Question about Kenmore 24032\24036 Top Load Washer
Loose basket my kenmore series 80 washer actually works but the basket is loose enough that I can move it in a fairly wide circle if empty...it also gives me that wonderful thumping noise like I need to redistribute the load on loads I wouldn't have imagined...any ideas?
  • 640 Answers
The block drive is worn..
Posted on Dec 28, 2008
My washer fills up with water and quits after that, it makes a buzzing noise when it should start its cycle. what can i do to fix this? it is a kenmore series 80
This could be a capacitor, which gives the motor the 'spark' to start, or the motor itself. If you try to move the empty machine's basket by hand, is it hard to move or does it spin freely?
Joe
Aug 29, 2011 | Kenmore Washing Machines
Kenmore 80 series top load washer. Will work on
if that arm is white and inside your clutch assy,that is the brake release arm that releases the brake to allow the basket to spin. it has 2 little fingers on it that lineup on the brake release cam, also check the bottom of yuor basket drive tube see if it has worn down or if the clip is there that holds that arm in place
Feb 21, 2010 | Kenmore Washing Machines
Kenmore series 80 washer off balance
Go to www.applienceparts.com and ask them for assistance, it is a free service.
Mar 13, 2017 | Kenmore Washing Machines
My kenmore 80 series inner tub is banging when it spins. It seems loose. Any suggestions?
There were a few of those where that would happen. The basket drive would come loose. Some had the drive block break. But either way you will need the spanner wrench to fix it.
Dec 30, 2009 | Kenmore 24032\24036 Top Load Washer
Will not spin
Check the motor coupler, or the drive block may be spinning on the basket drive. Some of these would break loose. Eric
Sep 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series model 110 after wash clothes are left soaking
when empty and off, open the lid and see if you can rotate the inner wash basket by hand. if you can easily, then the clutch is worn. This will prevent the basket from going into a high spin and wringing the clothes out. Replace the clutch by removing the top control panel, removing the clips that hold the cabinet, pull cabinet off, remove drain pump clips and pump, remove motor clips and motor, remove transmission (3 bolts). Now you will have access to the clutch, replace as needed, reverse dissasembly to complete. remember to unplug.
Jul 01, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 washing machine won't spin
No belts on that washer. You need a new clutch, the clutch cant grab the basket drive tight enough to spin. I will try to add a tutorial on it tomorrow. Look here for tutorial. www.shop.washermd.com Dave
Jan 05, 2009 | Kenmore 24902 Top Load Washer
Kenmore series 80- spin cycle does not spin
possible bad bearings in basket support asm or bad basket drive asm both pretty big jobs
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 Series
check the balance ring on the top of the basket it has either came loose from the basket rim or the fluid inside is not there
might need a new one
Jun 17, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
131 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
