Question about Yamaha HTR-5440 Receiver
Yamaha HTR 5440 Unit will not power up!
I have a Yamaha HTR 5440 unit that I have had for several years. Recently it stopped powering up. I took the cover off it and did not notice anything burnt. The fuses were good and I had power at the power supply rectifier bridge. When I turn the unit on, there is a click and no display. None of the functions work so I believe it is being inhibited by some kind of control circuitry. I like the unit and would rather repair it than replace. it. Any Ideas?????
techman
  • 3130 Answers
SOURCE: Yamaha Receiver Rear-channel Problem
Have you ever used the headphones as the sensor switch could be dirty?? Or if not mybe got a glitch in the micro from a surge or something like that. Try unplugging for a good few hours and restarting again???. Good luck Let us know as the more info we get the better we can assist you.
Posted on May 15, 2006
  • 3 Answers
SOURCE: what's NEC PF68S33 TV's remote control code for YAMAHA HTR-6130
I had similar problem when setting up the YAMAHA remote control for my NEC LCD TV. At the end I found I did not follow the YAMAHA manual properly. Did you hold down the DTV/CBL button, and AT THE SAME TIME press the AV POWER for 3+ seconds? You should be able to "REMOTE SETUP OK" displayed in the front panel of the YAMAHA AV receiver. Hope this helps. BTW, only the TV POWER, TV MUTE and the numeric buttons work in my case.
Posted on Feb 16, 2009
sparky1500
  • 1066 Answers
SOURCE: On my yamaha HTR 5440 after few seconds of
are you running your speakers at 8 ohms?
Posted on Feb 27, 2009
heavyice
  • 374 Answers
SOURCE: Microphone for my YAMAHA HTR-5440
Let me make this clear to you that your Yamaha does not support Microphone but the trick is you can still do it. All you need is a stereo jack to a RCA connector cable.Check this out http://www.mediacollege.com/audio/connection/jack-stereo-rca-2.html It is easily available in the market. The stereo jack will fit into your microphone and the RCA to your Amplifier/Reciever. Plug the RCA into CD/Tape input but not in the Phono n do your thing. Let me know if this works,coz I'm really curious.
Posted on Jun 02, 2009
smarthome2
  • 1114 Answers
SOURCE: what is the yamaha htr 6050 remote code?
You have to "learn" the IR. Yamaha has discrete on and off commands. which universal remote are you using?
Posted on Jul 26, 2009
The Sub-woofer output on my Yamaha HTR-5440 keeps dropping out!
may be dry joints on electronic components, consult a technicia for resoldering the pre amp or amp unit,
Feb 03, 2014 | Yamaha HTR-5440 Receiver
How to reset a yamaha 5440 reciever back to factory settings
Hold 'fm/am' and 'input mode' and press power button. Then cycle through menus using 'program' button until you come to the selection that says "preset inhibit". Then press 'preset/tuning' button to change it to "preset reservd". Then press power button to turn it off. When you turn it back on, it should be back to factory settings.
Dec 30, 2012 | Yamaha HTR-5440 Receiver
Yamaha HTR-5660 Power Problems
i talked to my father in law who knows quite a bit about these. your only option is replacement. i wish i had better news. i know what they cost and i have one as well.
Jan 19, 2010 | Yamaha HTR-5660 Receiver
Jun 02, 2009 | Yamaha HTR-5440 Receiver
Yamaha HTR-5230 will not power on
check yhe fuse inside the unit?
Jan 03, 2009 | Yamaha HTR-5730 Receiver
Powers on for just 5 seconds then off
Took my Yamaha HTR 5790 to a repair shop for an estimate to repair. Cost me $50 for estimate to be applied to repair. It needed two circuit boards replaced at a cost of $390.00.
SOLUTION... they kept my $50 and I bought a new AV Receiver that WAS NOT a Yamaha.
Aug 23, 2007 | Yamaha HTR-5790 Receiver
Remote will not work on my reciever
I am wondering if it a preprogrammed remote controller or not. If not, you have to reprogram it.
Jul 03, 2007 | Yamaha HTR-5440 Receiver
Check sp wires?
Your problem most likly is not because of dust. Its a bad connection in the amp section or the protection circuit, or the speakers them self have a problem. There could also be a componet problem. Unless you know how to troubleshoot solid state electronics,you should take the unit in to be serviced. It would most likly cost more then its worth to repair. A unit this old is u replaced at this point. Good Luck
Aug 05, 2006 | Yamaha HTR-5440 Receiver
Yamaha HTR-5440 Receiver Logo
147 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
