Question about Dryers
I have a GE DPSQ475ET4WW electric dryer and I am trying to replace the belt. I am confused on how the belt is to be run from the shaft of the motor and around the idler arm. I understand that the belt must have the rubber side down on the drum. Please advise.
  • Dryers Master
  • 8,220 Answers
The ribbed side goes down on the drum. I lay the new belt on the line that was made by the old one on the drum. I make sure it ain't twisted.You cannot see how to hook the belt because you are sitting in front of the dryer on the tailgate of a truck or on something up high like a good work table. I reach inside with my big old fat arms and I make sure the belt is on the bottom of the motor pulley. I raise up the idler arm, say a cuss word or 2 and I wrap the belt over the top of the idler pullley so that when I let loose of it it holds the belt firmly in place. I rotate the drum slowly to make sure everthing is kosher. If I am working on a dryer with a rear access panel it is much easier. But I don't believe yours has one.
Click here for a photo of various belt routings.
Posted on Dec 27, 2008
GE dryer turns on but doesn't spin
Probably nothing but a broken belt. Ge dryers can be tricky. Most of them cannot be accessed from the rear anymore. Lots of videos on youtube now that show how to replace a dryer belt on a GE dryer.
Mar 20, 2014 | General Electric GE 7 0 Cu Ft Super...
Was drying cloth and just stop working, the element comes on but no running of drum
Most electric dryers are 220V and are essentially 2 -110V circuits.. You should have either 2 circuit breakers or two fuses supplying the power to the dryer . One is probably tripped or blown. Either reset the breaker or replace the defective fuse and you should be in bussiness!
Feb 16, 2011 | Whirlpool LER4634J Electric Dryer
Dryer has electricity but the drum will not spin
Hello there:
If your dryer doesn't tumble, check these:
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Sep 27, 2010 | Whirlpool LER4634J Electric Dryer
My dryer was making a loud squeeking noise while drying, now it won't start, I can hear it trying purring but than it does not start, help!
if you can hear the motor running,and if this unit does not have a belt shut off switch,the motor will run even if the belt is broken,the squeaking noise earlier was probably the belt starting to slip on the drum,replace the belt and drum glides when repairing,they are relatively inexpensive and as long as its torn down replace these too
Sep 15, 2010 | GE DCSR483EA Electric Dryer
LG DLE5977W electric dryer hums when attempting to restart
This is usually the motor but not always. Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers, pulley, rear bearing, then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. You can also enter your model # for diagrams and illustrations at www.appliancehelponline.com
Mar 31, 2010 | LG DLE5977 Electric Dryer
I have an old GE dryer model DDG5380valwh. When try to start it it just hums. What should I do?
** ALLWAYS unplug a dryer before working on it.
Humming means the motor may not be turning.
The motor could be 'capacitor start'. Replace the capacitor.
The motor could be centrifugal start. Remove the belt. Still won't start? Replace the motor.
The motor bearings could be seized. Rebuild the motor or replace it.
The belt may be broken if the humming is a higher pitch. Replace the belt.
The drum may be jammed. Clean and lube the main bearing (Use Maytag Turbine oil or the recommended lube), the support wheels or the guides. Replace felt seals at the same time for best results.
Mar 22, 2010 | GE DWSR405EBWW Electric Dryer
I have a kenmore 80 series electric dryer. It gets
If your dryer doesn't tumble, check these: Belt Motor Door switch Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Thanks for choosing fixya...Regards, Joe
Nov 13, 2009 | Cars & Trucks
GE Profile dryer Model# DPSQ475ET4WW
You posted under a DPGT705EC and then a DPSQ475ET4WW, so I am going to guess you have the later one. If it has not been squeaking for an extended time you can get by with just changing the rear drum sleeve bearing (WE3X75). To do this, use a putty knife to push in on the 2 clips about two inches in from the sides at the seam where the front panel meet the dryer top, allowing top to swing up and back. Remove screw holding front panel to side panel near top just under where the top was. Tilt front panel forward and lift off bottom pegs. Swing to side (you don't have to remove wires). Pull drum forward about 6 inches. (you don't even have to remove the belt.) Change sleeve at center back of drum. Make sure to inspect the front drum support slides WE1M481dark ones and WE1M333 white ones (about 1/2 inch x 2.5 inch strips at the top of the front panel which support the front of the drum), as about the time the rear bearing goes, these may be wearing also, especially the one on the left side. You may have to contact GE to obtain an owner's manual (but there is nothing in them about how to service the dryer, just installation and settings, etc.) Parts can be obtained from just about any appliance service company or appliance retailer which does service in your area.
Nov 19, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryer repair
No. the belt is replace from the front, UNPLUG UNIT..remove front panel belt is looped over drum that way. Much eaiser to remove acess panel behind unit to reattach belt to idler and motor shaft, spring problably popped off idler, or motr shaft reattach and pull idler all the way to right and loop belt around motor shaft and relese(pulley should add tensionto belt)
Feb 26, 2008 | Frigidaire GLER642A Electric Dryer
Dryers Logo
106 people viewed this question
Top Dryers Experts
