Question about Kenmore 73932 Gas Dryer
My gas dryer heats at the start but dont reheat up
The glow coil works but don't fireup
  • 91 Answers
Remember if it glows and shuts off w/out turning on heat replace both gas coils,, than kyou
Posted on Jan 04, 2009
How do I test continuity on the sensors?
if it ignites then it's not the sensor,all you do with the meter is whatever part you're checking remove at least one of the wires,then put one lead on one side of the part and the other on the other side where the wire connects,set the meter on like 20k ohms,if the 1 stays there the part is bad if you get any other reading other than 1 the part is good,if it ignites for the first or second time check the gas coils on top of the gas valve,when the coils are starting to fail they will work fine until they heat up and then no flame,then when they cool down they could work again or you have a bad gas valve,sometimes when the gas valve is bad it will chatter and be noisy and might ignite or not,you can try tapping on the valve when the ignitor starts to glow to see if it lites but like i say if it's igniting the sensor is good there's no gas, i believe when the sensor is bad the ignitor will sit there and glow for a long time without any flame if the sensor is good the ignitor will glow for like 10 seconds and go out if there's no gas coming in from a bad gas valve or bad gas coils but it's getting no gas,hope this helps you out and if you have any other questions open the door to dryer and send the full model number so i can help you out better
Oct 21, 2017 | Dryers
Dryer running but not heating.
If the igniter glows but does not light, you will need to replace the "gas coils" on the machine. Here is the coil kit to order.
Here is a video to walk you thru the repair process.
Nov 07, 2012 | Dryers
No Heat- Dryer will not dry clothes, the pilot light will light for a few seconds with a glow. I have changed the coils and the thermal fuse. Don't know what else to try.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 07, 2011 | Dryers
Its a gas dryer. Starts up but no heat. Ignitor doesnt glow therefore no flame. Checked with ohm meter , seems good . Also checked coils for gas valve,checked out good . When you start up there is no power...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Gas valves works off of amps pulled by the ignitor...ohms doesn't matter..
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 06, 2010 | Dryers
When the dryer is cold the heater flame will
The heating circuit is working perfectly except for the solenoid coils as indicated by the occasional glowing of the igniter but no gas is ignited. A gas valve closes as the solenoid coil weakens as it gets hot and does not open until it has cooled down. Replace both gas valve solenoid coils to get the dryer back into proper operation. The solenoid coils are part numbers 694539 and 694540 but also can be purchased as a kit here.
Apr 27, 2010 | KitchenAid KGYS850LT Gas Dryer
Dryer starts with heat. After 10-15 minutes, when dryer calls for more heat, here a metal clicking noise, flame does not ignite. When it's clicking, I can look down the back from the top and see a glow....
Your gas valve coils are defective. Part #694539 and 694540 are required. Once the coils get hot they collapse internally and the gas valve shuts off. This is a common problem when valve coils get weak from use.
Nov 09, 2009 | Whirlpool LGQ9857L Gas Dryer
No heat, no flame, temperature based high heat
if the dryer doesn't shut off you need a new timer. have you replaced the igniter or glow coil? it needs to glow white not orange in order to ignite the gas.
Oct 11, 2009 | Whirlpool LGR5636PQ Gas Dryer
Kenmore 80 series gas dryer has not heat
most of these dryers have a little plastic plug on the front, left side. pop that plug out and look inside after turning it on. you should see a red glow. if not, then your ignitor has broken. if you see a glow, then the problem is probably one of the two little coils on the gas valve. these coils will sense if there is something to light the gas [the red glow] and open the valve - if the coils are bad, they won't open the valve
Aug 17, 2009 | Kenmore Dryers
Gas dryer does not heat GAS DRYER DOES NOT DRY CLOTHES WITH HEAT
check for igniter to be glowing, remove the plastic tab on the front panel an start the dryer
if it glows igniter is ok takes about 30 seconds to glow.if it glows is ok.
then check the thermal fuse for conitnuity an if it checks ok
then you have bad coils. replace the coils an ur done
May 26, 2009 | Frigidaire GSGQ642A Gas Dryer
GE Gas Dryer Model #dbvh512gfoww heat problems
Hi, It sounds like the coils on top the gas valve are bad. If the ignitor glows but shuts off before a flame, the coils need changed.
I hope this helps. If I can assist you further, please let me know.
Thanks
Vic
May 24, 2009 | GE 7.0 Cu. Ft. Super Capacity Gas Dryer -...
Kenmore 73932 Gas Dryer Logo
66 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
