Question about Pioneer PDP5016HD 50 in. Plasma Television
TV Will not turn on
Pioneer PDP-5016HD was working fine. I unplugged all cables to move to a new house. It was exposed to near-freezing temperature for about an hour. I set it up at the new house and it will not turn on. Note: Remote control still at old house so needed to use the side power button. I have confirmed that there is power to the socket we are plugging into (I tried a few to be sure) and that the power cord is correctly attached to the TV. Any ideas? Could it be that the remote is required to turn it on first time?
    Sergeant:
  • 233 Answers
Was the tv still "freezing cold" when it was plugged in? If so, then there was probably some condensation that formed on the circuit board inside the tv that could have shorted out an IC or another component. I saw this happen on a mitsubishi big screen - under the same exact circumstances. I removed the board, cleaned it with Isopropyl alcohol and a toothbrush, and dried it out with compressed air- after thet, it worked fine.
Posted on Dec 27, 2008
  • 916 Answers
Check the power fuse
We have a Pioneer PDP-LX 508a, tv will not tune in after moving house
If you're using the antenna socket in the house, the socket could be bad or the antenna needs replacing. It may also depend on what the general TV reception is like in your location.
Oct 12, 2018 | Pioneer Televison & Video
Moved to a new house, set up tv.........no sound. volume control moves but no mute to be found. no remote either.
Check the speaker either its disconnected to connector.try to open the cover of ur tv and check the connection of the wire to speaker.
Apr 04, 2011 | Pioneer PDP-6071HD 60 in. Plasma...
I have moved house and in the process the white and black cable went missing of my pioneer Pure Vision Plasma TV 50-inch PDP-504HDE. I need to buy a new one. Also, before the plasma screen was wall hung...
a stand can be found at a local electronics store like best buy or wal mart and the white and black cable is it power if so then that can be found online at a website like amazon or look at best buy
Jan 03, 2011 | Pioneer PureVision PDP-5040HD 50 in....
Pioneer Plasma TV-PDP-4270HD won't turn on. TV
Try this! There should be a power button on the bottom of the panel that has to be depressed for the television to power on. It is the main power supply button and without it there is no power going into the TV.
Mar 16, 2010 | Pioneer PDP-4270HD 42 in. Plasma...
Pioneer PDP-RX06XE has no picture
check PDP 436XPE UNIT may be Y board short...or need factory restore to the original state....
Nov 18, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
Plasma TV mod PDP-5016HD not turning on
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 27, 2009 | Pioneer PDP-5010FD 50 in. Plasma HDTV
Green blnking light on pioneer plasma - Picture does not come on
You can try a hard reset : Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck..
Nov 23, 2008 | Pioneer PureVision PDP-5030HD 50 in....
Pioneer PDP-503PU
Very possible,but yet,this might be the manufacturer defect power supply which they will fix it for you free;but before we jump to this conclusion,you need to test it first:
-Unplug the power cords.
-Unplug the media video cable from the box to the tv.
-Check all the pins on the video cable are in place as well as the connectors both behind the TV and the media box.
-Reconnect the media box and TV with the video cable(DVI+VGA in one) and have at least a video component hook up to it(ex. dvd player/VCR or comcast box) be sure this video player is turn on and running,at the same time,be sure it is under the right video input.
If you have tried the above steps but still doesn't work,call 1-800-pioneer Tuesday-Thursday at7amPST and address your issue to them.
Let me know if you have any additional questions!
solutiondoct
Oct 07, 2008 | Pioneer PureVision PDP-4340HD 43 in....
No sound
maybe in your cable box
Mar 30, 2008 | Pioneer PDP-4360HD 43 in. Plasma...
Pioneer PDP5016HD 50 in. Plasma Television Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
