Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Need a manual on my refrigerator
I have a Kenmore Side by Side Refrigerator - Model #106.57036601 with a Pur Ultimate Filtration system. I need to replace the filter; however, I do not have a manual that shows me what filter to buy and how to replace it. Can I get a copy of an instruction sheet on this subject?
  • keyla b Jan 21, 2009
    i moved my refridgerator to get some tiles when i moved it back i plugged it up and it did not work now my food is getting spoiled
  • keyla b May 11, 2010
    why did my fridge stop working
  • 59 Answers
That model uses the 9030 style filter at Sears. To remove the old filter push ******* the button next to the filter until it pops out a little then just pull it out, remove the cap and place it on the new filter. Make sure you remove the red seals from the end of the filter.
Posted on Dec 28, 2008
Kenmore side-by-side not dispensing ice or water, the ice maker has been replaced, no water going into the tray. I cannot locate the water filter, does this model have one?
Don't know what is the model number of your fridge. 1.Need check electric water valve under the fridge. If that fridge made by GE (Kenmore just a Sears brand name and they use several others manufacturers for refrigeration), usually it's a frozen plastic water supply line inside freezer door. You could unplug fridge for 24 hours (you have to put food from freezer to other freezer).
Jun 29, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
Making loud noises
hi there,
might be main motor problem. better have it check by a professional.
Jun 11, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
The motor doesn't come on.
the first thing to check is the over load relay and start ptc on the compressor. not sure if you can tell if the comprssor is coming on or not.i hope this helps you let me know how things work out.good luck
Jan 22, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
No water from the dispencer at times and then you hold it for a minute or so and then comes water
adjust tempt to a warmer setting it may be icing the water . if this doesnot work get back with me and will need the correct model # ..mm
Jan 19, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
Need a diagram for water valve part# 241734301 ice maker lines are crossed
If you press the water dispenser and the water comes out in the ice maker this is an easy fix.
I assume someone has replaced the water valve on the back side and reversed the electrical connectors for ice and water.
Jan 16, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
Freezer wont freeze and fridge isn't cold enough
Check the refrigerant level, using the systems analyzer.
From the analyzer, you will know if the high and low side of the compressor has the right pressure. If you
don't have the analyzer, then just get the services of
the refrigerator/freezer technician to fix it.
Sep 28, 2009 | Kenmore 24.5 cu. ft. Side-by-Side...
Low water pressure on kenmore side by side with PUR filtration
You must make sure your water line isn't kinked. You may need to replace your saddle valve. Get rid of the self piercing type.
Feb 22, 2009 | Kenmore 24.5 cu. ft. Side-by-Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
276 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
