Question about Acer Aspire M1100-U1402A Refurbished AMD Desktop PC - AMD Athlon X2 4400+ , 2GB DDR2, 320 SATA II, D
No usb ports are working,dvd drive do not burn.
Dvd drive will not let me formatt anything, no usb ports will read or burn
    Problem Solver:
  • 16 Answers
If you are having multiple component issues you should probably check if the motherboard isn't acting up; usually this is the solution to many problems at one time since the motherboard keeps everything running together smoothly.
Check the inside of your CPU for dust and also check your configuration (via My Computer and right clicking on the appropriate drive) of your DVD writer.
Hope this helps!
Posted on Dec 29, 2008
How install xp in usb pen drive
Download the following files from Internet and follow the instructions bellow.
1. USB Formatter.exe
2. WinSetupFromUSB_0-2-3.exe
Instruction.
!!!!Set Up Intallation!!!
Note:
*If Required To format with HP Formatter use USB formatter and Donot Bypass the Instruction.
Note: When Formatting Choose NTFS ( this is the Most Important!
1.Install WinSetupFromUSB_0-2-3
2.Follow the Instruction
3.Browse the Source XP cd
4.Click GO. ( note: when making bootable USB! dONT Press or check anything just GO only )
5.Wait until System Process Finished.
*******Before Installation******
!!!!After Finished!!!!
1. Exit the USB.
2. Safety ReMoved!
******Final Installation for Setup*****
!!!Installation to your Netbook/Laptop/Desktop!!!
1. Insert to your Laptop or NetBook USB HUB!
2. In the BOOT SCREEN! bott from CD/DVD?USB. drive
3. Press Enter
***** the Screen will boot Dont Press anything let the program Run for Installation!!!
4. You will see that the System Prompt installing The PART - 1
Let System Continue and Donot Press Any KEY. until its. Finished!!
Enjoy.....
This is new Version for XP to make XP USB Bootable for your Netbook or any other computer..
Aug 25, 2010 | Computers & Internet
Usb failier
Hi Qqhampton
Your USBs are more than likely past their sellby date! A PCI card like this with some new USB ports would only cost a few £/$ and are very easy to install if you follow the instructions and an awful lot cheaper than a new motherboard!
Regards
Scott
Mar 24, 2010 | ASUS M3A78-CM AMD 780V AM2+ Phenom FX /...
The liteon dvdrw will not burn a DVD
Perhaps you should reinstall the Sonic stuff, in case it was affected since the virus cleanup.  If the OS had some of its components quarantined from virus contamination, you are probably stuck reinstalling the OS...though of course you can search the web (and not least Microsoft.com if that's the sort of OS you use) for healing 'media detection' issues (w.r.t. your particular OS.)
Mar 18, 2010 | HP Pavilion a1610n PC Desktop
Will CD-RW drive play video or do I need CD-Rom? (Gulp) Cost ?
MAIN QUESTION.
NO sorry to tell you you need at least a dvd drive to play dvd's DVD - R/RW to burn onto a DVD disc but you are lucky, external DVD drives are relatively cheap now days, just look around online or at walmart my estimate is that you wont pay more than 200 for a dvd-rw drive (external) as far as the value of the computer you are getting i would say currently $200 to a max of $400 value if you were going to sell it and thats asking high. if you didnt pay more tha that then you are ok IF you did i would be asking for your money back as you can go to walmart and get 3 times the computer for 300 bucks. if you need to know more just shoot me an e-mail at tonyw514@yahoo.com just let me know in the subject that your real.
Jun 01, 2009 | Dell Latitude C810 PIII 1Ghz, 10-30Gb,...
My pc says 'drive not ready' when i try to burn cd
does it read the cd ? make sure that the IDE / SATA port are connected properly / or even usb cable if you use external cd burner...
May 13, 2009 | LG GSA-2166D DVD RW Dual Layer Burner
Will not read disks
Is this an older drive? Possible that the drive is dying. I had this happen to me once. I ended up buying a new cd/dvd burner. The laser works different when reading verse burning, so it is possible that it is dead, but still working just enough to burn.
Apr 20, 2009 | Computers & Internet
Usb problem
no fear. sorry to say that your usb flash is done for. extracting the information can be done, but it is a specialized job and thus will cost a small fortune. getting it repaired is fairly simple but the information inside might not be attainable due memory chip damage. does your fash disk power up (as in does the light on it flash when plugged unto the USB port)?
babyvalkyrie. your problem is slightly different. what you need to do is log onto the bios menu during startup if the bios recognises the the HDD then you can try to re-install windows on it, but during setup you will have to formatt your harddrive fully (formatt using the long formatt not the quick formatt. also use the ntfs formatt. If your bios does not recognise your HDD then you will just have to replace it.
May 17, 2008 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
DVD DRIVE WONT READ ANYTHING
If clone burning is successful then rub the dvd with soft cloth and again put it on the drive. If these will not solve the problem then wash it with warm water and a detergent.
I once do these and get the files.
Dec 08, 2007 | Toshiba SD-R6372 (SDR6372S) DVD±RW...
Bad writing
Take it to a friends house with internet, temporarily install it on his/hers machine, update and flash the firmware to latest and do a test burn there. Install it back to your cpu and see what happens. also, try a different burning software. Good Luck
Apr 24, 2007 | MSI (DRE8) DVD±RW Burner
Acer Aspire M1100-U1402A Refurbished AMD Desktop PC - AMD Athlon X2 4400+ , 2GB DDR2, 320 SATA II, D  Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
