Question about LG GSA-2166D DVD RW Dual Layer Burner
Computer Does Not Recognize Device
I am running Windows XP. Basically I have had this drive since xmas and it has worked flawlessly, burning around 10 movies for me for about two months. I would most oftenly set it up to burn at night as I slept. I am sure there is a good explanation for it but for some reason out of the blue, the LG GSA-2166D drive is no longer recognized by my machine. The Device Manager on my machine lists it as "unknown device" but it is easily recognized and used on my girlfriend's computer when plugged into any USB ports as it used to be on mine. So the problem is not in the device but rather in my USB bus or otherwise. It has been stated on other threads regarding this model that there is no need for any driver for this drive to operate however it might be useful to say that on my girlfriend's computer on the device properties (driver) tab it lists Driver Version: 5.1.2535.0 and then the Driver Details button lists 2 driver files: C:\WINDOWS\system32\DRIVERS\disk.sys (File Version: 5.1.2600.2180\xpsp_sp2_rtm.040803-2158) C:\WINDOWS\system32\drivers\PathMgr.sys (File Version: 5.1.2600.0 (XPClient.010817-1148) Whereas my device property (driver) tab lists Driver Version: 5.1.2600.0 and then the Driver Details button pulls a dialogue box stating: "no driver files are required or have been loaded for this device" As I understand it, firmware has to do with helping my drive use different media types and does not help my computer use the drive itself. But since I have seen this firmware file mentioned on several threads regarding this issue, I have tried to run the .exe on this website: http://forum.rpc1.org/dl_firmware.php?download_id=2226 but it will not run stating: "can not initialize!: 2815" This was after uninstalling and reinstalling WinRAR evaluation copy. Just for good measure I tried to update my machine but it is already running current patches. I got into Device Manager, expanded "IDE ATA/ATAPI controllers" and uninstalled Primary and Secondary IDE channel. After uninstalling and restarting, I got messages stating that new hardware was found and then to restart a second time to install drivers associated with the hardware (IDE channels). The LG DVD drive is still not recognized when plugged into the USB ports but when plugged into my girlfriend's computer, it is recognized right away and works fine. What's going on here?
  • 5 more comments
  • ffjabu Apr 12, 2008
    i ve problem when i connect hardesk to usb port ist showing 'no file found'!!!
  • Anonymous Jul 03, 2008
    my pc said i must install a lower version of firmware
  • Anonymous Aug 31, 2008
    The Same Problem
  • Anonymous Sep 16, 2008
    Device was working. new lap top. not recogizing writer. needs the same or older firm ware.
  • Anonymous Nov 30, 2008
    drive worked perfectly for a few months, now computer does not recognise the device and the power pack died a few weeks after we bought it. agree with others, it's the worst piece of hardware.
  • Anonymous Dec 18, 2008
    i have the same problem
  • mohammedyous Feb 09, 2009
    MY DVD R/W TRAY DOESNT OPENS
Dude, I threw my HP DVD writer out the 2nd story window after HP customer service in India tried to charge me for help, bought a different LG DVD writer, had the same problem. I have been on the computer for about 24 hours in the last week trying to fix this problem...
I researched every computer assistance blog on the net
I edited my registry about a billion times
I took out my usb from the device manager
I downloaded new drivers
I rebooted at least 15 times
I went into disk management
I went into services
I contemplated throwing the computer out the window and all the time I have wasted in my life troubleshooting computer problems.
I contemplated a world without computers.....
I even called tech support for LG (not located in India thank god).
And then I came across this page and the unplugging and plugging worked. Doh!
Posted on Aug 27, 2008
I had the problem described above with this device. I found the solution below on another site and was shocked that it actually worked! 1. Unplug the LG burner USB cord from your PC 2. Unplug the LG power cord from the burner itself 3. Wait 1 minute 4. Plug back the power cord to the burner 5. Plug back the USB cord to the PC I believe the key is to respect the sequence of cords unplugging... At least that worked for me!
