Question about Matrix Video Storm CRM84D HDMI, DVI&Component Video Switcher - The 1080p rated CRM84 switches HDMI, ...
VIDEO TO HDMI?
Can I have wii video signal go into a receiver and out to tv by hDMI
Solved - I learned Sony 720 and 820 receivers do not up convert video component (Wii) in to hdmi out. Need to upgrade to 920. Thanks anyway.
Posted on Dec 28, 2008
Denon 1312 receiver composite video inputs do not work.
I'm having the same problem with my Wii output. The manual for the Denon AVR-1312 says that analog video signals (i.e. component/composite outputs from the Wii) are not converted to digital video signals (i.e. HDMI output from the rcvr). I'm running only HDMI to a projector, so the video signal is essentially lost. The fix appears to be to run an additional composite cable all the way to the projector. Sounds like your fix is the same. No Wii tonight! :(
Jul 07, 2012 | Denon AVR-1312 5.1-Ch A/V Home Theater w/...
No component video with my Wii (component audio and HDMI video/audio both fine). It used to work fine, but now it won't show any picture regardless of which component IN I use. I checked all assigned...
Hello, I am sorry about your issue. Did you make any changes to the output resolution on the Wii. The output must be at 480i for the receiver to up-convert to HDMI. If there is a problem with the receiver I suggest a work around by connecting the component [red,blue,green] video outputs to the TV and the audio connections [red, white] to the receiver. Thank you, Onkyo USA
May 11, 2017 | Onkyo TX-SR606 Receiver
How to connect surround sound, tv,wii,dvd
Depends on your TV, surround system, and the provided connections.
The most common with a decent LCD TV is connected all the input devices (DVD, Wii, etc) to the TV via their respective connections. Run the audio from the TV to the receiver via HDMI or SPDIF or other audio out line on your TV. Set TV to output audio through that line always and you are done.
Quality audio receivers will have a panel where you connect everything to it, then connect the TV to it via HDMI. It will play the audio and send the video signal via HDMI in what is called a pass through. This will only be an option on quality, mid to high end audio receivers.
In either case, reading the manual for the receiver will tell you how to do this.
May 14, 2011 | Televison & Video
I can't get video out to TV from Wii video input on receiver. Wii is connected to AV5. Video to TV is thru HDMI out on receiver to HDMI in on TV. I can port the audio but get no video
Hello there,
ok the setup you are using is a Receiver, TV, and Wii unit .
Step 1: plug one HDMI cable into the back of the Receiver unit on slot 2 name on it is called HDMI out jack
if looking at the back of the unit this slot is 2nd from the top left
Step 2: now plug the HDMI cable into the TV this is the cable you just plugged into the Receiver
TV done
Step 3: Wii Setup move the Yellow,White,Red cables over to the right if looking at the back of the unit 2 spots name for this group is called AV out Jacks .
Wii Done
now use the right input channel for this group and you should now See Wii playing .
Thank you and don't forget to Rate
Jan 26, 2011 | Yamaha RXV467 Receiver
My wii is connected through component cables and runs to tv HDMI
In the receiver's main menu or setup on the remote you will find "input/output assign", make sure the "HDMI Monitor" is set to "yes".
This will make sure whatever video source is connected will be upconverted and outputted to the HDMI going to your TV. If it is set to "no" it will not show your Wii.
May 24, 2010 | Onkyo TX-SR605 Receiver
My wii won't play video through my Yamaha RX-V465. The audio comes through OK. I have a normal signal video component cable and i have connected the receiver to the TV with a HDMI cable. i have tried...
This receiver doesn't support processing of video signal, only switching. This means that it can output only the same format of video. Only some more expensive models do upscaling from component/composite to HDMI out.
From HDMI out, you can output only signal that came via HDMI in 1-3. For component out, you can output only component in. The same for composite.
So in order to use wii through receiver to TV, you must connect receiver and TV also via the component cables.
Or other option is to connect component from wii directly to TV and connect only audio to receiver.
May 09, 2010 | Yamaha HTR-5840 Receiver
TV not receiving video signal from DVD. Component video setup from DVD player to SR-606; DVD input assigned to IN1; TV receiving TV signal routed through same HDMI working OK. Was working OK once. Didn't...
This model has a defective hdmi pcb assy. this is a well know defect with this model.If under warrenty have hdmi bd replaced if not the hdmi pcb assy retails around $350.00
Mar 28, 2010 | Onkyo TX-SR606 Receiver
I have a Onkyo HT-S6100 sound system which has the HT-R667 receiver. I have a DirecTV dvr hooked up with hdmi, a PS4 hooked up with hdmi, and a Wii hooked up through component cables. The receiver is...
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
Sep 26, 2009 | Audio Players & Recorders
Just wondering if the 1708 converts up to hdmi? I have a wii and the audio works but no picture.I have the hdmi to the monitor out. So I don't know if there is somthing I have to setup or if I have to run...
this model can converts
HDMI ---- > HDMI
Component --- > Component
S-Video --- > composite, S-Video, Component
Composite --- > composite, S-Video, Component
Apr 08, 2009 | Denon AVR-1708 Receiver
I have the Rx-V661 and I just got the WII. I input the WII into the Video AUX on the front panel and pressed the aux button on the remote and nothign happened.
Just a thought, but, how do you have your TV/Monitor hooked up to the Yamaha unit? If your only connection between the receiver the and the TV/Monitor is an HDMI cable, and you are plugging your WII into the front v-aux jack using composite video, the receiver will have no way to send the video signal to the TV/Monitor. The receiver upconverts all composite video and S-video signals to component video signals. This means that if you only have an HDMI connection between the receiver and the TV/Monitor, you will also need to establish a second, component video connection between the receiver and TV/Monitor to handle the upconverted WII video signal. You will probably also need to switch your TV/Monitor to use that input when you are using the WII.
Of course, if you already knew this and have it set up that way, this answer won't help you at all!
Dec 25, 2008 | Yamaha RX-V661 Receiver
Televison & Video Logo
98 people viewed this question
Top Matrix Televison & Video Experts
Are you a Matrix Televison and Video Expert? Answer questions, earn points and help others
