Question about JVC TH-A35 System
Error message upon powering on
The DVD player seems to immediately attempt DVD mode upon powering on, despite no disc being present. The display shows "ERROR, PRESS POWER OFF/ON TO RESTART" and no other action is possible other than to power off.
  • Chris Murphy Apr 29, 2007
    Thanks, but this has no effect, unfortunately. This was the next action taken after the instructions on the DVD display.
    This error seems to be addressed here, but involves taking the machine apart and doing an appropriate part replacement after following these tests:
    http://monitor.net.ru/forum/download.php...
  • asujath2000 Jul 24, 2008
    THE PROBS WILL BE THE FAULTY MPEG BOARD UNIT I.E NEED TO REPLACE COMPLETELY
Error message upon powering on,even if you switch it on then off the problem still persists
Posted on Apr 18, 2011
Unplug it for 10 seconds then plug it in again
Posted on Apr 23, 2007
2 Suggested Answers
  • 157 Answers
SOURCE: The DVD player seems to
You have an internal mechanical switch/sensor which failed and will need replacement.The reason it is giving this message because the sensor might have been stuck in a position when it was damaged. And also along with it some parts(semiconductors and capacitors needs to replaced too)need some checking too.
Posted on Jan 30, 2011
WILL NOT EJECT DISC
What is the model number of your DVD player? You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
FOR SONY PLAYER's
This issue may occur if the disc is damaged or if the disc was not inserted properly into the Blu-ray Disc® player. Follow the steps below to open the disc tray and eject the disc.
  1. Turn off the Blu-ray Disc player.
  2. Disconnect the power cord (mains lead) or AC adapter.
  3. Allow the disc player to remain without power for 30 seconds.
  4. While pressing the OPEN/CLOSE button located on the front of the disc player, reconnect the power cord.
    IMPORTANT: For some Blu-ray Disc Home Theater models it is necessary to press and hold the OPEN/CLOSE andPLAY buttons simultaneously, then reconnect the power cord.
    NOTE: This step may require the assistance of a second person.
  5. After reconnecting the power cord, when the tray opens, release the OPEN/CLOSE button.
  6. Remove the disc.
  7. If necessary, disconnect and then reconnect the power cord to recover the player.
Aug 24, 2015 | Televison & Video
If press eject button,it's showing LOCKED.what can i do?
Jan 21, 2015 | home Audio Players & Recorders
I have a toshiba dvd recorder D-R160SB and am trying to record from sky plus to a verbatim dvd-rw (as recomended by the manual). When i put the disk in the dvd recorder it immediately starts to format the...
Two in ten discs usually are corrupt out of the box unfortunately. Try a different brand. As for it coming out in 4:3 or 16:9 try the settings on your SKY box. This should work.
Mar 01, 2014 | Televison & Video
KOSS KS5190 incompatible disk error message
Well I assume you've gone through the usual steps of making sure the discs are clean. Assuming thats not the issue, and If you're lucky, the problem will be a tiny speck of something which has made its way onto the DVD's lenses and stuck there. These lenses are used for focusing and detecting microscopic light beams that bounce off the the DVD tracks. Occasionally you can fix this without opening the unit, using a DVD lens cleaner kit. You can google them and happily they can be found for less than $10. So its definitely worth a try. I often run into this with DVD players/burners in PCs. I guess despite manufacturers attempts to shield the sensitive optics, PCs are notorious for sucking in dust. If the disk cleaner doesn't work. you might go a step further manually cleaning. But I'd try to find a youtube specific to servicing your machine first. Manufacturers are getting good at disguising the procedure to take these units apart. Good luck.
Dec 14, 2017 | Televison & Video
I have a brand new dvd from Amazon but it will not play coming up with an error message saying "incorrect disc" - any advice
All discs will not play with this set. It is not a fault. It is a common trouble to this model.
Apr 29, 2012 | Sharp DVRW250 DVD Players
Dmr-ex85 shows u81 code and is not functioning at all, says please wait but eventually just goes onto error code. no buttons will function?
Physically unplug power from the unit for a minute or two.
Connect power cord to unit and Simultaneously Press & Hold
both the [STOP] and Channel UP [^] for 5 seconds. This will
force Eject the DVD tray. Remove any disc if present.
Cycle the power again if necessary and wait for the unit to
go through its self check cycle. If after several attempts, and
you continue to get this error, then your Ram drive may need
to be replaced.
Jul 12, 2011 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
The DVD player seems to immediately attempt DVD mode upon powering on, despite no disc being present. The display shows "ERROR, PRESS POWER OFF/ON TO RESTART" and no other action is possible...
Jan 30, 2011 | JVC TH-A35 System
Panasonic dvd players error codes
I tried the WD-40 and it worked........thanks a million !!
Mar 28, 2010 | Panasonic DVD RV22K
UNLOCK CODES
* power up the player without a disc init.
* press setup on the remote control,an osd will appear on the tv.
* select GENERAL using right cursor and use down cursor to select BASIC,press ENTER.
*press DISPLAY, the current region will be displayed.
*press CONIDITION/MEMORY followed by 1,2,3,4,5,6 dependent upon the required region.
* press SETUP.
And thats it.
Sep 07, 2008 | Pioneer DV-525
Burning to cd
According to hp help and support
When using iTunes for Windows you may get a disc failed error. An unknown error occurred (4280)
In this situation, if you attempt to burn a disc, the following error message may display: The attempt to burn a disc failed. An unknown error occurred (4280) You can resolve this error message by modifying a file in the iTunes CD Configuration folder. First, you need to verify the model of optical drive present. Verifying the Model of the CDRW/DVD Drive Verify that your PC has a Sony CD-RW/DVD CRX830E optical drive installed:
  1. Open iTunes.
  2. In the iTunes Help menu, click Run CD Diagnostics .
  3. Insert an audio CD in the optical drive.
  4. Click OK .
  5. View the results in the CD Diagnostics window:
    • If IDE/CdRomSONY_CDRW/DVD_CRX830E is listed, proceed with the procedure below to resolve the error message.
    • If another drive name is listed, this document does not apply to your computer.
Resolving the Error Message When an IDE/CdRomSONY_CDRW/DVD_CRX830E model optical drive is present, do the following steps to resolve the error message: CAUTION: Take care in using the following steps.
  1. Close iTunes and any other files and software that are open.
  2. Click Start , My Computer , Drive C: , Program Files , iTunes , and CD Configuration to view the files in the CD Configuration folder.
  3. Locate the file gcdrtype.cfg in the CD Configuration folder.
  4. Right-click the file gcdrtype.cfg .
  5. In the drop-down menu, click Open (you may need to select Notepad ) to edit the file gcdrtype.cfg in Notepad .
  6. In the Notepad window, scroll to the bottom lines of the file gcdrtype.cfg .
  7. Locate the line that reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05
  8. At the end of this line add " | NOSENDOPC " (the first character is a blank space), so the line then reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05 | NOSENDOPC
  9. At the top of the Notepad window, click File , Save .
  10. At the top of the Notepad window, click File , Exit to close the window.
  11. At the top of the CD Configuration window, click File , Close to close the window
  12. Restart the computer.
You should now be able to burn an audio CD without displaying this error message. ---------------------------------------------------------------------------------------------If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Jun 03, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
JVC TH-A35 System Logo
361 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
