I have a HP computer and its brand new and my speakers don't make sound, I think I need a program to make it run, but i'm not sure how to get it
  • 77 Answers
CHECK WITH THE SPEAKER CORDS PROPERLY CONNECTED TO CPU
Posted on Apr 06, 2009
How do I download the driver?
hello,
I think you need all the drivers in the computer and not just the sound driver since you wiped out everything there.
Here's what you can do:
Go to the website of your comptuer's manufacturer and auto detect the brand of your computer. If they don't have it, then just try searching for it in the computer's casing. You should find the model name somewhere. Make sure to select the support and downloads page in the website and enter the operating system that your computer is currently running. All drivers will be shown on the screen.
Download the following:
1. Video Driver
2. Chipset Driver
3. Audio Driver
4. Internet or Network Driver
You should also install an anti-virus in the computer to make sure that you won't get any virus. After installing everything and if everything's working great, then you can other programs there. You can also add a tech software which can boost your computer's performance like RadarSync which will keep all your drivers updated.
David
If you have any questions, please drop me a line.
Dec 14, 2012 | Cyber Acoustics CA-2014 Computer Speakers
I have old Boston BA735 digital speakers that I am trying to get to work with a new HP PC. Do I need drivers? There are 6 places to plug in speaker cables on the back of the PC. Which ones do I use?
Many of the new sound cards and especially sound cards on OEM do not support digital speakers without buying additional connectors. (Not sure why. I have these same great speakers for years and they are wonderful.
- Check if your sound card ha an SPDIF connection option. - Check the speakers in the device manager to see if you can toggle the "digital" option. - I also have read that some versions of the BA 735 have an analog option on the back of the subwoofer if you need to bypass digital. (mine don't, so I don't know if this is accurate)
Aug 12, 2011 | Boston Acoustics BA735 Computer Speakers
I just bought Bose Companion 2 speakers which I don't know how to connect to my HP Pavillion desktop PC. The pdf instruction booklet does not help. There are multiple jacks (6) at the back of the tower...
You need to connect the speakers to the green jack in your PC.
Check your system sound volume setting to make sure it's not set to MUTE or the volume slider is on or near the lowest position - you don't specify what system you have on the PC so I can't give you an exact pointer but Volume Control generally is found under Programs -> Accessories -> Entertainment.
Please come back and rate the solution if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
Jul 24, 2011 | Bose Companion 2 Series II Multimedia...
No sound
no sound mean:
1- speaker is bad
2- entrance sound is bad
3- driver is bad ( re-nstall)
4-windows had a damged files (re- install)
5- sound ic control is damaged ( need out pci/ usb sound card )
6- tow jumper in mother board are take off
if you see these answer helpful please don't forget to vote me
best regards
Apr 25, 2011 | Computers & Internet
We have default buildin sound card on HP brand PC. i setup windows recently, from then sound device not work. show now sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 24, 2011 | HP (400745-001) Sound Card
I have the Logitech X 540 5.1 speakers. When I used them on my HP Desk Top that had Vista they worked for a long time then all of a sudden stopped. I thought it might be my computer and I needed a new one...
Double check all of your connections and make sure everything is properly connected in the back of the sub woofer. Next, make sure that your audio jacks are plugged into the correct audio ports on *********** board, this is very import to make sure that sound is coming out and going to the proper channels. If the front speakers still do not work, recheck your audio settings on the motherboard. If all is folly and they still don't work, i would still recommend the same speaker set, as for the price they are amazing quality. But I will include a few other options within your price range.
http://www.logitech.com/assets/35723/setup-installation-guide.pdf
http://www.newegg.com/Product/Product.aspx?Item=N82E16836121044
http://www.newegg.com/Product/Product.aspx?Item=N82E16836116049
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6325847&CatId=2894
Jan 14, 2011 | Logitech X-540 Computer Speakers
No sound comming from audio volume
First check if you have the speakers pin (green) connected in tothe proper green socket on the back of the computer.
If yes, then right click on the sound / speaker icon that is near to your clock on the right bottom, and click "Adjust audio properties"
Now click the sounds tab in the audio properties.
Select any sound from the list under program events, and click the play button near the browse button. It should play a sound.
If you are not able to hear any sound BUT the play icon changes to the stop icon for a few  moments, it means the sounds play alright but something is wrong with the speakers or the connections.
HTH,
Deboo
Jan 18, 2009 | E-Machines eMachines Refurbished EMA...
I have a brand new hp computer and speakers don't work
Make sure the drivers for the speakers are installed and enabled in the sound properties. Hope this helps.
Dec 27, 2008 | HP Audio Players & Recorders
HP DV5000 Speaker problems... Lag??
It may be the speakers are going bad or you may need to update your sound card drivers.Try going to your setting for your sound and make sure the settings are correct.Make sure they are set for laptop stereo speakers with full hardware control.
Dec 13, 2008 | HP Compaq Pavilion dv5000z Notebook
23 people viewed this question
 Grubhead
Grubhead