Posted on Jun 04, 2007
    President:
  • 2,961 Answers
Firstly the ide controllers you mention are only for internal devices like you hardrive and internal dvd writers, not usb peripherals. If you have service pack 2 on your system there should be no problem it could be that your usb port is faulting. You can locate the drivers that are on your girlfriends pc, they will be exactly in the location that you have typed in your post and copy them to a disc and paste them into your windows operating system in the same folder eg C:\WINDOWS\system32\DRIVERS and the other mentioned driver to see if it works. If not try another usb port or go to My computer>right click>properties>hardware tab>device manager and at the bottom of the list you will see everything to do with your usb port controllers. Right click on each controller and select uninstal and then restart your pc, the drivers that you put on your system should then automatically load when your pc finds the usb controllers again on start up.
Posted on Apr 23, 2007
    Master:
  • 551 Answers
Your may be caused problem.
Posted on Mar 26, 2013
Unplugging and plugging worked GREAT!!!
I owe a beer to the guy who came up with this solution.
Posted on Jan 17, 2010
Yes! I'll have to concur!
This problem has plagued my for quite a while now with my LG GSA-2166D.
The unplugging trick in solution #2 really works! Didn't even have to reboot.
Next I'll have to see if simply unplugging the power will work. I already know that unplugging and replugging the USB cord alone doesn't work. We'll see..
Posted on Nov 11, 2009
Noobs Buy a new one mate
Posted on Aug 21, 2008
Strange, i did what you said and just unplugged it and waiting a minute and plugged it back in and it recognized it fine, :) strange but whatever works right?
Posted on Jan 10, 2008
Shut up
Posted on Jan 05, 2008
I must say I did try the unplug and wait then plug back in using the steps from the first post and it worked no problem. Thanks
Posted on Sep 08, 2007
My computer no longer "sees"
hello
at end of this instruction set, see link to review more questions/answers,as your issue with CD/DVD ROM will vary .
This document applies to HP and Compaq desktop computers with Windows XP, Me, and 98. Use this document to make Windows and the CD writing software recognize the CD or DVD writer drive. Start at Step 1; do not skip to other sections until Step 1 has been completed. Step 1: Does Windows detect the CD or DVD drive? Use Device Manager to determine if Windows is recognizing the drive:
  1. In Windows XP, click Start , and right-click My Computer . In Windows 98 and Me, right-click the My Computer icon on the desktop.
  2. In Windows XP, select Properties , click the Hardware tab, and then click the Device Manager button. In Windows 98 and Me, select Properties , and click the Device Manager tab.
  3. Click the plus sign (+ ) next to DVD/CD-ROM Drives (or similar) category.
  4. Do the following depending on what is listed in the DVD/CD-ROM drives category:
    • If the CD or DVD drive name is missing , the drive is not being detected by Windows. Close Device Manager and skip to the section CD or DVD drive is not recognized by Windows .
    • If a drive name is shown but is disabled (icon is marked with a red X, c00877300.gif ), the drive has been disabled. Right-click the drive name and select Enable . You may have to restart the computer to complete the enabling process. The drive should work correctly once it has been enabled. NOTE: If the drive cannot be enabled, a required service or driver that the drive needs is not functioning or has been disabled. Click the plus sign next to IDE ATA/ATAPI controllers and troubleshoot any problems found according to any error codes in Device Manager. Resetting the BIOS may also resolve this problem.
    • If a drive name is shown but contains an alert icon (an icon marked with an alert symbol, c00877301.gif ), then use the section Using Device Manager error codes to troubleshoot the problem. You may also use the next section Disc burning software does not recognize the original drive to reset the drive configuration.
    • If the CD or DVD drive is listed as normal but your disc burning software does not recognize the drive, Device Manager shows no special icons c00877302.gif . Windows is detecting the drive but the writing software does not. Leave Device Manager open and continue with the next section Disc burning software does not recognize the original drive .
here is a link that will give you several other questions and answers to CD/DVD ROM issues.
