Question about Canon PIXMA iP5000 InkJet Photo Printer
Green tinge on Canon pixma ip3000 photos
I have a Canon ip3000 pixma printer that has always produced good photo prints using re-filled cartridges from catridge world, but just recently all the photo prints are coming out with a green tinge to them.....reading previous Q and A's it seems I may need to clean the print heads how is this done,(I have run the normal printer cleaning tasks several times to no avail.)Many thanks
  • 19 Answers
SOURCE: Canon i865 Printer produces green
Here is a web-site Canon has on this issue, you can select your operating system and manually adjust the tint, or you can perform deep head cleaning.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=232&modelid=9387
-Hope this helps.
Posted on May 19, 2008
  • 49 Answers
SOURCE: canon pixma inkjet ip3000 driver
try this link
http://www.download.com/BJ-Printer-Driver-Canon-Pixma-iP3000/3000-2116_4-10555913.html
Posted on Jul 06, 2008
SOURCE: Printer will not use the magenta color
I had the same problem. It is most likely that your print head nozzles are clogged. Your choices are to attempt to manually clean them, or order a new print head from Canon.
Attempt the manual cleaning at your own risk, this doesn't always work. When it does not work, it means your print head is damaged.
To maually clean the print head. Printer cover up (so you can get to the cartridges and print head). Turn the Printer Off. Remove all the cartridges (I put each cartridge in a separate zip lock bag). Then flip up the lever and remove the print head.
Now heat (don't boil) distilled water (Iused a good sized cook pan and a plastic measuring cup to pour the water). Find a container you can soak the print head in (I used a deep alluminum baking pan). Pour the hot (not boiling) distilled water over the print head molding where the cartridges seat down (hold the printhead over your diposable alluminum pan). Then dunk the molded print head part into the pan numerous times. When the water gets dark change it (be carefuill not to stain the sink). Then slowly pour the hot distilled over the print head (opposite side from where the cartidges seat in). Eventually no ink will be in the water. Set the print head on a dry paper towel, and let it dry for 24 hours or longer. Reinstall the print head, then the catridges. If it worked, your true colors will return. It make take up to 15-20 photos to get all the ink catridges flowing-be patient. You can also just wait 24 hours after re-installing the cartridges, and hopefully it will take less photos to see the correct color match.
Never keep printing when a cartridge is low or out.
Print a few prints every week. Not printing for weeks causes the printheead and the ink flow to clog!
Good luck. I just recovered my S820 and my i900D using the above cleaning method. Like everything else, your mileage may vary! It cost me $1.29 for distilled water and about an hours worth of time!
Posted on Oct 20, 2008
hashchathy
  • 246 Answers
SOURCE: Canon Pixma iP3000- How to Clean Heads
if you have the uninstall programe use to clean it.
Or use the add remove programe to clean this programe
Posted on Jan 08, 2009
I've just replaced the black ink cartridge on my Canon Pixma IP3000 but it is not printing - absolutely blank. However the colour cartridges are printing fine. Any clues?
Assuming a windows computer ... go to the printers section, right click on the IP3000, click on propterties then the maintenance tab. Try cleaning or deep cleaning and then nozzle check.
Feb 01, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
My pixma 3000 prints blank pages . iot was working until i installed a new black cartridge
my canon pixma ip3000 prints blank, I have tried all the maintenance functions but still prints blank. pls help...
Jul 20, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
I want to print with black cartridge only but
The best option is to click on properties when you're going to print and select grayscale. I believe this uses mostly, if not all, black ink.
Apr 11, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Can't switch up my Canon iP3000 printer
Problem solved - I bought a new printer. On a long run it is cheaper.   Thanks    Mila
Apr 10, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
ALL PRINTING COMES OUT GREEN
this is a diffusion in a printhead. Check your print head
Thanks,
Mar 21, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Colour photo printing has a green tinge
This could be one of many things.
Monitor Calibration to Printer.
Camera green Bias
And good many more
The thing is not to print direct from camera , but to use an image editor to colour correct.
A free simple one is Googles free Picasa.
Otherwise there are many more some free a lot to be paid for.
As always there is a learning curve.
Sep 09, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Black and white photo printing
Paste the address below in your browser.You might find some vital information there.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10238
Jul 09, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Problem with the color - Canon Pixma ip 3000 Ink Jet printer
go 2 printing preferances and make shore all your setting are on normal or higher and try again
Nov 28, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Streaks on photos
Take out your ink cartridge and clean off the bottom of it with a damp cloth.
Jun 14, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP5000 InkJet Photo Printer Logo
77 people viewed this question
Clive
Clive
old marine
old marine
