Question about Acer Aspire 5500 5570-2609 Laptop
Laptop powers on but nothing on the monitor
Hi, my acer laptop will power on ,but thats it. I get nothing on my monitor,.. any help would be appreciated
  • 2 more comments
  • Anonymous Jan 21, 2009
    my acer laptop turns on but nothing on screen
  • Jennifer Keen
    Jennifer Keen Feb 11, 2009
    same problem
  • DoomScoopity Feb 11, 2009
    I have a new Aspire 5515 with Windows Vista. Whenever the system tries to update itself, the computer will start to reboot, then the "progress" bar will get stuck about 2/3 of the way through and stay there. The only effective solution to this, it seems, is battery/power cord removal. If there's a better way, I'd like to hear about it, please.
  • Anonymous Feb 26, 2009
    Acer Aspire One won't turn on, that is, the green power light is on but nothing on monitor. Also, the laptop sounds "hollow"?
Ic number of acer lcd monitor v193hqv?
Hi guys the pwm ic number in acer v193hqv is TEA 1530 AP.......
Aug 05, 2014 | Acer Computers & Internet
No display in Acer 4150 laptop after upgrading BIOS
HI,
Do a power drain, this may cause by an electrical charge in the motherboard itself,Im Not really sure how it affects the display of the computer but this method usually fix such problem like that, First, removed the battery then unplugged the AC adapter the press and hold the power button or the ON/OFF button for at least 30 seconds then connect the power supply back to your computer then turn it back on, if nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
Hope this will help...Your response is very much appreciated...
Jan 28, 2011 | Acer TravelMate 4150LCi Notebook
I have a blank screen when I turn it on and nothing happens but the sound works.
hi,
can you please try to power drain the laptop, removed the battery and the unplugged the charger then press and hold the power button or the on/off button for 15 seconds, obviously it will not turn on since there is no power supply connected, after 15 seconds, connect the laptop direclty to the power outlet without using the battery just for the meantime, then power on the laptop, see if theres any difference, if nothing happens, there is something wrong woth the monitor itself.
Jan 19, 2011 | Acer Aspire One PC Notebook
I put my acer aspire one laptop into standby by putting down the monitor which automatically lock the laptop but then when i use it again the monitor is dark and i cant see anything. the power is on and i...
ok, press the Power button on the Laptop once, and if nothing happens, press the power button again but this time hold it down until it goes off... then remove the battery for 2 minutes, after that put the battery back and press the power button, it should power on and the monitor will show. (Do not plug into power source during all the above process).
Bams Tech.
Dec 02, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer extensa 4630z was working with broken monitor but when i try to chang it it wont work anymore just when i press power on power led get light but nothing else happin pleas i need help
If you've changed the screen then it's possible it's not plugged in right or is faulty. You could always try and plug in another monitor and see if it works on that.
Sep 06, 2010 | Acer Extensa 4620 Notebook
Laptop acer 5570 wont power up
Check the BIOS battery. If possible, remove it and put it back to reset the settings.
Hope this helps.
Dec 21, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 7520 black screen wont boot
Turn off notebook. Remove the battery. Press Power button. Notebook should start working. Wait for 15 secs. If the screen still blank press Power button and hold it for approx. 4 seconds until notebook is powered off. Then press power button again. Bingo, problem should be solved.
Dec 19, 2009 | Acer Aspire 7520-5185 Laptop
My acer aspire one netbook when i press power on nothing happens,only power green lite is on no display no sound,i connected external monitor still same no display.
The power green light is the power to the unit. I believe that you have a motherboard issue, sorry to say.
Acer's repair site is as follows
http://secure2.tx.acer.com/FixMyAcer3/FixMyAcer.aspx
Hope this helps. Best Regards, - md
Nov 10, 2009 | Acer Aspire One PC Notebook
Acer One 1542 series.Power on but not boot.
since you reseated the memory, the last two things I would do is remove the hard drive and dvd drive.
If you remove those and you can't get video then the motherboard is bad.
Aug 03, 2009 | Acer Aspire One PC Notebook
No power on laptop screen
The first thing to try is to hook up an external monitor to the laptop.
If the external monitor works then it is either the LCD screen or the backlight for the LCD. If not then it is probably the video card inside the laptop.
Also check the "function" (Fn) key combinations on the keyboard, you might have shut the screen off with the Fn keys accidentally.
Hope this helps.
Apr 26, 2009 | Acer Computers & Internet
Acer Aspire 5500 5570-2609 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
