Kenmore 33721 Upright Vacuum
Problem for Kenmore 33721 Upright Vacuum
Kenmore 33721 does not start
By MrsX on Apr 23, 2007
I was using my Kenmore 33721 vacuum and it just stopped working (as if it was unpluged).
I verified the outlet had power and tried to turn the vacuum on. Nothing.
I tried in several other outlets. Nothing.
I have taken care of the vacuum regularly, following the cleaning procedure in the manual. It is four years old.
Any help would be appreciated.
Comments:
Sep 03, 2007
- Thanks Guest.
I got the cover off (lots of screws) but I'm not very good with wiring diagrams.
Is the fuse the detachable piece that is screwed into the motor?
Thanks.
Best Solution
posted on Sep 02, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Same thing happened to me. After taking the cover off I noticed a wiring diagram on the inside cover.
There is a fuse between the on/off button and the motor, sure enough the fuse had blown. There is no mention of a fuse in the manual!
The vacuum works great again.
Popular Solutions for Kenmore 33721 Upright Vacuum
Questions and Unsolved Problems for Kenmore 33721 Upright Vacuum
Do you recommend Kenmore 33721 Upright Vacuum?
Answer
Answer
pump works pump runs but no pressure does unit need to be primed
Answer
I got the vacuum apart and put the new belt on the roller but don't see where else to put belt. Help... (More)
Answer
how do i change the belt on my Kenmore upright vacuum?
Answer
My Kenmore upright bagless vacuum (Model# 116.36720600) just stopped working while cleaning. I've... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore 33721 Upright Vacuum:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
