My hp dv5, keeps showing 0% charging,plugged in, after discharging completely, ppls wht can i do 2 make it charge?
  • 177 Answers
The Battery or AC part may be faulty or broken, in these cases contact HP - their number is on the website or on your Computer Help and Support.
Posted on Dec 28, 2008
My battrey is not charging
1) is the power source active (some wall sockets have a switch to render power there inactive -Australia)
2) is the charger plugged into an active power strip or an active wall socket?
3) is the charger damaged?
4) how long has the cell phone been charging? If the battery was completely discharged, it may take a bit for it to show a screen of it charging.
5) if the battery will not accept a charge, it will have to be replaced. Lithium batteries retain longer life spans if you charge them when power level is down to about 20 percent, NOT when they are completely discharged.
6) Better write down the battery number and amps when you pull the battery and keep it with phone documentation.
Jun 12, 2017 | Cell Phones
How do I reset the time on my fitbit charge?
How to Reset Fitbit Charge HR
  • Connect the charging cable to your tracker and plug the other end into a USB port
  • Press and hold the button for around two seconds and deprived of letting go of the button take away the charging cable from your tracker
  • Wait about six to ten more seconds after removing the charging cable discharge the button and keep holding it down again
  • Once "ALT" and a white screen flash, discharge the button and keep holding it down again
  • After you feel a vibration, discharge the button and keep holding it down again
  • As soon as you see "ERROR," discharge the button and keep holding it down again
  • As soon as you see "ERASE," discharge the button. The tracker is going to turn off
  • To about-face your tracker aback on, essayist the button or attach the charging cable (make abiding by bung in the added end of the cable). When you can see the time on your tracker is 0:00, you have successfully reset your device.
  • Next, you'll tell your Fitbit account that you're setting up a new tracker
That's how you can Reset Fitbit Charge HR and Fitbit Charge.
The Guide Of Reset Fitbit Charge HR Complete Guide
Dec 04, 2016 | Exercise & Fitness
Emachines charging
I've gone through exactly what your're going through right now.
I'm sorry to say but your battery is dead, you need to get it replaced. It can be replaced under warranty, if you have it.
To avoid this kind of a problem in future take care that you:
1. Don't let the battery drain out after your PC warns about low battery.
2. Try to maintain it's charge when you are not using it for days. The self discharge of the battery may take it below the critical level even when you're not using it. So keep charging it even when you're not using it.
3. Preferably use your laptop on external power supply (keep it on charging while using it whenever possible), charging it even when the battery is full doesn't hurt.
4. Let it have a charging and discharging cycle at least once in two weeks.
The above steps will help you maintain a good health of your battery and avoid the problem you're in currently.
Aug 31, 2013 | Computers & Internet
HP Pavilion dv5 Power Button not working
please disiconnect the adapter from the laptop
2) take out the battery
3) press the power button for 60seconds exactly.
and try again for normal use. The secret is to discharge the ESD. from the battery and the system
And try again. However if the problem persist, you must test the output from the adapter for to see if are working and consecuentrly charging the battery.
God bless you
Feb 18, 2013 | HEWLETT-PACKARD Pavilion dv5-2035dx...
My laptop is not charging. it says 0% available (plugged in, not charging) plz help i have a stock hp pavilion dv5
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 25, 2011 | HP Pavilion dv5-1138nr Notebook
My hp pavilion was fine but it discharged
ok it sounds like your battery was damaged when it discharged. try removing the battery and plug in to wall socket. boot computer ,.. if it boots up completely then you will need to replace your battery
Sep 22, 2009 | HP Pavilion ze2000 Notebook
HP DV6000 Won't Charge
The charging process is suspended temporarily because the battery has overheated. My brand new DV5 (3 weeks old) does the same, because it's really hot here.
Turn the laptop off and the battery should charge. Also, when you do not need the battery and are running off the mains, remove it from the laptop. Keeping a battery at 100% wears it 4 times faster than doing regular charge/discharge cycles.
Jul 02, 2009 | HP Pavilion dv6000t Notebook
Laptop power connection faulty
Hallow Dear,
As your explanation about Battery issue simply I’m advising you to replace your battery with original one.
But before that there is one thing that you can try it out.
---Use your laptop until battery goes down & shutdown automatically then remove the battery and try to discharge it completely with small bulb manually
When it’s on completely discharge (0 Volt) keep it on Outdoor Sunlight about 12 hours.
After that connect it to your laptop & recharge it completely (until Computer LEDs showing you as Fully Charged)
****** REMEMBER DO NOT TURN ON YOUR LAPTOP******
Until its Showing you as fully charged
That will be nice if you can check Battery Voltage & Amperage manually as it is charged fully before turn on your laptop. (if not you can give more charging time accordingly)
This will not solve your any component (thermal fuse, vRegulate) problems inside your battery but will increase your battery Cells Life and most vStoraging problems on Cells inside your battery
Thank you & Best Regards
Dinu….
Dec 20, 2008 | HP Pavilion dv6000z Notebook
Problem with my hp notebook battery!!!
discharge your battery compleately and then
charce your battery for 16 hrs add then discharge compleately
and charge till 100% batt level approx 2hrs
that will help
Nov 03, 2008 | HP Pavilion dv5020us Notebook
Computers & Internet Logo
200 people viewed this question
Alun Cox
David Payne
David Payne
