Cars & Trucks Logo
Posted on Sep 22, 2012
My ring fell behind my husbands dodge truck behind the dashboard, I tried sliding my fingers by the crack but I can't feel anything ughghhh I'm wondering where it could have gone? Should i have hope finding it if the dash gets removed or could it be long gone already? Pleeease help!!!
Anonymous
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 38 Answers
  • Posted on Sep 22, 2012
Anonymous
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
38
Questions
Helped
12216
Points
88
There isn't a black hole in trucks that make things disappear. If it fell into the defroster ducts it's going to take some work to get it out, but I'm sure it's in there somewhere. May have to remove the dashboard and ducts to locate it. It won't be a fun job, but if the ring means that much to you, you don't have much choice.
  • morgan6987 Sep 23, 2012
    Okay thank you!!
  • Anonymous Sep 23, 2012
    gollum strikes again
5 Related Answers
Anonymous
  • 625 Answers
  • Posted on May 31, 2008
SOURCE: Check Engine Light
almost any thing will bring the light on, like if you go get fuel and fill the tank with truck runing it will turn the light on
it does not mean than it is not safe to drive but you need to go to an auto repair and have them conect the scan tool to see what code is present i will recomend to take care of it because with the light on you might notice or get a decrease in gas mileage and fuel is so expensive now
LAYNRAIL
LAYNRAIL
  • 18 Answers
  • Posted on Jan 09, 2009
SOURCE: Dash removal for installing a radio
you just have to pull on it a bit, there is clips behind it. they are a little tricky so be careful, but ou have to use a bit of force
Anonymous
  • 9 Answers
  • Posted on May 02, 2009
SOURCE: dashboard removal of '98 dodge ram 2500
on the 98 model the fuse box can be removed without removing the whole dash board.
kirtec auto
  • 1348 Answers
  • Posted on Jun 14, 2009
SOURCE: engine light on the dashboard and stalls from time to time
look for a pipe that goes from the exhaust to the intake manifold on the back.there is a valve there
Anonymous
  • 548 Answers
  • Posted on Aug 26, 2009
SOURCE: I need an diagram on removing the dashboard in a
the library has free manuals to lend on most cars foreign and domestic if they wont lend it you can copy the diagrams you need
2answers
How do i retrieve a plastic card which fell into the middle console through the sliding cover closest to the dashboard on the middle console?
Pulling the floor onsoles are super easy, just identify whi h ones lay on top of the other..just a bunch of screws, starting inside an opened console. Snap them back in place in reverse order.
2answers
My Jeep Cherokee Laredo 1993 suddenly started making loud noise and steering got tight after driving it hard
the fluid for the power steering has ran out...fill it.usually located in the dashboard, near the steering wheel....
Repair cracked block behind water pump 2000 E150
You have a cracked block
Why would you do anything but replace it
or possibly weld it,once out & all apart & cleaned
Can't get battery tray out
some of the dodges have holes and slots that hold the box in place as well, try sliding it sideways either forward or back, side to side.
3helpful
Flashing 4x4 light on dashboard
The truck is telling you that there is a problem with the 4x4 system and the 4x4 should not be available for use. the system is extensive so it can be anything from a wheel speed sensor to a transfer case ring gear. the good news is that if its not a check engine light it shouldn't cause a brake down. i would find a good auto shop and have them use whats called a modis scan tool and find out why the light is on.
1helpful
2answers
How do I change the high beam bulb on my 2004 taurus
from behind
twist the old bulb counter clockways and remove, DO NOT TOUCH THE NEW BULB WITH YOUR BARE FINGERS
Stick your hand in a plastic baggie and then grab the new bulb out of it's package (Normal grease on clean hands sets up stress cracks and the bulb life will be very short)
Stick it straight in the socket) Push hard) and then reinstall the socket push in and twist right till it clicks
You're done
2helpful
2answers
My 2004 dodge ram 1500 with a 4.7 the AC blows cold but it barely comes out the vents as if something in the dash is not opening?
Check, under the hood, all vacuum lines. Loose, cracked, melted. WIth the engine running, wiggle them around, and listen for a hiss.
Drive shaft changing
Check if their is a ring just inside the outer casing. To check Push the drive all the way in then with your finger in the track for the drive rollers slide your finger all the way out to the end. Just before your finger is all the way out you should feel the ring across the track. Slide a small flat screwdriver under the part of the ring you feel in the track pry it up and out. I am not sure if this is the way it is kept in on a volvo but is a common way that drives are in. Cheer's
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
