Question about iLO LCT32HA36 Television
LCT32HA36 Power Supply went up smoke.
Where can I get a replacement powersupply board for the LCT32HA36.
You can probably fix it yourself. If your board failed the same way mine and seemingly almost everyone else did, its actually a very simple fix.
Up where all the cables plug into the board are 3 capacitors, running perpendicular to the inputs. They are the 3 BETWEEN the two black heat sinks. Those 3 have a habit of over heating and going bad. its easy to tell... the tops should be slightly bulging outward and you may even see specs of brown on top. If that's the case, you've got it easy. Go to Radio Shack and buy 3, 35v 1000uF capacitors, item # 272-1032. They're $1.59 ea. Use a soldering iron to take out the old capacitors, fit the new ones in, and replace the board into the TV. The new ones are a bit larger, but fit just fine. I suggest setting all 3 in BEFORE soldering them in, just so you can be sure they are in good position.
I bought all three capacitors, solder, and an iron kit for $35, about $150 cheaper than a new board. Its a 10min job and well worth the effort.
Posted on Jan 08, 2009
  • rbpsf Nov 27, 2010
    great fix -- thanks for sharing your solution!
My tv shut off and now no power at all its a Ilo 32HD
Fault with the main power supply regulator board.
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Jul 30, 2014 | Generic 32 ilo lct32ha36 1080i hdtv...
Fuses keep blowing in tv
The tv have a short in many parts internally in tv power supply board itself could be anythings on the tv power supply board to causes the fuse to blow over and over again.U will never solved it if u don't have all the measuring elecronics equipments and skills and know how to find out.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Aug 11, 2011 | iLO LCT32HA36 Television
Our Polaroid FLM 3232 has worked for four years and now all of the sudden it won't turn on....seems to be no power supply...the red standby light is not illuminated....please help we love this tv!
I hate to say it, but it is prob the main board that went bad. (the board where all the inputs get plugged into) It is possible that it might be the power supply. One thing to check is to make sure you have 25v coming from the powersupply board to the connectors that plug into the main board. If you do have 24-25v than you will have to replace the main board. If not than the powersupply.
Dec 26, 2010 | Polaroid FLM-3232 Television
LCT32HA36 Television does nothing. The standby light does not come on when plugged in.
Check the power source?Yes,than the tv power supply board it dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Oct 29, 2010 | iLO LCT32HA36 Television
My TV will only turn off and on. No other
Power light blinks?Ur power board is dead.Replacd the power supply board will solved this problems.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Feb 15, 2010 | iLO LCT32HA36 Television
Looking for I-C in power suppy of ilo tv model no. lct42ha36 I-C is mc0628r . jhartley42@yahoo.com
Will never ever find IC alone,U lucky even find the whole power supply board .Tries Shopjimmy.com.Ebay.com for refurbish power supply board.
Jan 15, 2010 | iLO LCT32HA36 Television
Teco lcd tv ,
Its most likely the power supply. If you open up the back and look at the caps. There might be some bad ones and they most likely are bulging. It should cost about $5 to replace them. If the power supply is good then its the power circuit board.
Jun 09, 2009 | iLO LCT32HA36 Television
LCT32HA36
Check the capaciotors in the power supply for bulging conditions.
Click here to have an idea how they might look like.
Good Luck.
Jul 12, 2008 | iLO LCT32HA36 Television
No power
I have one that I just got working. It seems there is 5 capacitors in the main power supply that were leaking. If you are good with electronics and soldering, open it up and look at the power supply where the main AC cord plugs in. There will be can type capacitors towards the top. Look for the ones where the tops are bulging. I found 5 like this. Three were 1000uF 16V, and two were 1000Uf 25V. I changed them out and it is back up and going!! Good luck!!!
Mar 17, 2008 | iLO LCT32HA36 Television
iLO LCT32HA36 Television Logo
459 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