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=11843&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=443069
please rate me with 4 thumbs UP to keep my services active
Dec 01, 2010 | HP Pavilion a810n (PP164AA) PC Desktop
Tip
How to link gpx mp3 player to pc?
1. Connect your ML648B to your computer with Windows XP or later.2. By default your computer will recognize ML648B as GPX MTP Device. (Wait for few seconds to a minute allowing your Windows computer to recognize and install necessary drivers for the device for first time as MTP Device.)
3. Press the POWER button from top of your ML648B, to change it to USB mode connection. You will also see USB on the screen of ML648B.(Wait for few seconds to a minute allowing your Windows computer to recognize and install necessary drivers for the device for first time as USB device.)
4. ML648B will now mount 2 drives, one as Tools (as CD-Drive) and second as Removable Disk (Drive) – under My Computer on your windows desktop.
5. Double click & open Tools, and run Setup.exe to start installing Video Conversion Software tool.
6. Select defaults options and finish the installation by clicking on Close or Finish.
7. If asked, click on Continue Anyway on Windows XP or Install this driver software anyway on windows vista.
This will help.Good Luck.
on Mar 10, 2010 | Audio Players & Recorders
Computer won't recognize external hard drive anymore
Have you tried changing the USB cable or connecting it to a different USB port on the computer?
Nov 14, 2017 | Western Digital 320GB MyBook External USB...
Will not connect to my computer, shows zzz on screen
3. Press the POWER button from top of your ML648B, to change it to USB mode connection. You will also see USB on the screen of ML648B. (Wait for few seconds to a minute allowing your Windows computer to recognize and install necessary drivers for the device for first time as USB device.)
4. ML648B will now mount 2 drives, one as Tools (as CD-Drive) and second as Removable Disk (Drive) – under My Computer on your Windows Desktop.
7. If asked, click on Continue Anyway on Windows XP or Install this driver software anyway on Windows Vista.
Jan 23, 2009 | GPX ML648B MP3 Player
Error Installing Utilites Software
<!--[if !supportLineBreakNewLine]-->
<!--[endif]-->
Jan 15, 2009 | GPX ML648B MP3 Player
Having problem adding this device to my computer
Dec 30, 2008 | GPX ML648B MP3 Player
Unit doesn't link with pc
Dec 27, 2008 | GPX ML648B MP3 Player
Ipac connecting to dell lattitude d620
With pda's the machine is going to recognize and class them connection then device, no way around that. You can get it working in the Dell by adjusting your firewall settings in the security center. There is a section that allows you to add exceptions to the firewall, add the programs for the pda and you're good to go.
Jul 17, 2008 | Dell Latitude D600 Notebook
Inability to recognize Kingston pendrive in windows98
Windows 98 is not capable of recornizing the mass storage devices, but windows 2000 and XP, vista has the capability to automatically recognize the USB mass storage devices.
Thats why your Windows 98 is not recognizing. So, to use the mass-storage device like your pen drive you have to install device driver to your windows 98 system for your pendrive.
If you don't have the driver, then goto pendrive manufacturer site, there you can found the driver for your pen-drive for windows 98, download it, and install on your windows 98 system..... n njoy,,... :))
Thanks
Iqbal
iqbal_delphidev@yahoo.com
Mar 23, 2008 | Microsoft Windows 98 for PC
Windows XP not recognizing cds/dvds in my HP DVD640i
Most likely your CD-DVD burning software is corrupted. When that happens, the machine doesn't recognize the existence of the CD/DVD hardware. Clean up your machine, defrag, run a freeware registry cleaer-defragmenter (see C-net for a good one). Then Reinstall/upgrade your burning software (the Windows XP software is not sufficient) either from HP/Compaq, if it came with your machine, or the program website if you purchased it separately. You may find out which it is by using a marvelous freeware program called Belarc advisor.
Feb 11, 2008 | HP LightScribe dvd640i (DVD640I)...
LG GSA-2166D DVD RW Dual Layer Burner Logo
2,567 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
