jul 24, 2009 | Refrigerators
Freezer wont defrost and refrigerator is to hot
the evaporator coils in the freezer are iced up. either someone left the door ajar for a while, you didn't let the fridge sit empty and turned on for a day before filling it, there is an obstruction in the evaporator drain causing water to pool and freeze on the coils, or your evaporator fans are not working. you need to unplug the unit and either: 1- let it set with the doors open and defrost with the ambient air (and soak up the excess water under the fridge); 2- find the back wall where the frost is, take the screws out and remove the wall, and use warm water to melt the ice on the coils (and soak up the excess water); or 3- use hot air (hair dryer). be careful with the hair dryer. just enough to melt the ice and not to heat up the fins and tubing. clean up any extra water inside, check the drain under the coils for obstructions, make sure the fan works, empty the fridge, turn it on, close it, and fill it tomorrow. also, there is a self-defrost timer on the fridge. look in the manual for it's location and setting.
Jul 20, 2009 | KitchenAid KSRG25FK Side by Side...
Our freezer keeps freezing up and it causes it to
If you tell me the model number found in locations in photo below I can help you.
Jul 13, 2009 | Refrigerators
Fridge and freezer not cold and frozen up
Can you remove the back panel inside the freezer and defrost the coils. Use a shop vac with the hose in the blow position instead of the vacuum position. And blow on the coils to defrost quickly. Hair dryers work also but prolonged use will burn up hair dryers. Now turn back on and see if the inside the freezer fan works. It should be running to keep the coils from freezing up. Also could be defrost timer. But this will be enough to get you going. Let me know how it goes. ken
Jan 12, 2009 | Samsung RS2630SH Side by Side Refrigerator
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
111 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
