Question about Bosch Dishwashers
Dishwasher not working porperly
About 2 months ago our bosch dishwasher flooded our kitchen. Tried using it one more time and had been working fine since then. Just the other day, it seemed to never stop running. We opened it, and It did clean the load that were in there though. Used it one more time later that evening, and the unit ran for a very long time. When we opened it, the dishes were still dirty. As if no water ran through the unit. Is it worth having someone come ou to fix, or buy a new one. What do you think is worng, and is it something easy to fix?
Thank you
    Genius:
  • 1,239 Answers
Hi The strainer is located directly under the lower sprayer arm. When the strainer becomes clogged with food and detergent debris, the dishwasher may flood or overfill. On some dishwashers, the strainer is a plastic or metal component consisting of two semicircular halves. To remove this type of strainer, pry it up. On other dishwashers, the strainer is a one-piece component. To remove this type, remove the cap that holds the sprayer arm on its shaft. Then remove the sprayer arm and the strainer.
Wash the strainer in the kitchen sink with water and a mild household detergent. Use a fairly stiff brush to get all the debris out of the holes and slots in the strainer. Rinse the strainer well and replace it. If part of the strainer lifts out for regular cleaning, check it and clean it -- if necessary -- after each load of dishes is washed. dishwasher not working porperly - 5816552.jpgc9d5dd9.jpg
Posted on Dec 27, 2008
  • ABHISHEK.C
    ABHISHEK.C Dec 27, 2008
     check the filters and grinder . The drain that it is hooked to is working or not.Is it hooked to a garbage disp. If so make sure the knock out is out. Then if you can use a volt meter. take off the 2 screws at the bottom of the unit on the left side is your drain pump. take off the 2 wires put your meter on ac and put your leads on the wires then run it in a cxl cycle. (the cxl will depend on your unit you will press two buttons @ the same time and hold it it will light up 2(2min))
    if you get 110 you have a bad pump........
  • ABHISHEK.C
    check detergent dispenser also,there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishes. the dishes look dirty because your water has a lot of calcium and magnesium in it making them appear cloudy or dirty. the dishwasher filter reduces those minerals and my dishes look perfect now. no more dirty and grimy looking dishes. i also dont waste time washing them by hand before and after the dishwasher. hahaha you can get it at dishwasherfilter.com. use code DFMTEN and you will get 10% off. it fits right under your sink and is very affordable. you will be glad you bought this product. thanks
    Sergeant:
    Novelist:
  • 327 Answers
Bosch model SHX68T55UC/02 Completely dead after 2 inch flood in kitchen.
You will need to remove the unit from its installation in the cabinetry. Check the wiring connector located on the rear of the base, near one side. The wire connection must be clean, dry and securely snapped into place. If this connection is burned, distorted or won't allow the plug (special shape) to click securely into place then it should be replaced. Since the unit is totally dead it would appear there is no power reaching the control module, But, you can also confirm that water did not overflow the top of the dishwasher base pan and allow water to enter the pump motors (there are two.) If so these must be thoroughly dried. They may be damaged if power was supplied to a motor with water in the winding and contacts.
Oct 03, 2016 | Bosch Dishwashers
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 | Dishwashers
Have a hotpoint dishwasher full of little black
I have a Bosch SMS 4012 works fine till cycle finished. when I turn it off it trips the power safety switch at the switch board. To prevent trips happening I have to switch off at the power point and unplug .The washer is 20 years old and the problem started around 3 months ago.Is it a major problem.
Frank. C
Feb 15, 2010 | KitchenAid Dishwashers
Dishwasher: BOSCH SHE43 - pump keeps draining
Your dishwasher is stuck in flood mode. Bosch dishwashers are built with flood switches located in the bottom base pan of the dishwasher. The flood switch is connected to a rod that activates a small interlock switch. When water enters the base pan on a Bosch dishwasher, a Styrofoam puck lifts the rod, activating the flood switch.
When the flood switch is activated, the dishwasher will go into a no-fill, only-drain mode. The drain motor may also run with the door open to the unit. This is definitely a sign there is water in the base pan. This can be caused by the drain being clogged. There are two ways to fix:
1. You can uninstall the dishwasher and tip it forward to about a 45 degree angle to drain the water out of the base pan. (This is probably why Ian Bint's solution fixed the problem.) Be sure to put a towel under the dishwasher first so that the water is soaked up in the towel instead of going all over the floor. Once you've drained all the water out of the base pan, reinstall the dishwasher and begin a cycle. If it fills and runs, you are good to go.
2. You can also unplug the unit, then remove the kick panel at the bottom in the front. (It's attached with two screws.) Then get some old washcloths or small towels and reach into the base pan below the dishwasher to soak up the water. The pan is directly behind the plastic base panel rim. Once the pan is empty and dry, your dishwasher will no longer be in "flood mode" and will run properly.
If the base pan keeps refilling with water and the no-fill problem returns, there is definitely another issue, such as a clogged drain. At this point, you need to decide whether to invest in an expert evaluation by a certified Bosch repairman and make the necessary repairs, or buy a new dishwasher.
Jun 28, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Contunuous draining turned into a flood when unit powered off
The fill valve is governed by the float switch. I doubt that your fill valve (solenoid) has failed.
Focus on replacing the float switch and you should be all set.
Good Luck!
May 09, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Nov 26, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch dishwasher regularly floods
fault is with dishwasher. even if drain blocked, would not cause overfill.
possibly the pipe to sump from fill mechanism partially blocked
Jul 18, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Broken dishwasher
I have a kenmore model 665 168 29000 the mounting bracket have broken from under the cabinet, so when you open the door and pull the racks out the machine moves forward, how can i fix this?????
Mar 08, 2008 | Bosch 23 in. SHU33A Built-In Dishwasher
Dishwashers Logo
55 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
