Question about Dell Inspiron 1525 Laptop
Windows Vista Blue Screen Error
I own the following system:
Dell Inspiron 1525 Laptop (6 months old) OEM System
Genuine Microsoft Windows Vista Home Premium
Intel Core 2 Duo CPU @2.00 GHz
3.0 GB RAM
160 GB HDD
I have encountered the following error:
IRQL driver not less or equal
Problem Event Name: BlueScreen
Some memory mini dump was written...
I don't remember as the blue screen was visible for 2-3 seconds and then the laptop got automatically shut down.
Is the error bcoz of out-dated Vista Drivers?
I downloaded Uniblue DriverScanner 2009 trial version and executed it...It showed 13 out-dated Vista Drivers...
Should I purchase the licensed version of this software and update the drivers? PLEASE SUGGEST...THANKS....
  • hafields Feb 08, 2009
    Same problem as described above on a brand new unit. The setup process auto updated about 12 or 13 Windows Vista programs and the Trend Micro antivirus software ran an update as well. I then activated the Face Recognition software, let that finish and then restarted the system. After restart I was presented with the IRQL blue screen. I let the system attempt a repair and then agreed to let it attempt a restore. Both of these attempts failed. I let the system try one additional time to repair itself and that attempt ended with a messge that says "Startup Repair cannot repair this computer automatically." Not sure what to do now. Any ideas.
  • Anonymous May 23, 2009
    blue screen occurs the lapton restarts itself
  • 433 Answers
Try this...on boot up hit F8 and select SAFE MODE and see if you can get in that way. Look on the control panel for add and remove programs...eliminate Uniblue from the program list. Reboot and you just may be fortunate.
Isn't it funny that the program that is messing up your machine is the one (for money) will fix it.
I still think the best way to update drivers is right from the manufacturer (ATI , nVidia, ASUS,)or the computer company (Dell-Gateway-HP) they all have driver updates for FREE in their Support area look for Drivers and Downloads. To contact their sites try the Company name and .com
I also think if things are running along just fine...don't update until performance suffers. Like your daddy told you...if it ain't busted, don't fix it.
hope this helps...good luck my friend
Posted on Apr 23, 2009
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Hi, My laptop doesn't boot up. I got a blue screen with the following error message- STOP: c000021a {Fatal System Error} The initial session process or system process terminated unexpectedly with a status...
Thats known as a blue screen of death. you simply have to put in an operating system CD which is bootable (the one which you are currently using win xp vista or whatever) just boot through the cd ignore the first repair option and hit enter when the option for repairs appears for the second time just hit R and follow the options. you won't loose any data.
Aug 20, 2010 | Dell Inspiron 1525 Notebook
My friend bought a new dell laptop & got vindows vista home premium for free when i wanted install that vista in my pc it installed on my pc bt now it is not activating with my friends vista's...
I assume you are using the Vista disk that came in with the system. Even though you can see a product key on your friends computer, It would not work on your own computer because that product key is intended only for that DELL computer. The windows Vista that your friend has is an OEM copy of the operating system. The product key should match the Hardware of the OEM computer for it to work.
I suggest you get a genuine copy of the operating system for your self.
Hope this helps.
Jul 04, 2010 | Microsoft Windows Vista Home Premium with...
I've just started up my Dell Inspiron, and for some reason the operating system looks like an old version of Windows 2003. It should be set up with Windows Vista, I've had this laptop for about 8 months...
Its not making sense. there is no Windows 2003. Unless you're referring to Windows Server 2003 or Microsoft Office 2003? They're not related except Windows Server 2003 is also an Operating System. I suggest to run PC Restore. Just a reminder, PC restore will restore your computer to factory setting. It will delete all data store in the computer. So you need to back up your files first. To run PC Restore, press Ctrl+F11 upon turning on your computer(While you seee the blue Dell Logo). Hope this will help.
Regards,
Melgasbal
Feb 22, 2010 | Dell Inspiron 1545 Notebook
"Dell Media Direct" on Inspiron 1525
Make sure you do not have a bootable CD or DVD in the drive. If that does not resolve, then try holding the "home" (Media Direct) button while pressing the Power button on.
Nov 02, 2009 | Dell Inspiron 1525 Laptop
Dell Inspiron 1525 Blue screen & windows error messages/reformat
Do a recovery first and if you are still getting a blue screen on this 1525 call dell and ask for a replacment do not go any further in trying to repair it yourself as anything you do would just make matters worse if its out of warrenty then the only thing you can do is try:
1. clean the unit if there is any dust
2. try new memory modules
3. run a memory diagnostic on it using windos diagnostics
4. recover the operating system.
I hope you have some good luck with this advice.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 17, 2009 | Dell Inspiron 1525 Notebook
I have Dell inspiron 1525 laptop with windows Vista home premium
go to bios setup n change sata driver to ATA from AHCI n  also disable da flash play module
Mar 18, 2009 | Microsoft Windows XP Professional for PC
Installation of MS SharePoint 2007 in Dell Inspiron 1525 Laptop
SInce SharePoint Services 3.0 and SharePoint Server 2007 does require a server interface to run the collaboration tools you are unfortunately stuck with running it on server software. But all is not doom and gloom as there is an option for you to run Microsoft's Virtual PC. Here is an article on how it works from Microsoft. (http://windowshelp.microsoft.com/Windows/en-US/Help/97a74f0e-798d-45ff-b9bf-7feed68c40e51033.mspx) . This allows you to not ony run your native Operating system, but also run SharePoint on th esame machine in a virtual environment.
Jan 09, 2009 | Dell Inspiron 1525 Laptop
Cant open my dell inspiron 1525 laptop
You can use Advanced Windows Password Recovery 4.0 to recover windows password, It's my favorite password recovery tool. You can have a try.
http://www.recoverwindowspassword.com
Dec 20, 2008 | Microsoft Windows Vista Home Premium with...
Download win xp
sorry u can't download windows XP u should purchase it and remove vista and install windows XP after installing u should download drivers for the dell laptop Inspiron 1525 of windows XP because vista is pre installed operating system including with drivers
Jul 29, 2008 | Microsoft Windows XP Professional With...
Dell Inspiron 1525 Laptop Logo
391 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
