Question about Kenmore 72222 / 72224 Bottom Freezer Refrigerator
Ice maker not making any ice.
Recently, the ice maker quit working. Always worked fine up until a couple of days ago. The freezer is working fine and fridge side is cool. No issues with the temperature on either side. What are the first few specific things I can look at that are the usual culprits for this. We have not adjusted the water pressure and no major changes with water system have taken place. It sounds like the cycle gets shut on, just no new ice being made. Thanks for any help you can provide.
  • Ryan Pichardo Apr 23, 2007
    Forgot to mention, this is a Maytag side by side fridge, model # MZD2766GES
    Thanks
  • oneloridr Jan 05, 2008
    maytag mzd2766ge ice maker isnt making ice. the water dispenser on door still works fine and the water tube to the ice maker is clear and empty. how can i check the dual inlet valve?
    Novelist:
  • 114 Answers
UN-PLUG YOUR REFRIGERATOR !!!!!! AND THEN ... THE FIRST THING TO CHECK IS FOR PROPER WATER GOING "INTO" AND "OUT OF" THE SMALL WATER SUPLLY SOLENOID VALVE (USUALLY LOCATED ON THE BACK OF THE FRIG.WHERE THE WATER LINE GOES IN. TRACE WATER LINE BACK TO ITS SORCE ... TURN "OFF" THE VALVE. USING AN ADJUSTABLE WRENCH, LOSSEN THE NUT AND ENSURE YOU HAVE GOOD WATER FLOW.LEAVE WATER "OFF" THEN GO TO THE BACK OF THE FRIG. AND REMOVE THE NUT ON THE "SUPPLY LINE SIDE" OF THE SMALL WATER SOLENOID VALVE.... THERE IS A STRAINER AND ORFICE JUST INSIDE THAT CONNECTION ... CLEAN IT !!! DO NOT POKE A LARGER WHOLE IN THE ORFICE. REPLACE ALL PARTS IN THE REVERSE ORDER THEY WERE REMOVED AND TIGHTEN ALL CONECTIONS. TURN WATER SUPPLY BACK "ON".AND PLUG REFRIGERATOR BACK-IN. (ALWAYS WAIT ALEAST 15 MINUTES TO RESTORE ELECTRIC POWER TO ANY REFRIGERATOR). NOW JUST SLOWLY LOOSEN THE OTHER NUT ON THE "OUT-LET" SIDE LEADING INSIDE THE BACK OF THE FRIG. SEE IF YOU HAVE WATER. IF YOU DO ... YOU VAN NOW CHECK TO SEE IF THE SOLENOID IS WORKING.... JUST USE A BUTTER KNIFE AND PLACE IT NEAR THE TOP SIDE(COIL) OF THE SOLENOID ... YOU SHOULD FEEL THE "MAGNETIC PULL" ... IF YOU HAVE DONE ALL THE ABOVE AND YOU STILL HAVE PROBLEMS ... CALL A "LICSENED FACTORY-CERTIFIED COMPANY" TO DO A "FLAT-RATE" DIAGNOSTIC CHECK ON YOUR CIRCUITS. ALWAYS GET A "TOTAL COST" ESTAMATE BEFORE STARTING ANY REPAIRS OR SIGNING ANYTHING. NEVER LET A REPAIRMAN REMOVE AND LEAVE THE HOME WITH A DEFECTIVE PART AT ANYTIME HE IS THERE. (UNLESS THE PART IS UNDER VWARRANTY) NEVER BE AFFRAID TO WATCH AND ASK YOUR REPAIRMAN QUESTIONS. REAL PROFESSIONALS ARE HAPPY TO ANSWER AND SHOW YOU EXACTLY WHAT THEY ARE DOING... THATS BECAUSE THEY KNOW WHAT THERE DOING AND PROUD OF IT !!!!
Posted on Apr 27, 2007
My ice maker quit working.
Ice not being dumped out because the heating element designed to slightly melt ice so arms can push it out is non functional and needs replacement. Cheaper and better to replace entire unit at nominal cost.
Feb 12, 2015 | Kitchen Appliances - Others
I have a Frigidaire GSI 26, ffor the last couple of days it has been making a buzzing sound that lasts about thirty seconds to a minute, today the freezer quit working. the compressor is hot, as is th
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
I have a Kenmore side by side, model # 106.57032601 that I bought 4 years ago. The ice maker suddenly quit working. The refigerator/freezer work fine otherwise and I continue to have water from the...
Is your ice tray filling with water? If not, then I would suspect the water inlet valve (http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10657032601/0582/0165000/K0607002/00012?blt=06&prst=0&shdMod=10657032601 - Item 10)
If it does fill with water, but does not eject the ice cubes to start a new cycle, I would suspect the ice maker motor(Item 37). BUT if it is the motor, that part costs $91.22 and you can replace the entire ice maker (Item 100) for $157.95
Jul 10, 2011 | Kenmore Refrigerators
Ice machine isn't working
Two things come to mind.
First, the water valve at the bottom rear of the refrigerator may have failed. You didn't mention if there is a water dispenser and whether or not this is still working. This valve pumps water to the icemaker and water dispenser when the control unit of the icemaker calls for water. Also, there could be a blockage in the line which brings the water to the icemaker.
The other possibility is that the part of the icemaker controls which calls for water from the valve has failed. If this has happened, it would likely be more cost effective to replace the icemaker unit.
Oct 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker hasn't worked in years. A couple of days ago food below the ice maker was thawed. Today I felt that the ice maker was hot to the touch. Is there anyway to disengage the power to the ice make
Yes you will need to take the screws that mount the Ice maker to the side of the freezer and unplug the cable plug that is hidden behind the back of ice maker. The only time that element is needed to become hot is the moments before the ice maker drops ice. Thanks, Sea Breeze
May 15, 2009 | Kenmore Refrigerators
KitecheAid Ice Maker Porblem
check the temperatures inside of the freezer. It has to be at least 17.5 for the ice maker to work correcltly
Feb 07, 2009 | Refrigerators
Ice Maker stopped making ice - water dispenser is fine.
well first the icemaker valve and water despensor valve a separate so you might want to try but to change it out you have to change both valves cause they made together then also check and makes sure your tube is not froze up and if that aint it then change your icemaker now for a little tip the icemaker will not run as long as the freezer door is open
Dec 30, 2008 | Maytag MSD2456G Side by Side Refrigerator
SAMSUNG RS253BAWW NOT WORKING
the ice maker wont cycle untill the temp of the ice is around 10 degrees so if the freezer is at 15 or 20 due to some other malfunction then you will see the maker full of ice but it wont harvest and make another batch. so you could have a sensor bad, control malfunction, refrigeration issue, compressor, defrost system malfunction(you mentioned ice build up)
May 08, 2008 | Samsung RS2534 Side by Side Refrigerator
Maytag MTB2156GEQ Top Freezer not working
The compressor not working, relay switch on compressor not working Had repair man put new switch in .Last year put in new fan motor in freezer compartment the cool air was not circulating both problems made the fridge not to cool and drip water
Nov 30, 2007 | Maytag MTB2156GES Top Freezer Refrigerator
Kenmore 72222 / 72224 Bottom Freezer Refrigerator Logo
78 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
